Hi folks,
I'm reposting my message. Jeroen reported that the message was
"bounced". Maybe a problem with the file that I attached.
To solve this problem with the e-mail I post the file that I
attached before as a "pastebin" that can be accessed by browser.
The link for the attached file: "http://pastebin.com/813661"\. This
link will be valid until the end of November.
Best regards.
Fernando Simon
Jeroen Ticheler wrote:
> Hi Fernando,
> Not sure why, but it seems the message bounced. You may try to send it
> again and maybe shorten the log file a bit!?
> Ciao,
> Jeroen
> On Oct 26, 2006, at 3:27 PM, sitelist-bounces@lists.sourceforge.net
> <mailto:sitelist-bounces@lists.sourceforge.net> wrote:
>> The attached message was received as a bounce, but either the bounce
>> format was not recognized, or no member addresses could be extracted
>> from it. This mailing list has been configured to send all
>> unrecognized bounce messages to the list administrator(s).
>> For more information see:
>> https://lists.sourceforge.net/lists/admin/geonetwork-users/bounce
>> *From: *Fernando Simon <fsimon@anonymised.com <mailto:fsimon@anonymised.com>>
>> *Date: *October 26, 2006 2:28:09 PM GMT+02:00
>> *To: *geonetwork-users-bounces@lists.sourceforge.net
>> <mailto:geonetwork-users-bounces@lists.sourceforge.net>
>> *Subject: **Schema problem*
>> Hi folks,
>> First, I'm Fernando Simon from Santa Catarina, Brazil. I work in the
>> LCA lab on the UNIVALI University, and here we work with environmental
>> information systems. We already worked since 2001 with Geotools,
>> Geoserver, Oracle spatial, PostgreSQL/PostGIS, and UMN Mapserver. And
>> for UMN Mapserver I develop the native Oracle Spatial connector.
>> So, now we starting to use a GeoNetwork to improve and develop new
>> projects here. After the installation and a little utilization I'm with
>> two problems. The first is with the schemas, the list of the schemas
>> appear empty in the administration menus options (like in Batch Import).
>> About this I found in the list acrhive this message:
>> "http://sourceforge.net/mailarchive/message.php?msg_id=37122276", but I
>> didn't find the solution to this issue. The another problem is when I
>> try to use the "Search" options, when I try to use it I receive this
>> error: "The requested operation could not be performed." I tried the
>> steps from this link
>> (http://geonetwork-opensource.org/documentation/error/request), but the
>> database connection in my case (Oracle) is correctly, I can perform
>> logins, create and manage users without problems.
>> About the first error when I start the GeoNetwork I receive a big
>> list with errors when they try to add the schema in the start batch. The
>> reported error is: "is not legal for a JDOM character content: 0x1c is
>> not a legal XML character".
>> Any hints how to solve these issues? Here I installed in my
>> computer, a openSuSe 10.1 (with the last updates), Java 1.5, and I use
>> the geonetwork 2.03 that I download from sourceforge with Oracle 10.2
>> version. I attached the jetty.log that contains just the log from a
>> simple the start and stop.
>> Best regards.
>> Fernando Simon
