[GeoNetwork-users] search capability with more than 100 K records
I am using the latest github code and have a strage problem to search
records from geonetwork with more than 100 K records: When my geonetwork
has 96 K records, it return 96 K records when I do the search; After I add
10 K more records and the number goes to 106K records, but it show 12965
records in the interface and CSW getrecords response ; After I delete 10 K
records and the number is 96 K records, the search works again and it
returns exact results.
I was wondering which setting I should modify to support search 100K
records.
Thanks and best regards,
Kai Liu
2013/6/17 Kai Liu <kliu.gis@anonymised.com>:
Do you have any indexing errors in the log ? Opening the index with
luke show how many records ?
Cheers.
Francois
records.
Kai Liu
This SF.net email is sponsored by Windows:
Build for Windows Store.
http://p.sf.net/sfu/windows-dev2dev
GeoNetwork-users mailing list
Hi Francois,
Thanks for your responding. The lucene size is 271M and I think it should
store more than 100K documents. I tried to use luke to read it but failed
because luke currently doesn't support lucene41. It has two kinds of
problem when building the index:
1
ERROR [geonetwork.index] - Failed to convert gml to jts object:
<gml:Polygon xmlns:gml="http://www.opengis.net/gml&quot; xmlns="
http://www.isotc211.org/2005/gmd&quot; xmlns:xlink="http://www.w3.org/1999/xlink&quot;
xmlns:srv="http://www.isotc211.org/2005/srv&quot; xmlns:fo="
http://www.w3.org/1999/XSL/Format&quot; xmlns:gsr="
http://www.isotc211.org/2005/gsr&quot; xmlns:advmis="
http://www.geodatenzentrum.de/advmis&quot; xmlns:gts="
http://www.isotc211.org/2005/gts&quot; xmlns:gmx="
http://www.isotc211.org/2005/gmx&quot; xmlns:geonet="
http://www.fao.org/geonetwork&quot; gml:id="ID-4686615730496844990" srsName="not
defined">
  <gml:exterior>
    <gml:LinearRing>
      <gml:pos>7.0332 51.6311 0.0</gml:pos>
      <gml:pos>6.9877 51.6229 0.0</gml:pos>
      <gml:pos>6.983 51.6233 0.0</gml:pos>
      <gml:pos>6.9319 51.6449 0.0</gml:pos>
      <gml:pos>6.9015 51.6354 0.0</gml:pos>
      <gml:pos>6.9009 51.6752 0.0</gml:pos>
      <gml:pos>6.941 51.7151 0.0</gml:pos>
      <gml:pos>6.9104 51.7459 0.0</gml:pos>
      <gml:pos>6.9158 51.7784 0.0</gml:pos>
      <gml:pos>6.9249 51.7772 0.0</gml:pos>
      <gml:pos>6.9561 51.772 0.0</gml:pos>
      <gml:pos>6.9778 51.7989 0.0</gml:pos>
      <gml:pos>7.0202 51.8002 0.0</gml:pos>
      <gml:pos>7.03 51.784 0.0</gml:pos>
      <gml:pos>7.0747 51.7776 0.0</gml:pos>
      <gml:pos>7.0892 51.7252 0.0</gml:pos>
      <gml:pos>7.0546 51.7107 0.0</gml:pos>
      <gml:pos>7.0531 51.6959 0.0</gml:pos>
      <gml:pos>7.023 51.6699 0.0</gml:pos>
      <gml:pos>7.0446 51.6436 0.0</gml:pos>
    </gml:LinearRing>
  </gml:exterior>
</gml:Polygon>
2.
The metadata document index with id=96533 is corrupt/invalid - ignoring it.
Error: null
java.lang.NullPointerException
        at
org.fao.geonet.kernel.search.index.LuceneIndexLanguageTracker.addDocument(LuceneIndexLanguageTracker.java:210)
        at
org.fao.geonet.kernel.search.index.LuceneIndexWriterFactory.addDocument(LuceneIndexWriterFactory.java:32)
        at
org.fao.geonet.kernel.search.SearchManager.index(SearchManager.java:690)
        at
org.fao.geonet.kernel.DataManager.indexMetadata(DataManager.java:581)
        at
org.fao.geonet.kernel.DataManager$IndexMetadataTask.run(DataManager.java:399)
        at
java.util.concurrent.ThreadPoolExecutor.runWorker(ThreadPoolExecutor.java:1145)
        at
java.util.concurrent.ThreadPoolExecutor$Worker.run(ThreadPoolExecutor.java:615)
        at java.lang.Thread.run(Thread.java:722)
I think these errors occurred when the metadata had invalid format.
However, the index mechanism should only ignore tthose invalid metadata
rather than those 90K metadata. It's very strange!
Kai Liu
On Fri, Jun 21, 2013 at 3:14 AM, Francois Prunayre <fx.prunayre@anonymised.com>wrote:
> Hi all,
add
K
Cheers.
Francois
> records.
> Kai Liu
