[GeoNetwork-users] Setup issue with GeoNetwork on Windows
Hi everybody.
I am new to GeoNetwork and have a problem I hope you can help me with. I
have installed version 2.10.1 using the geonetwork-install-2.10.1-0.exe
file on my locale windows 7 machine.
Then I have created a new database on my locale PostgreSQL installation
using the the script that creates the tables
(web\geonetwork\WEB-INF\classes\setup\sql\create\create-db-postgres.sql)
and all the scripts that inserts the data
(web\geonetwork\WEB-INF\classes\setup\sql\data\). After setting up the
database I have used GAST to change the database to use my new
PostgreSQL database.
I can start GeoNetwork, log in with the admin user, create a new user
which is stored in the users table on my PostgreSQL database.
But when I push the New metadata button I get the following error in the
GUI:
The requested operation could not be performed.
TransformerConfigurationException : Failed to compile stylesheet. 1
error detected.
A more detailed error description from the console-log:
2013-10-24 10:45:31,462 INFO [jeeves.request] - HTML Request (from
0:0:0:0:0:0:0:1) : /geonetwork/srv/eng/search
2013-10-24 10:45:31,463 INFO [jeeves.service] - Dispatching : search
2013-10-24 10:45:31,463 INFO [jeeves.service] - -> dispatching to
output for : search
2013-10-24 10:45:31,567 INFO [jeeves.webapp.search] - Creating default
metadata tab
2013-10-24 10:45:31,653 INFO [jeeves.service] - -> transforming
with stylesheet : C:\Program Files\geonetwork
2.10.1\web\geonetwork\xsl/search.xsl
Error at xsl:call-template on line 12 column 41 of common.xsl:
XTSE0650: No template exists named getLangId
2013-10-24 10:45:31,842 ERROR [jeeves.service] - -> exception during
transformation for : search
2013-10-24 10:45:31,843 ERROR [jeeves.service] - -> (C) stylesheet :
C:\Program Files\geonetwork 2.10.1\web\geonetwork\xsl/search.xsl
2013-10-24 10:45:31,843 ERROR [jeeves.service] - -> (C) message :
Failedto compile stylesheet. 1 error detected.
2013-10-24 10:45:31,843 ERROR [jeeves.service] - -> (C) exception :
2013-10-24 10:45:31,844 INFO [jeeves.service] - -> dispatching to
error for: search
2013-10-24 10:45:32,026 INFO [jeeves.service] - -> transforming
2.10.1\web\geonetwork\xsl/error.xsl
2013-10-24 10:45:32,139 INFO [jeeves.service] - -> end error
2013-10-24 10:45:32,140 INFO [jeeves.service] - -> error ended for :
search
I can see that there is no template exists named getLangId but does that
mean that I am missing some language file or rows in my database?
How do I get my GeoNetwork installation working?
Have anybody experienced this error and know what the solution is.
All comments or guidance would be appreciated.
Regards Esben
Hi Esben
Please install GeoNetwork outside of Program Files folder. I think we
should add in the manual, as this is a typical issue when setting up
GeoNetwork in Windows.
Jose García
On Thu, Oct 24, 2013 at 11:09 AM, Esben Taudorf <eta@anonymised.com> wrote:
Hi everybody.
GUI:
error detected.
output for : search
metadata tab
error for: search
search
Regards Esben
October Webinars: Code for Performance
Free Intel webinars can help you accelerate application performance.
Explore tips for MPI, OpenMP, advanced profiling, and more. Get the most
from
the latest Intel processors and coprocessors. See abstracts and register >
http://pubads.g.doubleclick.net/gampad/clk?id=60135991&iu=/4140/ostg.clktrk
GeoNetwork-users mailing list
GeoCat Bridge for ArcGIS allows instant publishing of data and metadata on
GeoServer and GeoNetwork. Visit http://geocat.net for details.
_________________________
Jose García
GeoCat bv
Veenderweg 13
6721 WD Bennekom
The Netherlands
http://GeoCat.net/&gt;
Hi Jose
I have installed GeoNetwork outside the Program Files folder and that solved my problem. Thanks a lot.
I think that your suggestion of adding it to the manual is a very good idea since the program files folder is the default folder when installing GeoNetowork on a windows machine.
Regards Esben
Fra: Jose Garcia [mailto:jose.garcia@…444…]
Sendt: 24. oktober 2013 11:25
Til: Esben Taudorf
Cc: geonetwork-users@lists.sourceforge.net
Emne: Re: [GeoNetwork-users] Setup issue with GeoNetwork on Windows
Hi Esben
Please install GeoNetwork outside of Program Files folder. I think we should add in the manual, as this is a typical issue when setting up GeoNetwork in Windows.
Jose García
On Thu, Oct 24, 2013 at 11:09 AM, Esben Taudorf <eta@...1275...> wrote:
Hi everybody.
GUI:
error detected.
output for : search
metadata tab
error for: search
search
Regards Esben
Explore tips for MPI, OpenMP, advanced profiling, and more. Get the most from
GeoCat Bridge for ArcGIS allows instant publishing of data and metadata on GeoServer and GeoNetwork. Visit http://geocat.net/&gt; for details.
Jose García
GeoCat bv
Veenderweg 13
6721 WD Bennekom
The Netherlands
2013/10/24 Esben Taudorf <eta@anonymised.com>
Hi Jose
BTW, at some point, we need to have it fixed. I had a look but not 100%
sure of the fix. See
https://github.com/geonetwork/core-geonetwork/pull/135 If anyone could
double check it on windows, that would be great.
Cheers.
Francois
Regards Esben
Fra: Jose Garcia [mailto:jose.garcia@anonymised.com]
Til: Esben Taudorf
Hi Esben
Jose García
Hi everybody.
GUI:
error detected.
output for : search
metadata tab
error for: search
search
Regards Esben
from
for details.
Jose García
GeoCat bv
Veenderweg 13
6721 WD Bennekom
The Netherlands
from
It is a problem that exists for a decade or so I think :slight_smile: I at least updated the manual to warn people to not install in c:\program files
Obviously it is better to fix it altogether for once and for good.
Ciao,
Jeroen
GeoCat Bridge for ArcGIS allows instant publishing of data and metadata on GeoServer, MapServer, PostGIS and GeoNetwork. Visit http://geocat.net for details.
Jeroen Ticheler
GeoCat bv
Veenderweg 13
6721 WD Bennekom
Tel: +31 (0)6 81286572
http://geocat.net
Op 28 okt. 2013 om 10:36 heeft Jesse Eichar <jesse.eichar@anonymised.com> het volgende geschreven:
I am developing on windows and have it working correctly. I probably did the fix for the spring-data-jpa work or some such.
On Mon, Oct 28, 2013 at 8:31 AM, Francois Prunayre <fx.prunayre@anonymised.com> wrote:
Hi Jose
BTW, at some point, we need to have it fixed. I had a look but not 100% sure of the fix. See
schema plugin URI catalog / Fix when path contains space on windows by fxprunayre · Pull Request #135 · geonetwork/core-geonetwork · GitHub If anyone could double check it on windows, that would be great.
Cheers.
Francois
Regards Esben
Til: Esben Taudorf
Hi Esben
Jose García
Hi everybody.
GUI:
error detected.
output for : search
metadata tab
error for: search
search
Regards Esben
Jose García
GeoCat bv
Veenderweg 13
6721 WD Bennekom
The Netherlands
GeoNetwork-devel mailing list
2013/10/24 Esben Taudorf <eta@anonymised.com…>
Hi Jose
https://github.com/geonetwork/core-geonetwork/pull/135 If anyone could double check it on windows, that would be great.
Cheers.
Francois
Regards Esben
Til: Esben Taudorf
Hi Esben
Jose García
Hi everybody.
(web\geonetwork\WEB-INF\classes\setup\sql\data). After setting up the
GUI:
error detected.
2013-10-24 10:45:31,463 INFO [jeeves.service] - → dispatching to
output for : search
metadata tab
2013-10-24 10:45:31,653 INFO [jeeves.service] - → transforming
2013-10-24 10:45:31,842 ERROR [jeeves.service] - → exception during
2013-10-24 10:45:31,843 ERROR [jeeves.service] - → (C) stylesheet :
2013-10-24 10:45:31,843 ERROR [jeeves.service] - → (C) message :
2013-10-24 10:45:31,843 ERROR [jeeves.service] - → (C) exception :
2013-10-24 10:45:31,844 INFO [jeeves.service] - → dispatching to
error for: search
2013-10-24 10:45:32,026 INFO [jeeves.service] - → transforming
2013-10-24 10:45:32,139 INFO [jeeves.service] - → end error
2013-10-24 10:45:32,140 INFO [jeeves.service] - → error ended for :
search
Regards Esben
GeoCat Bridge for ArcGIS allows instant publishing of data and metadata on GeoServer and GeoNetwork. Visit http://geocat.net <http://geocat.net/> for details.
Jose García
GeoCat bv
Veenderweg 13
6721 WD Bennekom
The Netherlands
http://GeoCat.net <http://geocat.net/>
