Hi List,
Does anyone have an example of how to check whether a value from the
CodeListValue attribute exists in the codelist defined as part of a schema
plugin? The codelists are defined in the loc/eng/codelist.xml file.
Thanks
Hi List,
Thanks
Hi, you can probably do something similar to the INSPIRE theme check
https://github.com/geonetwork/core-geonetwork/blob/master/schemas/iso19139/src/main/plugin/iso19139/schematron/schematron-rules-inspire.sch#L295-L327
HTH
Francois
Le mer. 6 mars 2019 à 15:17, Sam Meek <sam.meek@anonymised.com> a écrit :
Hi List,
plugin? The codelists are defined in the loc/eng/codelist.xml file.Thanks
GeoNetwork-users mailing list
