[GeoNetwork-users] Status code 504 for static content (CSS)
Hi
I get a "504 - The server did not return a complete response for this
request. Server returned 0 bytes." error when i run GN after my
installation.
Detail:
Happen on both Windows 10 / Windows Server 2012
jre-8u74-windows-x64
Tomcat 8
GN 3.0.3 (
https://sourceforge.net/projects/geonetwork/files/GeoNetwork_opensource/v3.0.3/
I installed it by downloading the war file (renamed the returned zip file
from SourceForge to *.war)
As an attempt to get around that, I tried to install using the
geonetwork-install-3.0.0-0.jar file ('java -jar
geonetwork-install-3.0.0-0.jar'). This work untill i hit 'next' after the
'pack installation progress' step is completed. I then get the error that i
pasted below in the command prompt.
Any advice would be much appreciated.
C:\Geonetwork>java -jar geonetwork-install-3.0.0-0.jar could not create
shortcut instance java.lang.Exception:
    error loading library java.lang.Exception: can't locate library
        at
com.izforge.izpack.util.Librarian.loadArchSpecificLibrary(Unknown Source)
        at com.izforge.izpack.util.Librarian.loadLibrary(Unknown Source)
        at com.izforge.izpack.util.os.ShellLink.initialize(Unknown Source)
        at com.izforge.izpack.util.os.ShellLink.<init>(Unknown Source)
        at com.izforge.izpack.util.os.Win_Shortcut.initialize(Unknown
Source)
        at com.izforge.izpack.panels.ShortcutPanel.panelActivate(Unknown
Source)
        at com.izforge.izpack.installer.InstallerFrame.switchPanel(Unknown
Source)
        at com.izforge.izpack.installer.InstallerFrame.navigateNext(Unknown
Source)
Source)
        at
com.izforge.izpack.installer.InstallerFrame$NavigationHandler.navigate(Unknown
Source)
        at
com.izforge.izpack.installer.InstallerFrame$NavigationHandler.access$100(Unknown
Source)
        at
com.izforge.izpack.installer.InstallerFrame$NavigationHandler$1.run(Unknown
Source)
        at java.lang.Thread.run(Unknown
Source)java.lang.NullPointerException
        at
com.izforge.izpack.util.os.Win_Shortcut.getProgramsFolder(Unknown Source)
        at
com.izforge.izpack.panels.ShortcutPanel.getProgramsFolder(Unknown Source)
Source)
Source)
Source)
Source)
        at
Source)
        at
Source)
        at
Source)
        at java.lang.Thread.run(Unknown Source)
Hi
Missing information is that the 504 errors are for files like these:
/geonetwork/static/gn_search_default.css
/geonetwork/static/gn_login_default.css
GN load and I can hit search etc, but the missing css is a problem.
Regards
On Tue, Mar 15, 2016 at 6:25 PM, Gert Conradie <gert.conradie@anonymised.com>
wrote:
Hi
installation.
Detail:
Tomcat 8
GN 3.0.3 (
        at
Source)
Source)
Source)
        at
com.izforge.izpack.installer.InstallerFrame.navigateNext(Unknown Source)
        at
        at
Source)
        at
Source)
        at
Source)
        at
        at
Source)
Source)
        at
        at
        at
Source)
        at
Source)
        at
Source)
