[GeoNetwork-users] servername configuration and interactive map function [SEC=UNCLASSIFIED]
Hello list
Just wondering if there is an authoritative list of files to modify to
move from a localhost installation to a servername installation of GN
2.6?
I have found that following the procedure from the User Guide
http://geonetwork-opensource.org/stable/users/admin/configuration/index.
html#system-configuration below will NOT allow viewing
http://servername:port/geonetwork, though localhost still works i.e.
does not change config:
            Run basic installation
            Login to localhost as admin
            In system configuration change localhost to servername
            Logout
            Restart GN
To obtain successful display at http://servername:port/geonetwork I need
to modify a number of config files. Including config.xml, jetty.xml,
config-gui.xml. Currently I don't think this is specified in the
userguide.
Interactive Map Function.
I have WMS transfer options populated within my metadata. The
Interactive map button is enabled in records containing this transfer
option. After clicking the Interactive Map button - Map Viewer displays
and the WMS layer is added to the overlays however the layer does not
display. If I use the Add layer function in Map Viewer I can get the
layer to display. Has anyone else had this problem?
The link metadata looks ok - see below example.
- <http://localhost:8080/geonetwork/srv/en/iso19139.xml?id=1#\#&gt;
<gmd:onLine>
  <gmd:CI_OnlineResource>
    <gmd:linkage>
<gmd:URL>http://pandora.internal.govt:81/ecwp/ecw_wms.dll?Request=GetCap
abilities</gmd:URL>
    </gmd:linkage>
    <gmd:protocol>
<gco:CharacterString>OGC:WMS-1.1.1-http-get-map</gco:CharacterString>
    </gmd:protocol>
    <gmd:name>
<gco:CharacterString>CONTINENTAL_BIL_04808_07.ERS_BAND123457.TIF.CMP.JP2
    </gmd:name>
    <gmd:description>
      <gco:CharacterString>Image Web Server Web Map
Service</gco:CharacterString>
    </gmd:description>
    <gmd:function>
      <gmd:CI_OnLineFunctionCode
codeList="http://www.isotc211.org/2005/resources/codeList.xml#CI_OnLineF
unctionCode
<http://www.isotc211.org/2005/resources/codeList.xml#CI_OnLineFunctionCo
de> " codeListValue="download" />
    </gmd:function>
  </gmd:CI_OnlineResource>
</gmd:onLine>
If there is a fix for this please let me know - it's a great bit of
functionality I'd like.
Thanks list!
Regards
Simon
If you have received this transmission in error please notify us immediately by return e-mail and delete all copies. If this e-mail or any attachments have been sent to you in error, that error does not constitute waiver of any confidentiality, privilege or copyright in respect of information in the e-mail or attachments.
Please consider the environment before printing this email.
