Hi Simon,
Thanks for the fix.
As for the second problem below, I guess this should not happen if the first problem has been fixed. I ran into that problem when I do this after adding the new schema and template and not seeing it listed in the add metadata page :
1) After I added the template, no template listed in "Add Metadata" page. So I had tried to add the template again. When checked in the database -> metadata table, the record shows that the template had been added successfully and had duplicate records due to my previous action.
2) Since there's no delete function for removing added template, what I did is to drop and recreate the geonetwork database and delete the schemaPlugin directory.
3) After restart GeoServer, 'The requested operation could not be performed. TransformerConfigurationException : Failed to compile stylesheet. 3 errors detected' error occurred. -> Mentioned in earlier email, if I manual remove the template, I should remove the entry in ../WEB-INF/schemaplugin-uri-catalog.xml file as well.
4) 'you must add the core profile template (iso19139 in this case)' => I guess this is incorrect and you can ignore this statement.
May be a "delete" button would be great for added template. Or additional doc to guide user how to remove a template from geonetwork.
Thanks & Regards,
Florence
-----Original Message-----
Sent: Friday, 29 July 2011 11:38 PM
To: Tan, Florence (CESRE, Kensington); geonetwork-users@anonymised.comet
Subject: RE: [GeoNetwork-users] schema plugin questions
Hi Florence,
Ok, not seeing the templates in 'New metadata' after adding a schema+templates is an issue that should be fixed, you shouldn't have to restart after adding a metadata schema. I've fixed that in svn commit rev 8049.
I really would like to know if possible how you ran into the other problems you mentioned in your original post where you were also saying that the main page wouldn't compile after you added the schema ie. 'The requested operation could not be performed. TransformerConfigurationException : Failed to compile stylesheet. 3 errors detected' and that you needed to add the base schema iso19139 ie. 'you must add the core profile template (iso19139 in this case) -> thanks Terry for pointing this out.' I couldn't reproduce those so the reason for this persistence is so that we can either change the doc or otherwise take steps to avoid that happening to other users
Cheers and thanks for reporting this,
Simon
________________________________________
Sent: Friday, 29 July 2011 6:25 PM
To: Pigot, Simon (CMAR, Hobart); geonetwork-users@lists.sourceforge.net
Hi Simon,
No, I didn't remove the build in schema for iso19139. What I think will be an important step is to restart GeoNetwork if the new template added doesn't show up in the list. My first test was just adding the iso19139.anzlic.zip and the template, but when click on the Add metadata, I get message ask me to add template first - I guess if I have restarted the GeoNetwork, I do not have to run thru all these trial and error.
After successful added the anzlic profile, I go on with a second test to add the mcp profile, successfully added and no restart of GeoNetwork needed and is able to see the mcp template in the template list in Add Metadata.
FYI, I'm using Internet Explorer.
Florence
Sent: Friday, 29 July 2011 4:14 PM
Hi Florence,
This may have been unnecessarily complicated due to some unusual steps you took? There is no need to add iso19139 - it is a built in schema and it's presence is assumed - if you removed it (and I don't know why you'd do that) then this might explain why you've had issues.
I just built a bare trunk + installer, installed it, built the schemaPlugin zip files (by running 'ant' in the checked out schemaPlugins/trunk directory), then added iso19139.anzlic.zip (from the dist subdirectory) to GeoNetwork thru 'Add a metadata schema / profile' and everything worked as expected.
Basically I'm not sure why you have had to take such convoluted steps (unless you removed the iso19139 built in schema) but I certainly didn't and don't see the problems you have had.
If there are additional steps or extra info that might help avoid this in future it would be good if you can suggest it for the doco.
Cheers and thanks,
Simon
From: Florence.Tan@anonymised.com [Florence.Tan@anonymised.com]
Sent: Friday, 29 July 2011 5:03 PM
To: geonetwork-users@lists.sourceforge.net
Subject: Re: [GeoNetwork-users] schema plugin questions
One more point to add :
5) if the new template still doesn't listed, restart GeoNetwork.
From: Florence.Tan@anonymised.com [mailto:Florence.Tan@anonymised.com]
Sent: Friday, 29 July 2011 2:35 PM
Subject: [ExternalEmail] Re: [GeoNetwork-users] schema plugin questions
Hi List,
After a few times trial and error, managed to get the profile uploaded and the template listed, a few mistakes done earlier and here's the correct steps for those who are interested :
1) Login to geonetwork as admin
2) Add anzlic profile thru "Add a metadata schema / profile"
3) Add the template for the new profile => previously missing this step
4) Click on "New metadata", now able to see list of iso19139.anzlic templates
* One thing to note : before adding anzlic profile template, you must add the core profile template (iso19139 in this case) -> thanks Terry for pointing this out.
As for the "The requested operation could not be performed. TransformerConfigurationException : Failed to compile stylesheet. 3 errors detected" error that I had, found the root cause. What I had done, recreate the database used by GeoNetwork, removing the newly uploaded schema folder (as specify in config.xml -> schemaPluginsDir parameter). After restart, GeoNetwork will failed to load the and getting the mentioned error. To fix, remove the new uri appended for the new schema plugin in ../WEB-INF/schemaplugin-uri-catalog.xml file (after <!-- plug in schemas - come next - managed by schema.add/update/delete -->). Restart GeoNetwork.
Florence
Sent: Friday, 29 July 2011 11:30 AM
Subject: [ExternalEmail] [GeoNetwork-users] schema plugin questions
Hi List,
I'd downloaded geonetwork trunk, build and deployed to my windows environment. Also downloaded the schemaplugin trunk and build to get the archive. What I had tested so far :
1) Start geonetwork, login as admin
2) Added iso19139.anzlic profile thru "Add a metadata schema / profile" - the profile has been added successfully with message "Schema iso19139.anzlic has been added/updated"
3) After adding the profile, clicking on the "New metadata", I don't see any template added for the anzlic profile ??
4) Another weird thing encountered is after adding the new profile, restarting GeoNetwork, the main.home will fail to load with the following error meessage
" The requested operation could not be performed.
Looking into the geonetwork.log, here's detail of the the error log :
2011-07-29 10:58:17,625 INFO [jeeves.request] - ==========================================================
2011-07-29 10:58:17,625 INFO [jeeves.request] - HTML Request (from 127.0.0.1) : /geonetwork/srv/en/main.home
2011-07-29 10:58:17,625 DEBUG [jeeves.request] - Method : GET
2011-07-29 10:58:17,625 DEBUG [jeeves.request] - Content type : null
2011-07-29 10:58:17,625 DEBUG [jeeves.request] - Accept : image/gif, image/jpeg, image/pjpeg, image/pjpeg, application/x-shockwave-flash, application/vnd.ms-excel, application/vnd.ms-powerpoint, application/msword, application/x-ms-application, application/x-ms-xbap, application/vnd.ms-xpsdocument, application/xaml+xml, */*
2011-07-29 10:58:17,625 DEBUG [jeeves.request] - Session id is F9CC5F52290D938EC7AA7EB378A5AA5B
2011-07-29 10:58:17,625 INFO [jeeves.service] - Dispatching : main.home
2011-07-29 10:58:17,625 DEBUG [jeeves.service] - -> no input parameters
2011-07-29 10:58:17,625 INFO [jeeves.service] - -> dispatching to output for : main.home
2011-07-29 10:58:17,906 INFO [jeeves.service] - -> transforming with stylesheet : C:\geonetworktrunk\web\geonetwork\/xsl/main-page.xsl
2011-07-29 10:58:18,672 ERROR [jeeves.service] - -> exception during transformation for : main.home
2011-07-29 10:58:18,672 ERROR [jeeves.service] - -> (C) stylesheet : C:\geonetworktrunk\web\geonetwork\/xsl/main-page.xsl
2011-07-29 10:58:18,672 ERROR [jeeves.service] - -> (C) message : Failed to compile stylesheet. 3 errors detected.
2011-07-29 10:58:18,672 ERROR [jeeves.service] - -> (C) exception : TransformerConfigurationException
2011-07-29 10:58:18,672 DEBUG [jeeves.service] - Raised exception while executing service
<error id="error">
<message>Failed to compile stylesheet. 3 errors detected.</message>
<class>TransformerConfigurationException</class>
<stack>
<at class="net.sf.saxon.PreparedStylesheet" file="PreparedStylesheet.java" line="176" method="prepare" />
<at class="net.sf.saxon.TransformerFactoryImpl" file="TransformerFactoryImpl.java" line="139" method="newTemplates" />
<at class="de.fzi.dbs.xml.transform.CachingTransformerFactory" file="CachingTransformerFactory.java" line="128" method="newTransformer" />
<at class="de.fzi.dbs.xml.transform.CachingTransformerFactory" file="CachingTransformerFactory.java" line="82" method="newTransformer" />
<at class="jeeves.utils.Xml" file="Xml.java" line="370" method="transform" />
<at class="jeeves.utils.Xml" file="Xml.java" line="296" method="transform" />
<at class="jeeves.server.dispatchers.ServiceManager" file="ServiceManager.java" line="718" method="dispatchOutput" />
<at class="jeeves.server.dispatchers.ServiceManager" file="ServiceManager.java" line="414" method="dispatch" />
<at class="jeeves.server.JeevesEngine" file="JeevesEngine.java" line="709" method="dispatch" />
<at class="jeeves.server.sources.http.JeevesServlet" file="JeevesServlet.java" line="196" method="execute" />
</stack>
<request>
<language>en</language>
<service>main.home</service>
</request>
<response />
</error>
I'm stil very new to GeoNetwork and need some pointer if I had done something not right ? My questions would be :
Q1) Why after adding the iso19139.anzlic profile, the template doesn't show up in the list as 3) above ? I'd tested adding the existing iso19139 template and able to see lists of templates when click on "Add metadata"
Q2) What's causing the main page failed to load ? How can I fix it ?
Florence Tan
Software Engineer | Auscope Grid
CSIRO Earth Science and Resource Engineering
Phone: +61 8 6436 8802 | Fax: +61 8 6436 8559
florence.tan@anonymised.com<mailto:florence.tan@anonymised.com> | www.csiro.au
Address: Australian Resources Research Centre, 26 Dick Perry Avenue, Kensington WA 6151
PLEASE NOTE
The information contained in this email may be confidential or privileged. Any unauthorised use or disclosure is prohibited. If you have received this email in error, please delete it immediately and notify the sender by return email. Thank you. To the extent permitted by law, CSIRO does not represent, warrant and/or guarantee that the integrity of this communication has been maintained or that the communication is free of errors, virus, interception or interference.
Please consider the environment before printing this email.
Got Input? Slashdot Needs You.
Take our quick survey online. Come on, we don't ask for help often.
Plus, you'll get a chance to win $100 to spend on ThinkGeek.
http://p.sf.net/sfu/slashdot-survey
GeoNetwork-users mailing list
