I'm pretty new to GeoNetwork and still trying to get my head around the
services and the design arcitecute.
As I understand, GeoNetwork saves metadata records or updates them even if
the mandatory fields are empty. I also read in dev documentation there is a
parameter called 'validate' which is set to off by default. I'd like to
change this default behaviour and do not let the user saves/updates records
if the metadata does not satifty validation rules. Is there any way to set
the parameter 'validate' for all of the updates and inserts services?
I would appreciate if someone please answer my question considering I'm not
so familiar with the environment.
Seb
