Dear all,
After I install and run Geonetwork 2.4.2 successfully, I used batch import
tool to import some 600 metadata records. Before I import, I deleted all
built-in categories and added 2 new categories. When I do the batch import I
set one of the new categories I created to the 'Category' field. After the
batch import I checked the category of some of the metadata records and they
all set to the same category.
However, when I click on the category at the left hand side of the
application window (under "CATEGORIES"), it doesn't bring any searched
result, although all 600 metadata records are set to the selected category.
I also tried to search using the Advanced option by selecting a value for
the Category field but the search result brings nothing.
If anyone face the same problem and was able to solve it, I wish to get your
help.
Girum.
