[GeoNetwork-users] service metadata
Hey all!
Question. I have a 'special kind of metadata' - service metadata. Where
metadata extent is not defined using gmd:extent but with srv:extent and when
i view this metadata (inspire view) the extent does not show up (it says
extent data is missing). So how can i enable this 'service metadata'
metadata type.
View this message in context: http://osgeo-org.1803224.n2.nabble.com/service-metadata-tp5942872p5942872.html
Hello,
2011/1/20 GeoUser <blazrepnik@anonymised.com>:
Hey all!
metadata type.
Extent for service metadata is conditional regarding INSPIRE IR but it
could be good to display it if it exists. Schematron does not report
error if a service metadata doest not have an extent.
I've updated the view to display it.
Update metadata-iso19139-inspire.xsl files line 245 and 262
@@ -245,7 +245,7 @@
select="generate-id(/root/gui/strings/inspireSection/geoloc/title)" />
                               <xsl:with-param name="content">
- <xsl:for-each
select="gmd:extent/gmd:EX_Extent">
+ <xsl:for-each
select="*:extent/gmd:EX_Extent">
                                               <xsl:apply-templates
mode="complexElement"
                                                       select="
gmd:description|gmd:geographicElement|gmd:verticalElement
@@ -262,7 +262,7 @@
                                               </xsl:apply-templates>
                                       </xsl:for-each>
- <xsl:if test="not(gmd:extent)">
+ <xsl:if test="not(*:extent)">
HTH.
Francois
Protect Your Site and Customers from Malware Attacks
Learn about various malware tactics and how to avoid them. Understand
malware threats, the impact they can have on your business, and how you
can protect your company and customers by using code signing.
http://p.sf.net/sfu/oracle-sfdevnl
GeoNetwork-users mailing list
thanks a lot, i will integrate this into 2.6.2
View this message in context: http://osgeo-org.1803224.n2.nabble.com/service-metadata-tp5942872p5954429.html
another question, why does XSL transformer generate soooooo many <p></p>
(empty) elements? If i look at the XSLT result (before it gets dispatched) i
see this:
[Element: <td/>]: [Attribute: class="padded"], [Attribute: valign="top"],
[Element: <p/>]:
[Element: <p/>]:
[Element: <p/>]:
[Element: <p/>]:
[Element: <p/>]:
[Element: <p/>]:
[Element: <p/>]:
[Element: <p/>]:
[Element: <p/>]:
[Element: <p/>]:
[Element: <p/>]:
[Element: <p/>]:
[Element: <p/>]:
[Element: <p/>]:
[Element: <p/>]:
[Element: <p/>]:
[Element: <p/>]:
[Element: <p/>]:
[Element: <p/>]:
[Element: <p/>]:
[Element: <p/>]:
[Element: <p/>]:
[Element: <p/>]:
[Element: <p/>]:
[Element: <p/>]:
[Element: <p/>]:
[Element: <p/>]:
[Element: <p/>]:
[Element: <p/>]:
[Element: <p/>]:
[Element: <p/>]:
[Element: <p/>]:
[Element: <p/>]:
[Element: <p/>]:
[Element: <p/>]:
[Element: <p/>]:
[Element: <p/>]:
[Element: <p/>]:
[Element: <p/>]:
[Element: <p/>]:
[Element: <p/>]:
[Element: <p/>]:
[Element: <p/>]:
[Element: <p/>]:
[Element: <p/>]:
[Element: ]: [Attribute: style="font-weight:bolder;"], [Attribute:
href="mailto: name@anonymised.com "],
[Element: <p/>]:
[Element: <p/>]:
[Element: <p/>]:
[Element: <p/>]:
[Element: <p/>]:
[Element: <p/>]:
[Element: <p/>]:
[Element: <p/>]:
[Element: <p/>]:
[Element: <p/>]:
[Element: <p/>]:
[Element: <p/>]:
[Element: <p/>]:
[Element: <p/>]:
[Element: <p/>]:
[Element: <p/>]:
And this creates a very ugly webpage with many empty lines between text
lines. I've checked the metadata XML and it does not contain any weird
characters.
This all happens when viewing metadata in inspire view (or edit) in the
Coupling Type section of the view.
View this message in context: http://osgeo-org.1803224.n2.nabble.com/service-metadata-tp5942872p5958549.html
