Yes, I will put it in my TODO list
But first of all, I will create a ticket, maybe (surely) someone will be faster than I to implement that feature.
Le 24/07/12 20:22, heikki a écrit :
It wouldn't be rocket-science to make a slight modification so the result of 'main.home' would, on document load, check for URL params and then automatically launch the search. I think that would be a nice addition to the GN code base. Want to contribute ?
On Wed, Jul 25, 2012 at 2:06 AM, Sylvain Lesage <severo@anonymised.com <mailto:severo@anonymised.com>> wrote:
OK. Thanks a lot!
Le 24/07/12 20:05, heikki a écrit :
> I'm afraid not, without making changes to GeoNetwork -- you get that
> general interface only if you use 'main.home' in your URL, but that
> doesn't execute the search. From the general interface the search is
> done through an Ajax call that puts these results next to that left
> side with the search form ..
> On Wed, Jul 25, 2012 at 1:52 AM, Sylvain Lesage
> Perfect, thanks...
> Well, only one other question: isn't it possible to see the
general
> interface, with the search form on the left side, instead of
only the
> results ?
> Le 24/07/12 19:41, heikki a écrit :
> > hi Sylvain,
> > a correct URL for that in a standard installation on
localhost would
> > be
http://localhost:8080/geonetwork/srv/en/main.search?any=‘africa’&sortBy='relevance
<http://localhost:8080/geonetwork/srv/en/main.search?any=‘africa’&sortBy='relevance>
> <http://localhost:8080/geonetwork/srv/en/main.search?any=‘africa’&sortBy='relevance>'
> <http://localhost:8080/geonetwork/srv/eng/main.search?any=‘africa’&sortBy=‘relevance’>
> > This should work OK if you didn't change default port and web
> > application name.
> > Does it ?
> > Kind regards
> > Heikki Doeleman
> > On Wed, Jul 25, 2012 at 1:09 AM, Sylvain Lesage
<mailto:severo@anonymised.com>>> wrote:
> > Hi,
> > I didn't find in GeoNetwork documentation how to
specify search
> > parameters to GeoNetwork via URL, in the following style
> (taking the
> > example from
http://geonetwork-opensource.org/latest/developers/xml_services/metadata_xml_services.html#search-metadata-xml-search):
http://localhost/geonetwork/srv/en/search?any=‘africa’&sortBy='relevance
<http://localhost/geonetwork/srv/en/search?any=‘africa’&sortBy='relevance>
> <http://localhost/geonetwork/srv/en/search?any=‘africa’&sortBy='relevance>'
> > and get the results page in GeoNetwork ?
> > I mean, automatize the manual process of entering search
> > parameters and
> > click the search Button, using URL parameters.
> > The reason is I want, from a form in another website, to
> send to the
> > results in GeoNetwork.
> > Is it possible to this in GeoNetwork ?
> > Thanks
> > Severo
> > Live Security Virtual Conference
> > Exclusive live event will cover all the ways today's
> security and
> > threat landscape has changed and how IT managers can
respond.
> > Discussions
> > will include endpoint security, mobile security and the
> latest in
> > malware
> > threats.
> http://www.accelacomm.com/jaw/sfrnl04242012/114/50122263/
> > _______________________________________________
> > GeoNetwork-users mailing list
> > GeoNetwork-users@lists.sourceforge.net
<mailto:GeoNetwork-users@lists.sourceforge.net>
<mailto:GeoNetwork-users@lists.sourceforge.net>>
<mailto:GeoNetwork-users@lists.sourceforge.net>>>
> > https://lists.sourceforge.net/lists/listinfo/geonetwork-users
> > GeoNetwork OpenSource is maintained at
> > http://sourceforge.net/projects/geonetwork
security and
> threat landscape has changed and how IT managers can respond.
> Discussions
latest in
> malware
> threats.
Exclusive live event will cover all the ways today's security and
Discussions
will include endpoint security, mobile security and the latest in
malware
threats. http://www.accelacomm.com/jaw/sfrnl04242012/114/50122263/
