[GeoNetwork-users] simple metadata forms
Hello,
We are customizing the metdata editor form to show simple elements instead
of the whole set of elements that gets displayed and for the custom view we
set flat="true" attribute in config-gui.xml. But we still get the complete
set of elements for Example in Contact Details we get Fascimile etc. How do
we control this?
Thanks.
Regards
Kumaran
This is not directly an answer to your specific question but a more general comment on simpler data entry & query tools.
My organisation is developing a "postcard" tool, with subject areas on a tab based form, like what, who, where, when, etc to provide a less complex GUI to interact with. This is not yet complete, nor (yet) available externally.
Another agency I work with has developed a different front end to the underlying catalogue
see: http://www.geodata.govt.nz and reused at (query only) http://www.os2020.org.nz/data-and-reports/. This is built into the Open Source Silverstripe CMS, and is freely reuseable
In Australia there is the ANZMEST Lite interface, and the xMET inteface.
So in my experience, most places that seek to simplify the interface are using a completely different front end, using CSW or other supported protocol to communicate with the underlying Geonetwork catalogue.
I'm not sure if this might prove an easier way to build a simpler interface.
Brent Wood
--- On Tue, 2/28/12, Kumaran Narayanaswamy <kumaran.narayanaswamy@anonymised.com> wrote:
From: Kumaran Narayanaswamy <kumaran.narayanaswamy@anonymised.com>
Subject: [GeoNetwork-users] simple metadata forms
To: geonetwork-devel@lists.sourceforge.net, geonetwork-users@anonymised.comrge.net
Date: Tuesday, February 28, 2012, 6:28 PM
Hello,
we control this?
Thanks.
Regards
Kumaran
Keep Your Developer Skills Current with LearnDevNow!
The most comprehensive online learning library for Microsoft developers
is just $99.99! Visual Studio, SharePoint, SQL - plus HTML5, CSS3, MVC3,
Metro Style Apps, more. Free future releases when you subscribe now!
http://p.sf.net/sfu/learndevnow-d2d
GeoNetwork-users mailing list
Hi Kumaran
Which version of GeoNetwork are you using? For 2.6.4 there was a bug on
flat attribute management.
See rev 8539 to fix it. It just requires 2 small changes in the file
xsl/metadata.xsl to get it working properly.
Jose García
On Tue, Feb 28, 2012 at 6:28 AM, Kumaran Narayanaswamy <
Hello,
we control this?
Thanks.
Regards
Kumaran
GeoCat Bridge for ArcGIS allows instant publishing of data and metadata on
GeoServer and GeoNetwork. Visit http://geocat.net for details.
_________________________
Jose García
GeoCat bv
Veenderweg 13
6721 WD Bennekom
The Netherlands
http://GeoCat.net/&gt;
Hello Jose,
I checked out the code for rev 8539 and then built a war file and deployed to Tomcat. Enabled Inspire View through system configuration then went to Create New Metadata screen and I still see the whole fields when flat=”true” is set to Inspire in config-gui.xml
Do we need to do something else to filter other fields in Point of Contact . Please let me know
Please refer the attached snapshot.
Thanks.
Regards
Kumaran
From: Jose Garcia [mailto:jose.garcia@anonymised.com]
Sent: Tuesday, February 28, 2012 1:44 PM
To: Kumaran Narayanaswamy
Cc: geonetwork-devel@lists.sourceforge.net; geonetwork-users@anonymised.comrge.net
Subject: Re: [GeoNetwork-users] simple metadata forms
Hi Kumaran
Which version of GeoNetwork are you using? For 2.6.4 there was a bug on flat attribute management.
See rev 8539 to fix it. It just requires 2 small changes in the file xsl/metadata.xsl to get it working properly.
Jose García
On Tue, Feb 28, 2012 at 6:28 AM, Kumaran Narayanaswamy <kumaran.narayanaswamy@anonymised.com> wrote:
Hello,
we control this?
Thanks.
Regards
Kumaran
GeoCat Bridge for ArcGIS allows instant publishing of data and metadata on GeoServer and GeoNetwork. Visit <http://geocat.net/&gt; http://geocat.net for details.
Jose García
GeoCat bv
Veenderweg 13
6721 WD Bennekom
The Netherlands
<http://geocat.net/&gt; http://GeoCat.net
(attachments)
Snapshot.pdf (86.9 KB)
Hello Jose,
Do we need to do something else to filter other fields . Please let me know
Thanks.
Regards
Kumaran
Hi Kumaran
Jose García
Hello,
we control this?
Thanks.
Regards
Kumaran
Jose García
GeoCat bv
Veenderweg 13
6721 WD Bennekom
The Netherlands
