Does anyone have a free standing XSLT that will convert IS19139. mcp records to a tidy printed format? i.e one that is not dependent on Geonetwork.
Thanks Andrew
Please consider the environment before printing this email.
NIWA is the trading name of the National Institute of Water & Atmospheric Research Ltd.
Use the attached xml-to-text-ISO.xsl (it calls in the other attached files)
-----Original Message-----
From: Andrew Watkins [mailto:a.watkins@anonymised.com]
Sent: Tuesday, April 12, 2011 5:10 PM
To: geonetwork-users Users
Subject: [GeoNetwork-users] Stand alone XSLT
Thanks Andrew
Research Ltd.
Forrester Wave Report - Recovery time is now measured in hours and minutes
not days. Key insights are discussed in the 2010 Forrester Wave Report as
part of an in-depth evaluation of disaster recovery service providers.
Forrester found the best-in-class provider in terms of services and vision.
Read this report now! http://p.sf.net/sfu/ibm-webcastpromo
GeoNetwork-users mailing list
(attachments)
xml-to-text-ISO.xsl (6.17 KB)
elements-ISO.xml (34.5 KB)
printFormatted.xsl (10.5 KB)
printtextlines.xsl (6.49 KB)
hello list,
maybe you can use a simple oss php class for this.
there was a presentation on fossgis 2011 in heidelberg.
http://www.webmapcenter.de/imp/webseite/index.html
regards
armin
Am Mittwoch 13 April 2011, um 15:59:40 schrieb Jaci Mize:
Geonetwork.
Thanks Andrew
Research Ltd.
Im Auftrag
Armin Retterath
Zentrale Stelle Geodateninfrastruktur
LVermGeo RP
Ferdinand-Sauerbruch-Straße 15
56073 Koblenz
Telefon 0261/492-466
Telefax 0261/492-492
armin.retterath@anonymised.com
http://www.geoportal.rlp.de
