We would like to zoom in and center the search maps on a specific country
(NZ) by default without disabling pan.
This question has been raised a few times and we have tried the various
changes suggested with no luck.
We are on GN v2.10.2 and are using the HTML5UI.
Any help much appreciated.
Many Thanks
View this message in context: http://osgeo-org.1560.x6.nabble.com/Setting-search-maps-default-zoom-and-center-GN-v2-10-2-HTML5UI-tp5101963.html
shireeb
2
Help please I am going around in circles.
We are using OSM based maps.
I have tried (in debug mode, so that the non minified files are used) adding
a center and zoom to:
MAP_OPTIONS and MAIN_MAP_OPTIONS
https://github.com/geonetwork/core-geonetwork/blob/2.10.x/web-client/src/main/resources/apps/html5ui/js/map/Settings.js#L73&L89
center : new
OpenLayers.LonLat(174.55,-41.10).transform("EPSG:4326","EPSG:900913")
And to the:
generateMaps function
https://github.com/geonetwork/core-geonetwork/blob/2.10.x/web-client/src/main/resources/apps/html5ui/js/map/MapApp.js#L72
and #L142 (may not be the right place?)
center: GeoNetwork.map.MAIN_MAP_OPTIONS.center.clone()
center: GeoNetwork.map.MAP_OPTIONS.center.clone()
I have also played around with disabling the restrictedExtent and setting
wrapDateLine to true.
Nothing has worked. Any suggestions very welcomed.
Many Thanks for your help
View this message in context: http://osgeo-org.1560.x6.nabble.com/Setting-search-maps-default-zoom-and-center-GN-v2-10-2-HTML5UI-tp5101963p5105688.html
To reply to my own post for anyone looking to do a similar thing. Note may
not be the best way to achieve but does work.
Centering search map:
Add /center: new
OpenLayers.LonLat(174.55,-41.10).transform("EPSG:4326","EPSG:900913"),
zoom : 4,/ to var geomWithMapField in SearchApp.js
(https://github.com/geonetwork/core-geonetwork/blob/2.10.x/web-client/src/main/resources/apps/html5ui/js/search/SearchApp.js#L293)
Also comment out MAP_OPTIONS restrictedExtent in Settings.js
Centering metadata view and edit mode map:
Add /center: new
OpenLayers.LonLat(174.55,-41.10).transform("EPSG:4326","EPSG:900913"),/ to
createMap options in ExtentMap.js
(https://github.com/geonetwork/core-geonetwork/blob/2.10.x/web-client/src/main/resources/apps/js/GeoNetwork/lib/GeoNetwork/map/ExtentMap.js#L118)
And also comment out the /restrictedExtent/
Regards
View this message in context: http://osgeo-org.1560.x6.nabble.com/Setting-search-maps-default-zoom-and-center-GN-v2-10-2-HTML5UI-tp5101963p5136805.html
Thanks for this shireeb. I will try this solution as we face the same
problem.
Byron
View this message in context: http://osgeo-org.1560.x6.nabble.com/Setting-search-maps-default-zoom-and-center-GN-v2-10-2-HTML5UI-tp5101963p5140186.html
