Hi All.
I'm sorry for the naive question but I'm a very newbie in Geonetowrk
and this is my first post!!!
I'm installed successfully the latest version of Geonetwork and all
same works fine.
My problem is the search by categories!!! If I add some dataset at
some categories, in the PostGres db the relationship between
categories and metadata is present.
But, If a search by categories, Geonetwrk return no result.... for any
categories presents in the web application. The same happen when I try
with embedded database. The dataset is assigned at the rights
categories but no result appears when a try to search by that
categories.
Any suggewstions???
Francesco D'Amore
blog: www.marinajonica.org
linkedin: http://www.linkedin.com/in/francescodamore
Hi Francesco,
This seems to be a bug that needs fixing. We are working on it.
Ciao,
Jeroen
On Jul 30, 2009, at 1:27 PM, Francesco D'Amore wrote:
Hi All.
same works fine.
categories.
Any suggewstions???
-- Francesco D'Amore
Let Crystal Reports handle the reporting - Free Crystal Reports 2008 30-Day
trial. Simplify your report design, integration and deployment - and focus on
what you do best, core application coding. Discover what's new with
Crystal Reports now. Best Open Source Mac Front-Ends 2024
GeoNetwork-users mailing list
geonetwork-users List Signup and Options
GeoNetwork OpenSource is maintained at GeoNetwork - Geographic Metadata Catalog download | SourceForge.net
Thank you..... I'm waiting for that..
Ciao.
2009/7/30 Jeroen Ticheler <Jeroen.Ticheler@anonymised.com>:
Hi Francesco,
Ciao,
Jeroen
Hi All.
same works fine.
categories.
Any suggewstions???
30-Day
on
Crystal Reports now. http://p.sf.net/sfu/bobj-july
Francesco D'Amore
Fixed :
http://trac.osgeo.org/geonetwork/ticket/139
It will be available in 2.4.1 release.
If you want to fix it on your installation apply this patch:
http://trac.osgeo.org/geonetwork/attachment/ticket/139/139.patch
Cheers.
Francois
2009/7/31 Francesco D'Amore <francesco.damore@anonymised.com>:
Ciao.
Hi Francesco,
Ciao,
Jeroen
Hi All.
same works fine.
categories.
Any suggewstions???
30-Day
on
Francesco D'Amore
Thank you!!!!
2009/7/31 Francois Prunayre <fx.prunayre@anonymised.com>:
Fixed :
Cheers.
Francois
Ciao.
Hi Francesco,
Ciao,
Jeroen
Hi All.
same works fine.
categories.
Any suggewstions???
30-Day
on
Francesco D'Amore
Francesco D'Amore
Hi All!!!
More about categories...
After the bug fixing, every things works fine about old categories
presents in original installation. But, If I try to add a new
category and I assign some dataset to category just created, the
searcher don't works.
The new category is presents in the DB. The relationship between new
category and dataset is right but, the searcher for this new category
shows nothing.....
Any suggestions about this???
Thank you!!!!
Thank you!!!!
Fixed :
Cheers.
Francois
Ciao.
Hi Francesco,
Ciao,
Jeroen
Hi All.
same works fine.
categories.
Any suggewstions???
30-Day
on
Francesco D'Amore
Francesco D'Amore
Francesco D'Amore
Hi Francesco,
Did you try to force re-indexation in the administration page ?
Mathieu
On Fri, Jul 31, 2009 at 11:57 AM, Francesco D'Amore <
francesco.damore@anonymised.com> wrote:
Hi All!!!
shows nothing.....
Thank you!!!!
> Thank you!!!!
>> Fixed :
>> Cheers.
>> Francois
>>> Ciao.
>>>> Hi Francesco,
>>>> Ciao,
>>>> Jeroen
>>>>> Hi All.
>>>>> same works fine.
any
try
>>>>> categories.
>>>>> Any suggewstions???
>>>>> 30-Day
focus
>>>>> on
>>>>> _______________________________________________
>>> Francesco D'Amore
30-Day
focus on
> Francesco D'Amore
Francesco D'Amore
on
Mathieu Coudert
Camptocamp France SAS
18 Avenue de l'Europe
31520 Ramonville Saint Agne
Tel: +33 (0)5 16 57 01 03
http://www.camptocamp.com
Yes.... I just tried to rebuild the Lucene index....
The problems persists. The custom categories that I have created don't works.
2009/7/31 Mathieu Coudert <mathieu.coudert@anonymised.com>:
Hi Francesco,
Mathieu
<francesco.damore@anonymised.com> wrote:
Hi All!!!
shows nothing.....
Thank you!!!!
> Thank you!!!!
>> Fixed :
>> Cheers.
>> Francois
>>> Ciao.
>>>> Hi Francesco,
>>>> Ciao,
>>>> Jeroen
>>>>> Hi All.
>>>>> same works fine.
>>>>> any
>>>>> try
>>>>> categories.
>>>>> Any suggewstions???
>>>>> 30-Day
>>>>> focus
>>>>> on
>>> Francesco D'Amore
>>> 30-Day
>>> focus on
> Francesco D'Amore
Francesco D'Amore
30-Day
on
Mathieu Coudert
Francesco D'Amore
But ,in yours installation does the searcher works fine for new categories??
If so... the problem may be in my custom installation.
Hi Francesco,
Mathieu
Hi All!!!
shows nothing.....
Thank you!!!!
> Thank you!!!!
>> Fixed :
>> Cheers.
>> Francois
>>> Ciao.
>>>> Hi Francesco,
>>>> Ciao,
>>>> Jeroen
>>>>> Hi All.
>>>>> same works fine.
>>>>> any
>>>>> try
>>>>> categories.
>>>>> Any suggewstions???
>>>>> 30-Day
>>>>> focus
>>>>> on
>>> Francesco D'Amore
>>> 30-Day
>>> focus on
> Francesco D'Amore
Francesco D'Amore
30-Day
on
Mathieu Coudert
Francesco D'Amore
Francesco D'Amore
It works for me. Did you read this message "Important! This form
allows you to add a Key value to the database. The key can not have
spaces.
After adding your key values, use the "Localization" form in the
Administration panel to provide the actual name you want to be
displayed on the website for the different languages." in the category
administration panel ?
What's the name of your category ?
HTH. Francois
Hi Francesco,
Mathieu
Hi All!!!
shows nothing.....
Thank you!!!!
> Thank you!!!!
>> Fixed :
>> Cheers.
>> Francois
>>> Ciao.
>>>> Hi Francesco,
>>>> Ciao,
>>>> Jeroen
>>>>> Hi All.
>>>>> same works fine.
>>>>> any
>>>>> try
>>>>> categories.
>>>>> Any suggewstions???
>>>>> 30-Day
>>>>> focus
>>>>> on
>>> Francesco D'Amore
>>> 30-Day
>>> focus on
> Francesco D'Amore
Francesco D'Amore
30-Day
on
Mathieu Coudert
Francesco D'Amore
Francesco D'Amore
mmmm
The name was wrong. I'm sorry for that.
Now, it works!!!
Thank you.
spaces.
HTH. Francois
Hi Francesco,
Mathieu
Hi All!!!
shows nothing.....
Thank you!!!!
> Thank you!!!!
>> Fixed :
>> Cheers.
>> Francois
>>> Ciao.
>>>> Hi Francesco,
>>>> Ciao,
>>>> Jeroen
>>>>> Hi All.
>>>>> same works fine.
>>>>> any
>>>>> try
>>>>> categories.
>>>>> Any suggewstions???
>>>>> 30-Day
>>>>> focus
>>>>> on
>>> Francesco D'Amore
>>> 30-Day
>>> focus on
> Francesco D'Amore
Francesco D'Amore
30-Day
on
Mathieu Coudert
Francesco D'Amore
Francesco D'Amore
Francesco D'Amore
