Thank you Jose it works!
Actually in my module.js I was missing this part:
} else {
// If no match set default to categories
$scope.browse = 'categories';
Thanks again
Da: Jose Garcia <jose.garcia@anonymised.com>
Inviato: mercoledì 11 luglio 2018 12:36
A: Eugenio Trumpy
Cc: Geonetwork-Users@anonymised.com
Oggetto: Re: [GeoNetwork-users] set default browse mode
Hi Eugenio
Sorry, I misunderstood your requirement. The related code is this: https://github.com/geonetwork/core-geonetwork/blob/3.2.x/web-ui/src/main/resources/catalog/views/default/module.js#L209-L219
[https://avatars3.githubusercontent.com/u/1842442?s=400&v=4]<https://github.com/geonetwork/core-geonetwork/blob/3.2.x/web-ui/src/main/resources/catalog/views/default/module.js#L209-L219>
geonetwork/core-geonetwork<https://github.com/geonetwork/core-geonetwork/blob/3.2.x/web-ui/src/main/resources/catalog/views/default/module.js#L209-L219>
github.com
core-geonetwork - GeoNetwork repository
I think this change should work
// Set the default browse mode for the home page
$scope.$watch('searchInfo', function (n, o) {
if (angular.isDefined($scope.searchInfo.facet)) {
if ($scope.searchInfo.facet['categories'].length > 0) {
$scope.browse = 'cat';
} else if ($scope.searchInfo.facet['inspireThemes'].length > 0) {
$scope.browse = 'inspire';
} else if ($scope.searchInfo.facet['topicCats'].length > 0) {
$scope.browse = 'topics';
} else {
Assuming in home.html you have something like this for the categories.
<label data-ng-show="searchInfo.facet['categories'].length > 0">
<input type="radio" name="browse" value="cat" data-ng-model="browse"/>
<span data-translate="">categories</span>
</label>
Make sure to clean your browser cache and also the wro4j cache.
Jose García
On Wed, Jul 11, 2018 at 12:21 PM, Eugenio Trumpy <frippe12573@anonymised.com<mailto:frippe12573@anonymised.com>> wrote:
Dear Josè and all,
I have already tried to change the order of the radio buttons,
but it doesn't change the default radio button.
I tested also to change the content of the ['facet name'] putting the categories in the first radio button,
but nothing changed.
I didn't want to move the section in another place, just put categories (I mean the GN categories, not the topic categories) as default.
Any other input is very appreciated.
Eugenio
Da: Jose Garcia <jose.garcia@anonymised.com<mailto:jose.garcia@anonymised.com>>
Inviato: mercoledì 11 luglio 2018 12:13
A: frippe12573
Cc: Geonetwork-Users@anonymised.com<mailto:Geonetwork-Users@anonymised.com>
Hi
The html code to display the radio buttons for browse by topic categories and inspire themes is the following:
https://github.com/geonetwork/core-geonetwork/blob/3.2.x/web-ui/src/main/resources/catalog/views/default/templates/home.html#L37
Not sure what change you require. If it's just the order of the radio buttons, you can check to update that snippet (see input type="radio" elements to reorder them) or if you need to move the full section to other page location, I guess can be copied all related code that handles that section to a new location, but requires to be tested.
Jose García
On Wed, Jul 11, 2018 at 9:35 AM, frippe12573 <frippe12573@anonymised.com<mailto:frippe12573@anonymised.com>> wrote:
in GN3.2 I would like to modify a bit the home page.
I have already added categories to the radio button
related to 'Browse by'. I would like to change the default
position of the radio button.
I say in module.js some lines related to this aspect,
but I don't understand how to change the code to
have the wanted effect.
Could you give me an hint?
Best
Eugenio
Sent from: http://osgeo-org.1560.x6.nabble.com/GeoNetwork-users-f3860293.html
Check out the vibrant tech community on one of the world's most
GeoNetwork-users mailing list
GeoNetwork-users@lists.sourceforge.net<mailto:GeoNetwork-users@anonymised.comforge.net>
Vriendelijke groeten / Kind regards,
Jose García
[https://www.geocat.net/wp-content/uploads/2015/07/GeoCat_small1.png\]<http://www.geocat.net/>
Veenderweg 13<https://maps.google.com/?q=Veenderweg+13+
+6721+WD+Bennekom+
+The+Netherlands&entry=gmail&source=g>
6721 WD Bennekom<https://maps.google.com/?q=Veenderweg+13+
+6721+WD+Bennekom+
The Netherlands<https://maps.google.com/?q=Veenderweg+13+
+6721+WD+Bennekom+
T: +31 (0)318 416664<tel:+31318416664>
[https://www.geocat.net/wp-content/uploads/2015/07/facebook_24.png\]<https://www.facebook.com/geocatbv> [https://www.geocat.net/wp-content/uploads/2015/07/Twitter_icon.png\] <https://twitter.com/geocat_bv> [https://www.geocat.net/wp-content/uploads/2015/07/Google-plus-icon.png\] <https://plus.google.com/u/1/+GeocatNetbv/posts>
Please consider the environment before printing this email.
Jose García
Veenderweg 13
6721 WD Bennekom
The Netherlands
