[GeoNetwork-users] Schema plugin and profile
HI
I wonder if anyone could point me at a *simple* example of a "profile" with a clear statement about the minimum requirements for adding to - say - iso19139?
All I want to do is....:slight_smile:
Add a few elements to the iso19139 schema
I don't want to extend or otherwise modify *anything* in the iso19139 schema except to add a couple of elements - let's call the profile / plugin
iso19139.model
I have a model.xsd file and a schema.xsd file and a schema-ident.xml file
What else is needed?
I find the current documentation confusing I'm afraid - sections which say these directories *can* be present which implies they are optional followed by some which are mandatory and some which are optional?
Are "converters" XSLT transforms or a servlet or what? I feel I am swimming way out of my depth here and would appreciate some help :)!
Thanks
Paul
Paul Cleverley
Software Developer, Hydrodynamics & Metocean
E: p.cleverley@anonymised.com<mailto:p.cleverley@anonymised.com>
T: +44 (0)1491 822483
<http://www.hrwallingford.com/banner.html&gt;
[HR Wallingford Logo]
HR Wallingford
Howbery Park, Wallingford, Oxfordshire OX10 8BA, United Kingdom
T: +44 (0)1491 835381 F: +44 (0)1491 832233
[HR Wallingford Secondary Logo]
HR Wallingford and its subsidiaries uses faxes and emails for confidential and legally privileged business communications. They do not of themselves create legal commitments. Disclosure to parties other than addressees requires our specific consent. We are not liable for unauthorised disclosures nor reliance upon them.
If you have received this message in error please advise us immediately and destroy all copies of it.
HR Wallingford Limited
Howbery Park, Wallingford, Oxfordshire, OX10 8BA, United Kingdom
Registered in England No. 02562099
Hi Paul
I have worked recently in some schemas, let me explain how I managed:
I started the development based on this template project:
https://github.com/geonetwork/schema-plugins/tree/master/iso19139.xyz
One of the schemas is
https://github.com/geonetwork/schema-plugins/tree/master/iso19139.napm ,
that is iso19139 with customisations in xsd related to cardinality and some
custom codelist values mostly.
I did mostly these steps:
1) Customise schema-ident.xml with the rules to match metadata to the new
schema
2) In schema folder copy the iso19139 xsd and custom xsd (see
https://github.com/geonetwork/schema-plugins/tree/master/iso19139.napm/schema/napm
3) Map custom xsd in oasis-catalog.xml (see
https://github.com/geonetwork/schema-plugins/blob/master/iso19139.napm/oasis-catalog.xml#L58
4) Customise the codelists (if your schema has new values for iso19139
codelist or new codelists)
See
https://github.com/geonetwork/schema-plugins/blob/master/iso19139.napm/loc/eng/codelists.xml
5) Customise the labels (if your schema requires to replace iso19139
element labels or add labels for new elements)
See
https://github.com/geonetwork/schema-plugins/blob/master/iso19139.napm/loc/eng/labels.xml
6) Customise template names in present/metadata-edit.xsl and
present/metadata.xsl (I assume you work with 2.8 or 2.10 versions, for
develop branch changes a bit)
Take a look for example to
https://github.com/geonetwork/schema-plugins/blob/master/iso19139.napm/present/metadata-edit.xsl,
my schema is named iso19139.napm, some templates should have this name in
the template name (you need to replace with your schema name)
7) Almost all the other files you can see that delegate to iso19139 (see
for example,
https://github.com/geonetwork/schema-plugins/blob/master/iso19139.napm/index-fields.xsl
Another plugin that can be interesting to check is this one:
https://github.com/geonetwork/schema-plugins/tree/master/iso19139.naplio-dataset,
as adds new elements to iso19139.
1) The steps are similar, but present/metadata-edit.xsl and
present/metadata.xsl require some additional customisation to manage the
new elements. See
https://github.com/geonetwork/schema-plugins/blob/master/iso19139.naplio-dataset/present/metadata.xsl#L234
2) Also another change is to remove the custom elements from CSW responses
when requested iso19139 output. See
https://github.com/geonetwork/schema-plugins/blob/master/iso19139.naplio-dataset/present/csw/iso-full.xsl#L15
A bit long mail, but hope can help a bit to clarify the steps. I want to
update the documentation to improve it with a simple case, but could not
manage yet, will try to check in coming weeks.
Jose GarcĂ­a
On Fri, Apr 25, 2014 at 1:01 PM, Paul Cleverley <
P.Cleverley@anonymised.com> wrote:
HI
iso19139?
iso19139.model
Thanks
Paul
Paul Cleverley
HR Wallingford
Start Your Social Network Today - Download eXo Platform
Build your Enterprise Intranet with eXo Platform Software
Java Based Open Source Intranet - Social, Extensible, Cloud Ready
Get Started Now And Turn Your Intranet Into A Collaboration Platform
http://p.sf.net/sfu/ExoPlatform
GeoNetwork-users mailing list
* GeoCat Bridge for ArcGIS allows instant publishing of data and metadata
on GeoServer and GeoNetwork. Visit http://geocat.net
<http://geocat.net/&gt; for details. _________________________Jose
GarcĂ­aGeoCat bvVeenderweg 13 6721 WD BennekomThe
Netherlandshttp://GeoCat.net/> *
Jose, thank you very much indeed - that gives me a lot to go on!
I have managed to fake my iso19139.model schema to the point where the whole system doesn’t fall over. I am currently trying to edit an example MEF file to incorporate the new element I have added (ModelFeatureType) so I can add it as sample-data.
In step 7) you say “Almost all the other files you can see that delegate to iso19139” – do you mean I don’t have to have instances of these for my iso19139.model?
I don’t know what oasis is or what it is for?
I don’t know how geonetwork uses schema-ident.xml.
I don’t know how geonetwork uses codelists (lookup tables yes? – but the references to codelists are relative to what?)
I can’t find an explanation of what geonetwork thinks a “template” is – and no idea what the metadata.xsl and metadata-edit.xsl transforms are used for or where or when.
Labels is good! I will obviously need a new label for my element – I’ll call it “Model Feature Type” – but not yet clear on how GN uses the labels files (there appear to be lots of files called labels.xml, codelist.xml etc all in different directories and it’s not clear how GN merges / separates these )
Thank you so much for your help with this I will endeavour to go through each step accordingly!
Thanks!
Best wishes
Paul
Sent: Friday, April 25, 2014 1:34 PM
To: Paul Cleverley
Cc: geonetwork-users@lists.sourceforge.net
Subject: Re: [GeoNetwork-users] Schema plugin and profile
Hi Paul
I started the development based on this template project: https://github.com/geonetwork/schema-plugins/tree/master/iso19139.xyz
One of the schemas is https://github.com/geonetwork/schema-plugins/tree/master/iso19139.napm , that is iso19139 with customisations in xsd related to cardinality and some custom codelist values mostly.
1) Customise schema-ident.xml with the rules to match metadata to the new schema
2) In schema folder copy the iso19139 xsd and custom xsd (see https://github.com/geonetwork/schema-plugins/tree/master/iso19139.napm/schema/napm)
3) Map custom xsd in oasis-catalog.xml (see https://github.com/geonetwork/schema-plugins/blob/master/iso19139.napm/oasis-catalog.xml#L58)
4) Customise the codelists (if your schema has new values for iso19139 codelist or new codelists)
See https://github.com/geonetwork/schema-plugins/blob/master/iso19139.napm/loc/eng/codelists.xml
5) Customise the labels (if your schema requires to replace iso19139 element labels or add labels for new elements)
See https://github.com/geonetwork/schema-plugins/blob/master/iso19139.napm/loc/eng/labels.xml
6) Customise template names in present/metadata-edit.xsl and present/metadata.xsl (I assume you work with 2.8 or 2.10 versions, for develop branch changes a bit)
Take a look for example to https://github.com/geonetwork/schema-plugins/blob/master/iso19139.napm/present/metadata-edit.xsl, my schema is named iso19139.napm, some templates should have this name in the template name (you need to replace with your schema name)
7) Almost all the other files you can see that delegate to iso19139 (see for example, https://github.com/geonetwork/schema-plugins/blob/master/iso19139.napm/index-fields.xsl)
Another plugin that can be interesting to check is this one: https://github.com/geonetwork/schema-plugins/tree/master/iso19139.naplio-dataset , as adds new elements to iso19139.
1) The steps are similar, but present/metadata-edit.xsl and present/metadata.xsl require some additional customisation to manage the new elements. See https://github.com/geonetwork/schema-plugins/blob/master/iso19139.naplio-dataset/present/metadata.xsl#L234
2) Also another change is to remove the custom elements from CSW responses when requested iso19139 output. See https://github.com/geonetwork/schema-plugins/blob/master/iso19139.naplio-dataset/present/csw/iso-full.xsl#L15
A bit long mail, but hope can help a bit to clarify the steps. I want to update the documentation to improve it with a simple case, but could not manage yet, will try to check in coming weeks.
Jose GarcĂ­a
On Fri, Apr 25, 2014 at 1:01 PM, Paul Cleverley <P.Cleverley@...1309...<mailto:P.Cleverley@…1309…>> wrote:
HI
iso19139.model
Thanks
Paul
Paul Cleverley
E: p.cleverley@...1309...<mailto:p.cleverley@…1309…><mailto:p.cleverley@…1309…>
T: +44 (0)1491 822483<tel:%2B44%20%280%291491%20822483>
HR Wallingford
T: +44 (0)1491 835381<tel:%2B44%20%280%291491%20835381> F: +44 (0)1491 832233<tel:%2B44%20%280%291491%20832233>
www.hrwallingford.com<http://www.hrwallingford.com>
GeoNetwork-users@lists.sourceforge.net<mailto:GeoNetwork-users@lists.sourceforge.net>
GeoCat Bridge for ArcGIS allows instant publishing of data and metadata on GeoServer and GeoNetwork. Visit http://geocat.net/&gt; for details.
Jose GarcĂ­a
GeoCat bv
Veenderweg 13
6721 WD Bennekom
The Netherlands
http://GeoCat.net/&gt;
This message has been scanned for viruses by MailControl<http://www.mailcontrol.com/&gt;, a service from BlackSpider Technology
Click here<https://www.mailcontrol.com/sr/n274HG0AFdHGX2PQPOmvUvmldA89nuwlhZgA2r7PaGotm4jMfTGRzy6Jv+6tRVI65zXWrIMm5qT1JTd!1uc+!w==&gt; to report this email as spam.
Hi Paul
iso19139.model?
You need to have them in your schema, but can copy from
https://github.com/geonetwork/schema-plugins/blob/master/iso19139.xyz
See for example
https://github.com/geonetwork/schema-plugins/blob/master/iso19139.xyz/index-fields.xsl#L3,
imports the same file from iso19139 schema, but the file
index-fields.xsl should be also in your profile.
I would start the schema based on
https://github.com/geonetwork/schema-plugins/blob/master/iso19139.xyz and
start customising the files I described in the previous mail. All the other
files you can leave untouched.
Jose GarcĂ­a
On Fri, Apr 25, 2014 at 2:43 PM, Paul Cleverley <
iso19139.model?
these )
Thanks!
Best wishes
Paul
*From:* Jose Garcia [mailto:jose.garcia@anonymised.com]
*Sent:* Friday, April 25, 2014 1:34 PM
*To:* Paul Cleverley
*Cc:* geonetwork-users@lists.sourceforge.net
*Subject:* Re: [GeoNetwork-users] Schema plugin and profile
Hi Paul
new schema
See
See
for example,
https://github.com/geonetwork/schema-plugins/tree/master/iso19139.naplio-dataset, as adds new elements to iso19139.
new elements. See
Jose GarcĂ­a
HI
iso19139?
iso19139.model
Thanks
Paul
Paul Cleverley
HR Wallingford
GeoServer and GeoNetwork. Visit http://geocat.net for details.
Jose GarcĂ­a
GeoCat bv
Veenderweg 13
6721 WD Bennekom
The Netherlands
Click here<https://www.mailcontrol.com/sr/n274HG0AFdHGX2PQPOmvUvmldA89nuwlhZgA2r7PaGotm4jMfTGRzy6Jv+6tRVI65zXWrIMm5qT1JTd!1uc+!w==&gt;to report this email as spam.
*HR Wallingford and its subsidiaries* uses faxes and emails for
Paul,
The developer manual has a whole section on schema plugins
that explains most if not all of the things you mention below (using iso19139.mcp as an example). I suspect Jose intended that you read that in order to help with his steps :-).
Please make sure you're using 2.10.3 as well on windows because there were a number of issues (mainly relating to handling of URIs/URLs in xml-resolver jar) that prevented GeoNetwork 2.10.2 and earlier from working on windows - one of the problems actually caused the error you were seeing.
Simon
________________________________________
Sent: Friday, 25 April 2014 10:43 PM
To: 'Jose Garcia'
Thanks!
Best wishes
Paul
From: Jose Garcia [mailto:jose.garcia@anonymised.com]
To: Paul Cleverley
Hi Paul
I started the development based on this template project: schema-plugins/iso19139.xyz at develop · geonetwork/schema-plugins · GitHub
One of the schemas is schema-plugins/iso19139.napm at develop · geonetwork/schema-plugins · GitHub , that is iso19139 with customisations in xsd related to cardinality and some custom codelist values mostly.
Another plugin that can be interesting to check is this one: schema-plugins/iso19139.naplio-dataset at develop · geonetwork/schema-plugins · GitHub , as adds new elements to iso19139.
Jose GarcĂ­a
On Fri, Apr 25, 2014 at 1:01 PM, Paul Cleverley <P.Cleverley@anonymised.com<mailto:P.Cleverley@anonymised.com>> wrote:
HI
iso19139.model
Thanks
Paul
Paul Cleverley
E: p.cleverley@anonymised.com<mailto:p.cleverley@anonymised.com><mailto:p.cleverley@anonymised.com>
HR Wallingford
GeoNetwork-users@lists.sourceforge.net<mailto:GeoNetwork-users@anonymised.comforge.net>
Jose GarcĂ­a
GeoCat bv
Veenderweg 13
6721 WD Bennekom
The Netherlands
:slight_smile: Yes - I have read it about fifty times :slight_smile: ! (hence my quotes from it ). I am clearly a bear of very little brain!
I am using 2.10.3.
I suspect there is a huge gap between what you guys are aware of in terms of other schemata (eg srv, etc) and what they are for and what I know (new to geo systems I'm afraid so there is something of the monkey pushing buttons about my current role :-} ) - and also a familiarity with geonetwork itself.
Anyway, I have manfully struggled through Tomcat, GN v 2.6 and 2.8, spaces in path names, GAST and Postgres under windows and multiple instances of GN with different names and arrived at the installation of 2.10.3 using jetty.
And - phew - it works - although when the server fires up I get warnings they don’t look particularly dangerous (I list them here for consideration)
2014-04-25 14:05:59,365 WARN [geonetwork.schemamanager] - Cannot resolve http://www.w3.org/2001/03/xml.xsd: will append last component to current path (not sure it will help though!)
2014-04-25 14:05:59,739 WARN [geonetwork.schemamanager] - WARNING: gco:Record is a global element without a type - assuming a string
2014-04-25 14:06:00,102 WARN [geonetwork.schemamanager] - WARNING: gco:Record is a global element without a type - assuming a string
2014-04-25 14:06:00,113 WARN [geonetwork.schemamanager] - WARNING: schema-substitutions.xml has wiped out XSD substitution list for gml:CoordinateSystemAxis
2014-04-25 14:06:00,119 WARN [geonetwork.schemamanager] - WARNING: schema-substitutions.xml has wiped out XSD substitution list for gml:VerticalCS
2014-04-25 14:06:00,125 WARN [geonetwork.schemamanager] - WARNING: schema-substitutions.xml has wiped out XSD substitution list for gml:CoordinateSystemAxis
2014-04-25 14:06:00,126 WARN [geonetwork.schemamanager] - WARNING: schema-substitutions.xml has wiped out XSD substitution list for gml:VerticalDatum
One thing I find confusing about the documentation is this - it starts off talking about *schema plugins* and then mentions *profiles* as a useful way of doing simple extensions and then goes on to describe mcp ( a *profile*) in fairly complex terms - I am not at all clear on the difference between a "profile" and a "schema plugin" I'm afraid. I'll read it again and hope the penny drops but...
Jose's mail will give me lots to chew on I'm sure!
Thanks again!
Paul
-----Original Message-----
From: Simon.Pigot@anonymised.com [mailto:Simon.Pigot@anonymised.com]
Sent: Friday, April 25, 2014 1:57 PM
To: Paul Cleverley; jose.garcia@anonymised.com
Subject: RE: [GeoNetwork-users] Schema plugin and profile
Paul,
http://geonetwork-opensource.org/manuals/2.10.3/eng/developer/schemaPlugins/index.html
Simon
To: 'Jose Garcia'
Thanks!
Best wishes
Paul
To: Paul Cleverley
Hi Paul
Jose GarcĂ­a
HI
iso19139.model
Thanks
Paul
Paul Cleverley
HR Wallingford
Howbery Park, Wallingford, Oxfordshire, OX10 8BA, United Kingdom Registered in England No. 02562099
Start Your Social Network Today - Download eXo Platform Build your Enterprise Intranet with eXo Platform Software Java Based Open Source Intranet - Social, Extensible, Cloud Ready Get Started Now And Turn Your Intranet Into A Collaboration Platform http://p.sf.net/sfu/ExoPlatform _______________________________________________
Jose GarcĂ­a
GeoCat bv
Veenderweg 13
6721 WD Bennekom
The Netherlands
Ok thanks I’m doing that now.
When you say “ you need to have them in your schema “ do you mean I need to include them in my directory iso19139.model? is this a “schema” or a “schema plugin” or a “profile”?
BTW one approach I took was to copy iso19139 in its entirety; refactor every occurrence in the schema plugin of “iso19139” to “iso19139.model” (including file names).
The server ran ok but opening the home page gave me an error about not being able to compile stylesheets?
Thanks!
Paul
Sent: Friday, April 25, 2014 1:50 PM
To: Paul Cleverley
Hi Paul
You need to have them in your schema, but can copy from https://github.com/geonetwork/schema-plugins/blob/master/iso19139.xyz
See for example https://github.com/geonetwork/schema-plugins/blob/master/iso19139.xyz/index-fields.xsl#L3 , imports the same file from iso19139 schema, but the file index-fields.xsl should be also in your profile.
I would start the schema based on https://github.com/geonetwork/schema-plugins/blob/master/iso19139.xyz and start customising the files I described in the previous mail. All the other files you can leave untouched.
Jose GarcĂ­a
On Fri, Apr 25, 2014 at 2:43 PM, Paul Cleverley <P.Cleverley@...1309...<mailto:P.Cleverley@…1309…>> wrote:
Thanks!
Best wishes
Paul
To: Paul Cleverley
Cc: geonetwork-users@lists.sourceforge.net<mailto:geonetwork-users@lists.sourceforge.net>
Hi Paul
Jose GarcĂ­a
HI
iso19139.model
Thanks
Paul
Paul Cleverley
HR Wallingford
Jose GarcĂ­a
GeoCat bv
Veenderweg 13
6721 WD Bennekom
The Netherlands
Click here<https://www.mailcontrol.com/sr/MZbqvYs5QwJvpeaetUwhCQ==&gt; to report this email as spam.
Jose GarcĂ­a
GeoCat bv
Veenderweg 13
6721 WD Bennekom
The Netherlands
I have added a few elements to the 19139 to add for biological extensions
and I have the files and full documentation here:
ftp://ftp.ncddc.noaa.gov/pub/Metadata/Online_ISO_Training/Intro_to_ISO/schemas/ISObio/
Please do not hesitate to ask if you have any questions.
Jaci
On Fri, Apr 25, 2014 at 6:01 AM, Paul Cleverley <
HI
iso19139?
iso19139.model
Thanks
Paul
Paul Cleverley
HR Wallingford
Jacqueline Mize
Metadata Specialist
Radiance Technologies, Inc.
DOC/NOAA/NESDIS/NODC/NCDDC
1021 Balch Blvd, Suite 1003
Stennis Space Center, MS 39529
email: Jacqueline.Mize@anonymised.com
ph: 228.688.2174
Thanks Jaci – I will take a look! I just discovered the README.TXT file at https://github.com/geonetwork/schema-plugins which helps a bit too!
Paul
From: Jacqueline Mize - NOAA Affiliate [mailto:jacqueline.mize@anonymised.com]
Sent: Friday, April 25, 2014 2:57 PM
To: Paul Cleverley; Angela Sallis - NOAA Affiliate
I have added a few elements to the 19139 to add for biological extensions and I have the files and full documentation here: ftp://ftp.ncddc.noaa.gov/pub/Metadata/Online_ISO_Training/Intro_to_ISO/schemas/ISObio/
Jaci
On Fri, Apr 25, 2014 at 6:01 AM, Paul Cleverley <P.Cleverley@anonymised.com<mailto:P.Cleverley@anonymised.com>> wrote:
HI
iso19139.model
Thanks
Paul
Paul Cleverley
HR Wallingford
Jacqueline Mize
Metadata Specialist
email: Jacqueline.Mize@anonymised.com<mailto:Jacqueline.Mize@anonymised.com>
ph: 228.688.2174
Click here<https://www.mailcontrol.com/sr/m+qQeCwChn!GX2PQPOmvUvmldA89nuwlvvGANCgsdRAmE+pHf3+XMYKjnJScCKcZ5zXWrIMm5qQhR!AbTPK7tQ==&gt; to report this email as spam.
Hi Jose et al
I have made great strides thanks to your guidance :smiling_face:! Thank you very much indeed.
I now need to understand a bit more about how to make complex items available in the user interface.
For example - I have added a schema called mim. This – basically – comprises two lists – “inputs” and “outputs”. Each list contains 0 or more elements “input” or “output” – and each of those derive from a base “ioType” element type (so they are identical except for the element name).
Sorry to throw it at you but here's the new schema. What I would like to see on the web page when I create some metadata is – in the contentInfo section – a subsection called “Inputs” with a subsection for each input; and a subsection called “Outputs” with a subsection for each output.
I have modified the labels.xml accordingly (I think). However all I currently see are the fields for a single ioType and no text or sections for Inputs or Outputs.
So the question is – basically – how do I get a template built so that geonetwork will display sections as per the xml structure here and allow the user to add and remove inputs and outputs to their little heart’s desires? Very much appreciate any help you can offer – as I say, couldn’t have got this far without you :-}
       <contentInfo>
              <mim:modelInstance>
                     <mim:inputs>
                           <mim:input>
                                  <mim:featureType>Feature type</mim:featureType>
                                  <mim:position>Position</mim:position>
                                  <mim:parameter>Parameter</mim:parameter>
                                  <mim:timeRange>timeRange</mim:timeRange>
                                  <mim:timeStepType>timesteptype</mim:timeStepType>
                                  <mim:maximumTimestep>Maximum timestep</mim:maximumTimestep>
                                  <mim:minimumTimestep>Minimum timestep</mim:minimumTimestep>
                           </mim:input>
                     </mim:inputs>
                     <mim:outputs>
                           <mim:output>
                           </mim:output>
                     </mim:outputs>
              </mim:modelInstance>
       </contentInfo>
<?xml version="1.0" encoding="utf-8"?>
<xs:schema xmlns:xs="http://www.w3.org/2001/XMLSchema&quot; xmlns:gmd="http://www.isotc211.org/2005/gmd&quot; xmlns:gco="http://www.isotc211.org/2005/gco&quot; xmlns:gml="http://www.opengis.net/gml&quot; xmlns:mim="http://www.hrwallingford.co.uk/mim/1.0&quot; targetNamespace="http://www.hrwallingford.co.uk/mim/1.0&quot; elementFormDefault="qualified" version="1.0">
       <xs:import namespace="http://www.isotc211.org/2005/gmd&quot; schemaLocation="../../../iso19139/schema/gmd/gmd.xsd"/>
       <xs:import namespace="http://www.isotc211.org/2005/gco&quot; schemaLocation="../../../iso19139/schema/gco/gco.xsd"/>
       <xs:import namespace="http://www.opengis.net/gml&quot; schemaLocation="../../../iso19139/schema/gml/gml.xsd"/>
       <xs:element name="modelInstance" type="mim:modelInstanceType"/>
       <xs:element name="inputs" type="mim:inputListType"/>
       <xs:element name="outputs" type="mim:outputListType"/>
       <xs:element name="input" type="mim:ioType"/>
       <xs:element name="output" type="mim:ioType"/>
       <xs:complexType name="modelInstanceType">
              <xs:annotation>
                     <xs:documentation>Data specific to a model instance</xs:documentation>
              </xs:annotation>
              <xs:sequence>
                     <xs:element ref="mim:inputs" minOccurs="1" maxOccurs="1"/>
                     <xs:element ref="mim:outputs" minOccurs="1" maxOccurs="1"/>
              </xs:sequence>
       </xs:complexType>
       <xs:complexType name="inputListType">
              <xs:annotation>
                     <xs:documentation>A list of inputs for a model instance</xs:documentation>
              </xs:annotation>
              <xs:sequence>
                     <xs:element ref="mim:input" minOccurs="0" maxOccurs="unbounded"/>
              </xs:sequence>
       </xs:complexType>
       <xs:complexType name="outputListType">
              <xs:annotation>
                     <xs:documentation>A list of outputs for a model instance</xs:documentation>
              </xs:annotation>
              <xs:complexContent>
                     <xs:extension base="gmd:AbstractMD_ContentInformation_Type">
                           <xs:sequence>
                                  <xs:element ref="mim:output" minOccurs="0" maxOccurs="unbounded"/>
                           </xs:sequence>
                     </xs:extension>
              </xs:complexContent>
       </xs:complexType>
       <xs:complexType name="inputType">
              <xs:annotation>
                     <xs:documentation>An input for a model instance</xs:documentation>
              </xs:annotation>
              <xs:complexContent>
                     <xs:extension base="mim:ioType"/>
       </xs:complexType>
       <xs:complexType name="outputType">
              <xs:annotation>
                     <xs:documentation>An output for a model instance</xs:documentation>
              </xs:annotation>
              <xs:complexContent>
       </xs:complexType>
       <xs:complexType name="ioType">
              <xs:annotation>
                     <xs:documentation>Base type for both input and output for a model instance</xs:documentation>
              </xs:annotation>
              <xs:sequence>
                     <xs:element name="description" type="gco:CharacterString_PropertyType"/>
                     <xs:element name="featureType" type="gco:CharacterString_PropertyType"/>
                     <xs:element name="position" type="gco:CharacterString_PropertyType"/>
                     <xs:element name="parameter" type="gco:CharacterString_PropertyType"/>
                     <xs:element name="timeRange" type="gco:CharacterString_PropertyType"/>
                     <xs:element name="timeStepType" type="gco:CharacterString_PropertyType"/>
                     <xs:element name="maximumTimestep" type="gco:CharacterString_PropertyType"/>
                     <xs:element name="minimumTimestep" type="gco:CharacterString_PropertyType"/>
              </xs:sequence>
       </xs:complexType>
</xs:schema>
Sent: Friday, April 25, 2014 3:13 PM
To: Paul Cleverley
Hi Paul
Not there as the xyz it's only an schema template. If you have a model.xsd should be referenced there.
See for example: https://github.com/geonetwork/schema-plugins/blob/master/iso19139.napm/schema.xsd#L11
<xs:import namespace="http://www.geoconnections.org/nap/napMetadataTools/napXsd/napm&quot; schemaLocation="schema/napm/napm.xsd"/>
You should change for your model.xsd.
Jose GarcĂ­a
On Fri, Apr 25, 2014 at 4:03 PM, Paul Cleverley <P.Cleverley@...1309...<mailto:P.Cleverley@…1309…>> wrote:
Hi Jose
The xyz schema.xsd looks like this:
<xs:schema targetNamespace="http://my/schema/target/namespace&quot; elementFormDefault="qualified"
            xmlns:xyz="http://my/schema/target/namespace&quot; xmlns:xs="http://www.w3.org/2001/XMLSchema&quot;
            xmlns:gmd="http://www.isotc211.org/2005/gmd&quot; xmlns:gmx="http://www.isotc211.org/2005/gmx&quot;
            xmlns:srv="http://www.isotc211.org/2005/srv&quot;&gt;
            <xs:include schemaLocation="schema/xyz.xsd"/>
            <xs:import namespace="http://www.isotc211.org/2005/srv&quot; schemaLocation="schema/srv/srv.xsd"/>
</xs:schema>
But there is no schema subdirectory containing xyz.xsd… any ideas if this is missing or not required in a sample?
Paul
To: Paul Cleverley
Hi Paul
Jose GarcĂ­a
Thanks!
Best wishes
Paul
To: Paul Cleverley
Hi Paul
Jose GarcĂ­a
HI
iso19139.model
Thanks
Paul
Paul Cleverley
HR Wallingford
Jose GarcĂ­a
GeoCat bv
Veenderweg 13
6721 WD Bennekom
The Netherlands
Jose GarcĂ­a
GeoCat bv
Veenderweg 13
6721 WD Bennekom
The Netherlands
Jose GarcĂ­a
GeoCat bv
Veenderweg 13
6721 WD Bennekom
The Netherlands
