[GeoNetwork-users] Should large map viewer show country bounds+Blue marble when opened?
Hi users and developers,
I compile and install geonetwork trunk 2.7 (SVN8469) + ANZMEST with schema plugins
iso19139.anzlic and iso19139.mcp. I am running with jetty and
using the supplied geoserver 2.1.1 web app with country boundaries and blue marble world.
I configure web/geonetwork/WEB-INF/config-gui.xml replacing the
the 5 occurrences of http://localhost:8080/geoserver/wms with
http://myserver.gov.au:1234/geoserver/wms according to host and port
in order to get correct URL for geoserver to draw base maps.
I then get the small base map (with country boundaries + blue marble world)
on the left hand side.
When I click 'show map' for the large map
should it display country boundaries and blue marble world?
OR can only get these through add layers with green + button and select
geoserver and then layer?
Andrew
