Hi Andrea, search on protocol allow user to search on data available for
download or using WMS. Protocols to search on are located in template named
online and download in lucene.xsl.
Blocks uncommented were in lucene.xsl
<xsl:when test="string(/request/online)='on' and
string(/request/download)='on'"> ...
In iso19115.xsl : line 51 <xsl:apply-templates
select="/Metadata/distInfo/distTranOps/onLineSrc/protocol"/>
That was implemented in GeoNetwork 1 and maybe turned off for version2. Any
reasons ?
Francois.
-----Message d'origine-----
De : geonetwork-users-admin@lists.sourceforge.net
[mailto:geonetwork-users-admin@lists.sourceforge.net] De la part de Andrea
Carboni
Envoyé : vendredi 19 mai 2006 16:49
À : geonetwork-users@lists.sourceforge.net
Objet : Re: [GeoNetwork-users] Search on Protocol
Hi Francois,
can you clarify what you are talking about? The only 'protocol' I see is
located into the xml/search/lucene.xsl file: there is not a searchable
field named 'protocol'.
One question to the list, why the search on protocol has been switched
off in the lucene index ?
If I turn it on for iso, I could search for all metadata available for
download or having WMS available ... That's useful.
Thanks.
Francois
Using Tomcat but need to do more? Need to support web services, security?
Get stuff done quickly with pre-integrated technology to make your job
easier Download IBM WebSphere Application Server v.1.0.1 based on Apache
Geronimo
http://sel.as-us.falkag.net/sel?cmd=lnk&kid=120709&bid=263057&dat=121642
GeoNetwork-users mailing list
Ce message a ete verifie par MailScanner pour des virus ou des polluriels et
rien de suspect n'a ete trouve.
Les donnees et renseignements contenus dans ce message sont personnels,
confidentiels et prives. Toute publication, utilisation ou diffusion, meme
partielle, doit etre autorisee.
Any data and information contained in this electronic mail is personal,
confidential and secret. Any total or partial publication, use or
distribution must be authorized.
Ce message a ete verifie par MailScanner pour des virus ou des polluriels et rien de suspect n'a ete trouve.
Les donnees et renseignements contenus dans ce message sont personnels, confidentiels et prives. Toute publication, utilisation ou diffusion, meme partielle, doit etre autorisee.
Any data and information contained in this electronic mail is personal, confidential and secret. Any total or partial publication, use or distribution must be authorized.
