In our geonetwork setup many regions are global. When searching spatial all queries will match with the global datasets.
It would be nice to adjust de ranking of the search extent with the datasets.
For example when I draw a bounding box of the netherlands, datasets that have a similar area size should ranked higher that areas that have a much higher or lower area size.
Would this kind of ranking be possible with geonetwork 3 or would some custom code be required?
In case code changes are required, could you please give an indication on how to implement such a feature. I'm will to make the code available as a pull request if such a feature doesn't exist yet.
Rudie Ekkelenkamp.
DISCLAIMER: This message is intended exclusively for the addressee(s) and may contain confidential and privileged information. If you are not the intended recipient please notify the sender immediately and destroy this message. Unauthorized use, disclosure or copying of this message is strictly prohibited. The foundation 'Stichting Deltares', which has its seat at Delft, The Netherlands, Commercial Registration Number 41146461, is not liable in any way whatsoever for consequences and/or damages resulting from the improper, incomplete and untimely dispatch, receipt and/or content of this e-mail.
No this feature doesn't exist in geonetwork.
If you want to sort result on the extent size, it must be done server side,
from Lucene index.
I don't think it's gonna be easy.
On Sun, Feb 21, 2016 at 11:32 AM, Rudie Ekkelenkamp <
Rudie.Ekkelenkamp@anonymised.com> wrote:
datasets.
Rudie Ekkelenkamp.
of this e-mail.
Site24x7 APM Insight: Get Deep Visibility into Application Performance
APM + Mobile APM + RUM: Monitor 3 App instances at just $35/Month
Monitor end-to-end web transactions and take corrective actions now
Troubleshoot faster and improve end-user experience. Signup Now! http://pubads.g.doubleclick.net/gampad/clk?id=272487151&iu=/4140
GeoNetwork-users mailing list
GeoNetwork-users@lists.sourceforge.net geonetwork-users List Signup and Options
*camptocamp*
INNOVATIVE SOLUTIONS
BY OPEN SOURCE EXPERTS
