[GeoNetwork-users] special sign "&"
Hallo,
I´m migrating data from a projects database to geonetwork 2.1 using a
postgresql database...
There are charackters like the "&"-sign in the datasets. GN seems not to
accept the "&" sign in a string like the "title". "%" for example works.
Also have problems with other characters like "é" or "ä". I checked the
postgres database it is set to utf8. GN displays this charckters in a very
strange way é = é. Has anybody a solution for this problem.
best regards
roczko
View this message in context: http://www.nabble.com/special-sign-"-"-tp15487097s18419p15487097.html
Sent from the geonetwork-users mailing list archive at Nabble.com.
Is this an issue with the special semantics of '&' in XML? If the stylesheets for display are outputting XHTML, perhaps the funny rendering is occurring there?
A. Soroka / DSS R & D / the University of Virginia Library
On Feb 14, 2008, at 2:22 PM, roczko wrote:
Hallo,
best regards
roczko
Defy all challenges. Microsoft(R) Visual Studio 2008.
GeoNetwork-users mailing list
Hello,
Have you looking to the related problem on others posts ?
http://www.nabble.com/Problem-with-post-files-and-accents-on-metadata-edit.xsl-tp13470914s18419p13470914.html
http://www.nabble.com/GN-2.1-Beta-4---Error-with-accent-tp11831161s18419p11831161.html
http://www.nabble.com/some-tweaking-issues-tp8974417s18419p8974417.html
That can maybe helpfull
Best regards,
Fabien Bachraty
roczko wrote:
Hallo,
best regards
roczko
View this message in context: http://www.nabble.com/special-sign-"-"-tp15487097s18419p15496161.html
Hallo and thank you for answering.
There is a difference between é and the &-sign. While GN displays the é
"only" wrong, it does not accept the xml file if there is the &-sign in a
string at all.
best regards
roczko
Hallo,
not to
works.
the
a very
best regards
roczko
View this message in context: http://www.nabble.com/special-sign-%
22-%22-tp15487097s18419p15487097.html
projects/geonetwork
View this message in context: http://www.nabble.com/special-sign-"-"-tp15487097s18419p15499510.html
