[GeoNetwork-users] Spatial Index Problem with Geonetwork 2.10.4
Hi List
(attempt 3 at sending this message, apologies if all three come through!)
I recently upgraded a Geonetwork 2.10.4 installation to the latest snapshot
to apply some security patches. I'm using tomcat6 and my approach was to
create a new database (postgresql) and restore a snapshot of my live one to
that. I copied my live data directory to a new one. I deployed a renamed
war file and set the config to point at the new database and new data
directory. This all worked fine, so I stopped tomcat6, and renamed
everything so that the new version was the one in use. The configuration
all seemed fine for a couple of days but then I started to get lots of
problems with both the spatial index and the lucene index (separate message
to follow about lucene).
For the spatial index- previously I was using postgresql for my database
but a shapefile spatial index. No problems were reported in the old
installation, but fairly quickly after doing the upgrade I started to see
errors about corruptions in the index. There were lots looking like the one
below but for different metadata IDs.
2015-07-20 02:06:24,337 ERROR [geonetwork.index] - Failure resetting
spatial index.
java.io.IOException: Dbf has extra record
at
org.geotools.data.shapefile.ShapefileAttributeReader.internalReadersHaveNext(ShapefileAttributeReader.java:153)
at
org.geotools.data.shapefile.ShapefileFeatureWriter.close(ShapefileFeatureWriter.java:237)
at
org.geotools.data.shapefile.indexed.IndexedShapefileFeatureWriter.close(IndexedShapefileFeatureWriter.java:109)
at
org.geotools.data.InProcessLockingManager$1.close(InProcessLockingManager.java:350)
at
org.geotools.data.AbstractFeatureStore.removeFeatures(AbstractFeatureStore.java:370)
at
org.fao.geonet.kernel.search.spatial.SpatialIndexWriter.reset(SpatialIndexWriter.java:276)
at
org.fao.geonet.kernel.search.SearchManager.setupIndex(SearchManager.java:1348)
at
org.fao.geonet.kernel.search.SearchManager.initLucene(SearchManager.java:648)
at org.fao.geonet.kernel.search.SearchManager.<init>(SearchManager.java:542)
at org.fao.geonet.Geonetwork.start(Geonetwork.java:320)
at jeeves.server.JeevesEngine.initAppHandler(JeevesEngine.java:605)
at jeeves.server.JeevesEngine.init(JeevesEngine.java:206)
at jeeves.server.sources.http.JeevesServlet.init(JeevesServlet.java:91)
at javax.servlet.GenericServlet.init(GenericServlet.java:212)
at
org.apache.catalina.core.StandardWrapper.loadServlet(StandardWrapper.java:1213)
at org.apache.catalina.core.StandardWrapper.load(StandardWrapper.java:1026)
at
org.apache.catalina.core.StandardContext.loadOnStartup(StandardContext.java:4425)
at org.apache.catalina.core.StandardContext.start(StandardContext.java:4738)
at
org.apache.catalina.core.ContainerBase.addChildInternal(ContainerBase.java:799)
at org.apache.catalina.core.ContainerBase.addChild(ContainerBase.java:779)
at org.apache.catalina.core.StandardHost.addChild(StandardHost.java:583)
at org.apache.catalina.startup.HostConfig.deployWAR(HostConfig.java:943)
at org.apache.catalina.startup.HostConfig.deployWARs(HostConfig.java:778)
at org.apache.catalina.startup.HostConfig.deployApps(HostConfig.java:504)
at org.apache.catalina.startup.HostConfig.start(HostConfig.java:1317)
at
org.apache.catalina.startup.HostConfig.lifecycleEvent(HostConfig.java:324)
at
org.apache.catalina.util.LifecycleSupport.fireLifecycleEvent(LifecycleSupport.java:142)
at org.apache.catalina.core.ContainerBase.start(ContainerBase.java:1065)
at org.apache.catalina.core.StandardHost.start(StandardHost.java:822)
at org.apache.catalina.core.ContainerBase.start(ContainerBase.java:1057)
at org.apache.catalina.core.StandardEngine.start(StandardEngine.java:463)
at org.apache.catalina.core.StandardService.start(StandardService.java:525)
at org.apache.catalina.core.StandardServer.start(StandardServer.java:754)
at org.apache.catalina.startup.Catalina.start(Catalina.java:595)
at
sun.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAccessorImpl.java:57)
at
sun.reflect.DelegatingMethodAccessorImpl.invoke(DelegatingMethodAccessorImpl.java:43)
at java.lang.reflect.Method.invoke(Method.java:606)
at org.apache.catalina.startup.Bootstrap.start(Bootstrap.java:289)
at org.apache.catalina.startup.Bootstrap.main(Bootstrap.java:414)
2015-07-20 02:06:24,429 INFO [jeeves.apphand] - - Access manager...
<snip>
2015-07-20 02:06:35,114 ERROR [geonetwork.index] - Failed to properly index
geometry of metadata 5422. Error: Dbf has extra record
at
at
at
at
at
org.geotools.data.FilteringFeatureWriter.close(FilteringFeatureWriter.java:151)
at
at
org.fao.geonet.kernel.search.spatial.SpatialIndexWriter.delete(SpatialIndexWriter.java:221)
at
org.fao.geonet.kernel.search.SearchManager.indexGeometry(SearchManager.java:711)
at org.fao.geonet.kernel.search.SearchManager.index(SearchManager.java:695)
at org.fao.geonet.kernel.DataManager.indexMetadata(DataManager.java:580)
at
org.fao.geonet.kernel.DataManager$IndexMetadataTask.run(DataManager.java:399)
at
java.util.concurrent.ThreadPoolExecutor.runWorker(ThreadPoolExecutor.java:1145)
at
java.util.concurrent.ThreadPoolExecutor$Worker.run(ThreadPoolExecutor.java:615)
at java.lang.Thread.run(Thread.java:745)
2015-07-20 02:06:35,115 ERROR [geonetwork.datamanager] - The metadata
document index with id=5422 is corrupt/invalid - ignoring it. Error: null
2015-07-20 02:06:35,158 ERROR [geonetwork.index] - Failed to properly index
geometry of metadata 5909. Error: Dbf has extra record
at
at
at
at
at
at
at
at
at
at
at
2015-07-20 02:06:35,158 ERROR [geonetwork.datamanager] - The metadata
document index with id=5909 is corrupt/invalid - ignoring it. Error: null
As I couldn't see any documentation on how I get around this, I thought
that if I converted to using a postgis index it would rebuild everything
and I would stop getting the errors. I altered the connection string in
config.xml to jdbc:postgresql_postGIS://host:5432/database. The
documentation suggests this should be enough to get Geonetwork to use
postgis for the spatial index. I created the spatialindex table using the
setup scripts from the installation and when I restarted Geonetwork this
table was populated. However, when my server has restarted since then, it
has reverted to using shapefiles for it's index and I'm seeing the
corruption again. I can't see any errors about why it would revert back to
using shapefiles.
Can anyone give me some clues as to what's going on?
Thanks
Jo
*Jo Cook*
Astun Technology Ltd, The Coach House, 17 West Street, Epsom, Surrey, KT18
7RL, UK
t:+44 7930 524 155
iShare - Data integration and publishing platform
<http://www.isharemaps.com/&gt;
Company registration no. 5410695. Registered in England and Wales.
Registered office: 120 Manor Green Road, Epsom, Surrey, KT19 8LN VAT no.
864201149.
Hi Jo
Have you try to delete the index folder and restart GeoNetwork? this should
at least recreate the shapefile and I guess should be fine then.
Not sure why not using the postgis index. Check the log file, to see if
provides any information about this.
Jose García
On Thu, Jul 23, 2015 at 1:13 PM, Jo Cook <jocook@anonymised.com> wrote:
Hi List
spatial index.
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
<snip>
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
using shapefiles.
Thanks
Jo
*Jo Cook*
7RL, UK
t:+44 7930 524 155
864201149.
GeoNetwork-users mailing list
*GeoCat Bridge for ArcGIS allows instant publishing of data and metadata on
GeoServer and GeoNetwork. Visit http://geocat.net/&gt; for
details. _________________________Jose GarcíaGeoCat bvVeenderweg 136721 WD
BennekomThe Netherlandshttp://GeoCat.net/>*
Hi Jose,
Sorry for the delay in getting back to you about this. I have tried to
force geonetwork to recreate the index by backing up the old index
directory and restarting geonetwork so that it creates that from scratch. I
still get all the same errors as before though- for the lucene index. This
seems to have fixed the spatial index errors though.
Jo
On Thu, Jul 23, 2015 at 12:39 PM, Jose Garcia <jose.garcia@anonymised.com>
wrote:
Hi Jo
should at least recreate the shapefile and I guess should be fine then.
Jose García
wrote:
Hi List
snapshot
to
message
one
spatial index.
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
<snip>
index
at
at
at
at
at
at
at
at
at
at
at
at
index
at
at
at
at
at
at
at
at
at
at
at
at
using shapefiles.
Thanks
Jo
*Jo Cook*
7RL, UK
t:+44 7930 524 155
864201149.
on GeoServer and GeoNetwork. Visit http://geocat.net
<http://geocat.net/&gt; for details. _________________________Jose
GarcíaGeoCat bvVeenderweg 136721 WD BennekomThe
*Jo Cook*
7RL, UK
t:+44 7930 524 155
864201149.
