Hi!
I'm using the geonetwork 3.4.3 docker image and trying to increase the maxUploadSize from 100MB to something bigger. I try to follow the instructions in [1].
Problem: Inside the container in /usr/local/tomcat/webapps/geonetwork/WEB-INF/config-spring-geonetwork.xml there is no "maxUploadSize" parameter if I see that correctly.
The only thing I find is in in /usr/local/tomcat/webapps/geonetwork/WEB-INF/config.xml there is a "<maxUploadSize>100</maxUploadSize>". But increasing that does not help.
Any ideas what I do wrong?
Grmpfhmbl
Hi
The file where is defined is
https://github.com/geonetwork/core-geonetwork/blob/3.4.x/services/src/main/resources/config-spring-geonetwork.xml#L63-L66,
but that's build inside the services jar, so not easy to change unless
rebuilding GeoNetwork.
This should be improved, probably to be moved geonetwork/WEB-INF/
config-spring-geonetwork.xml or making it configurable in the UI. There's
an open issue related to this:
https://github.com/geonetwork/core-geonetwork/issues/2030
The other setting in config.xml is for the old Jeeves services, probably
kept in case any legacy service is still used.
Jose García
On Mon, Aug 13, 2018 at 7:40 PM, Steffen Reichel <grmpfhmbl@anonymised.com>
wrote:
Hi!
not help.
Grmpfhmbl
Check out the vibrant tech community on one of the world's most
GeoNetwork-users mailing list
GeoNetwork OpenSource is maintained at http://sourceforge.net/project
s/geonetwork
*Vriendelijke groeten / Kind regards,Jose García
<http://www.geocat.net/>Veenderweg 136721 WD BennekomThe NetherlandsT: +31
(0)318 416664 <+31318416664> <https://www.facebook.com/geocatbv>
<https://twitter.com/geocat_bv>
<https://plus.google.com/u/1/+GeocatNetbv/posts>Please consider the
environment before printing this email.*
Hi Jose,
thank you for you answer. That helped a lot! So what I did now was:
extracting config-spring-geonetwork.xml from the services jar
setting the upload size
packing it back into the jar
That is not a nice solution, but it can be automated, works for now and gives the desired result.
Steffen
On 16.08.18 09:23, Jose Garcia wrote:
Hi
The file where is defined is https://github.com/geonetwork/core-geonetwork/blob/3.4.x/services/src/main/resources/config-spring-geonetwork.xml#L63-L66, but that's build inside the services jar, so not easy to change unless rebuilding GeoNetwork.
This should be improved, probably to be moved geonetwork/WEB-INF/config-spring-geonetwork.xml or making it configurable in the UI. There's an open issue related to this: https://github.com/geonetwork/core-geonetwork/issues/2030
The other setting in config.xml is for the old Jeeves services, probably kept in case any legacy service is still used.
Jose García
On Mon, Aug 13, 2018 at 7:40 PM, Steffen Reichel <grmpfhmbl@anonymised.com <mailto:grmpfhmbl@anonymised.com>> wrote:
Hi!
Grmpfhmbl
