[GeoNetwork-users] srv:operatesOn xlink:href
Dear all,
acoording to the Metadata Implementation Rules of the german SDI "GDI DE"
the data -service linkage has to be realized via "xlink:href" attribute in the "srv:operatesOn" element
(gmd:MD_Metadata/gmd:IdentificationInfo/srv:SV_ServiceIdentification/srv:operatesOn).
I am using GeoNetwork 2.6.4!
Using the search dialog (Binocular-Button) only the attribute "uuidref" is stored with the UUID
of the coupled dataset.
The grid showing the results in the search dialog already shows a column URI which
contains the URI of the corresponding dataset. So I think it would be quite easy to make GN store
the xlink:href to this URI as well.
Does someone offers a patch for this or might give me a hint where to look in the code to implement it?
Thanks in advance for any help
Till
Till Kirchner
Johann Heinrich v. Thünen-Institut (vTI)
Bundesforschungsinstitut für Ländliche Räume, Wald und Fischerei
Institut für Waldökologie und Waldinventuren (WOI)
Alfred-Möller-Str. 1
D-16225 Eberswalde
Tel.: 03334 3820 310
Email:till.kirchner@anonymised.com
Hi Till
That was changed in 2.6.x branch after 2.6.4 release. Give a try to nightly
build versin of 2.6.x branch. You can find it in:
http://nightlybuild.geonetwork-opensource.org/branch/
Jose García
On Mon, Nov 5, 2012 at 3:58 PM, Till Kirchner <till.kirchner@anonymised.com>wrote:
Dear all,
URI which
Till
Till Kirchner
D-16225 Eberswalde
LogMeIn Central: Instant, anywhere, Remote PC access and management.
Stay in control, update software, and manage PCs from one command center
Diagnose problems and improve visibility into emerging IT issues
Automate, monitor and manage. Do more in less time with Central
http://p.sf.net/sfu/logmein12331_d2d
GeoNetwork-users mailing list
GeoCat Bridge for ArcGIS allows instant publishing of data and metadata on
GeoServer and GeoNetwork. Visit http://geocat.net for details.
_________________________
Jose García
GeoCat bv
Veenderweg 13
6721 WD Bennekom
The Netherlands
http://GeoCat.net/&gt;
Hi Till,
you do not have to install anything for fullfilling "GDI-DE Konventionen"
document.
In the menue to the left (editing metadata) you find "XML Sicht". This is
where you can manipulate the operatesOn element as you wish.
German help manual for download:
http://geoportal.geodaten.niedersachsen.de/legende/anleitung_geonetwork_niedersachsen.pdf
(approx. 6MB)
Greetings,
Anja
View this message in context: http://osgeo-org.1560.n6.nabble.com/srv-operatesOn-xlink-href-tp5014046p5014546.html
Hi GN-Users,
sorry to bring up this old thread again, but since the subject is
completely right and the last suggestion seemed to work, I'd like to ask
about the current status of this issue. I'm using GN 2.10.3 on Suse Linux,
when I edit a service record and want to add the ref to a source dataset, I
tried both suggested ways: using the binoculars adds the uuid to the
uuidref field and the getRecordbyId URL in the xlink:href. However, as the
OP mentioned in the german SDI the local identifier should be appended to
the namespace using a "#". I tried Anja's suggestion using the XML-view and
saving it from there, but GN keeps on stripping this manually added
"#my_local_id". Is anybody experiencing the same behaviour?
Cheers, Michael
2012-11-07 13:48 GMT+01:00 Anja <moonbeam@anonymised.com>:
Hi Till,
document.
(approx. 6MB)
Greetings,
Anja
Michael Schulz
Johann-Sebastian-Bach-Str. 32
79104 Freiburg
