[GeoNetwork-users] search results
Hi all
I created a schema called iso19139.mim (MIM stands for Model Instance Metadata)
This includes amongst other things elements
            <mim:inputs>
                        <mim:input>
                        <mim:input>
            <mim:outputs>
                        <mim:output>
                        <mim:output>
These appear fine - and properly structured - in the ISOAll and Content Info views in the Administration -> My metadata view.
But the nested data structure is not shown on the search results page - this only shows the content of each <input> and <output> element but not enclosed in the input/output hierarchical structure.
Can anyone tell me - in simple terms because I am a bear of very little brain - what I need to do to change the search results view so it shows:
Inputs
            input
            input
Outputs
            output
            output
I hope this makes sense :-}
Or perhaps you know someone who can help? Or whoever wrote the documentation?
Many thanks
in desperate hope
Paul
Paul Cleverley
Software Developer, Hydrodynamics & Metocean
E: p.cleverley@anonymised.com<mailto:p.cleverley@anonymised.com>
T: +44 (0)1491 822483
<http://www.hrwallingford.com/banner.html&gt;
[HR Wallingford Logo]
HR Wallingford
Howbery Park, Wallingford, Oxfordshire OX10 8BA, United Kingdom
T: +44 (0)1491 835381 F: +44 (0)1491 832233
[HR Wallingford Secondary Logo]
HR Wallingford and its subsidiaries uses faxes and emails for confidential and legally privileged business communications. They do not of themselves create legal commitments. Disclosure to parties other than addressees requires our specific consent. We are not liable for unauthorised disclosures nor reliance upon them.
If you have received this message in error please advise us immediately and destroy all copies of it.
HR Wallingford Limited
Howbery Park, Wallingford, Oxfordshire, OX10 8BA, United Kingdom
Registered in England No. 02562099
Hi Paul
Some comments inline.
Jose García
On Fri, Jul 18, 2014 at 10:24 AM, Paul Cleverley <
P.Cleverley@anonymised.com> wrote:
Hi all
Metadata)
            <mim:inputs>
                        <mim:input>
                        <mim:input>
            <mim:outputs>
                        <mim:output>
                        <mim:output>
Can you provide the changes done to display these elements, to check?
Inputs
            input
            input
Outputs
            output
            output
Depends on which UI you're using, for the classic one (no ExtJs), afaik the
search results uses the brief mode. In your metadata you should have a
brief template that most probably delegates to the iso19139 brief mode and
does some additional stuff you probably added. Check that the brief
template, returns the inputs and outputs elements, so can be used in the
search results.
documentation?
Many thanks
in desperate hope
Paul
Paul Cleverley
HR Wallingford
Want fast and easy access to all the code in your enterprise? Index and
search up to 200,000 lines of code with a free copy of Black Duck
Code Sight - the same software that powers the world's largest code
search on Ohloh, the Black Duck Open Hub! Try it now.
http://p.sf.net/sfu/bds
GeoNetwork-users mailing list
* GeoCat Bridge for ArcGIS allows instant publishing of data and metadata
on GeoServer and GeoNetwork. Visit http://geocat.net
<http://geocat.net/&gt; for details. _________________________Jose
GarcíaGeoCat bvVeenderweg 13 6721 WD BennekomThe
Netherlandshttp://GeoCat.net/> *
