[GeoNetwork-users] Set default outputSchema for GetRecordsByIdResponse [GeoNetwork 3.6.0]
Hi everyone!
I just stumbled on a problem while replacing another CSW with the GeoNetwork CSW. There are heaps of links to the CSW responses, that need the correct format and don't work as expected anymore.
I need the response for a request with parameters like "?service=CSW&version=2.0.2&request=GetRecordById&Id=[UUID]&ElementSetName=full" to be as if the parameter "&outputSchema=http://www.isotc211.org/2005/gmd" was appended by default. I can't find the option to set the default CSW outputSchema.
Might it be possible to set it in the geonetwork/WEB-INF/config-csw.xml ?
Thanks in advance and best regards
Sven
Mit freundlichen Grüßen
Sven van Crombrugge
[cid:image001.jpg@anonymised.com]
Sachgebiet 3.3 - Geoinformationssysteme, E-Government -
- Zentrale -
Von der Heydt 22 . 66115 Saarbrücken
Tel.: +49 (0) 681 9712-303 · Fax: +49 (0) 681 9712-200
S.vanCrombrugge@anonymised.com<mailto:%3Ca%20href=%22mailto:%22%3ES.vanCrombrugge@anonymised.com%3C/a%3E> · www.lvgl.saarland.de<http://www.lvgl.saarland.de>
[cid:image003.jpg@anonymised.com]
(attachments)
Hi Sven
According to the CSW 2.0.2 specification, the outputSchema is optional and
the default is for Dublin Core format (http://www.opengis.
net/cat/csw/2.0.2).
Afaik, that's not configurable in GeoNetwork, if you need other
outputSchema you need to provide it in the parameters of the request.
Jose García
On Tue, May 28, 2019 at 7:32 PM van Crombrugge, Sven (LVGL) <
S.vanCrombrugge@anonymised.com> wrote:
Hi everyone!
to be as if the parameter "&outputSchema=http://www.isotc211.org/2005/gmd&quot;
outputSchema.
Sven
Sven van Crombrugge
- Zentrale -
GeoNetwork-users mailing list
*Vriendelijke groeten / Kind regards,Jose García
<http://www.geocat.net/&gt;Veenderweg 136721 WD BennekomThe NetherlandsT: +31
(0)318 416664 <+31318416664> <https://www.facebook.com/geocatbv&gt;
<https://twitter.com/geocat_bv&gt;
<https://plus.google.com/u/1/+GeocatNetbv/posts&gt;Please consider the
environment before printing this email.*
