[GeoNetwork-users] Still...after trying for weeks...HTTP ERROR: 404 Here is the loggfile.
I´m running Symatec Norton 360, XP, IE8 & FireFox. Could it be the Firewall
settings? //Regards Anders Sweden
C:\Program\geonetwork\bin>cd ..\jetty
C:\Program\geonetwork\jetty>del logs\*request.log*
C:\Program\geonetwork\jetty>del logs\output.log
Det går inte att hitta C:\Program\geonetwork\jetty\logs\output.log.
C:\Program\geonetwork\jetty>move logs\geonetwork.log.* logs\archive
C:\Program\geonetwork\jetty\logs\geonetwork.log
C:\Program\geonetwork\jetty>move logs\intermap.log.* logs\archive
C:\Program\geonetwork\jetty\logs\intermap.log
C:\Program\geonetwork\jetty>move logs\geoserver.log.* logs\archive
Antingen är filnamnet duplicerat eller så finns inte filen.
C:\Program\geonetwork\jetty>rem try changing the Xmx parameter if your
machine has little RAM
C:\Program\geonetwork\jetty>rem java -Xms48m -Xmx256m -XX:MaxPermSize=128m
-DSTOP.PORT=8079 -DSTOP.KEY=geonetwork -jar start.jar ..\bin\jetty.xml
C:\Program\geonetwork\jetty>rem if you want to hide the dos window when
GeoNetwork is started,
C:\Program\geonetwork\jetty>rem comment out the next line and comment the
last line
C:\Program\geonetwork\jetty>java -Xms48m -Xmx512m -Xss2M
-XX:MaxPermSize=128m -DSTOP.PORT=8079 -Djava.awt.headless=true
2009-09-22 17:33:26.984::INFO: Logging to STDERR via
org.mortbay.log.StdErrLog
2009-09-22 17:33:27.218::INFO: jetty-6.1.14
2009-sep-22 17:33:36
org.geotools.data.shapefile.indexed.IndexedShapefileDataStore
<init>ALLVARLIG: null
2009-sep-22 17:33:36 org.geotools.factory.FactoryRegistry scanForPlugins
VARNING: Can't load a service for category "CoordinateOperationFactory".
Cause is "NoClassDefFoundError: javax/vecmath/SingularMatrixException".
2009-sep-22 17:33:36 org.geotools.data.shapefile.ShapefileDataStore
createSchema
VARNING: PRJ file not generated for null CoordinateReferenceSystem7781
[main] INFO util.ThreadPool - New thread pool (Current_count=0) of 1
threads
7781 [main] INFO jeeves.apphand - - Access manager...
7813 [main] INFO jeeves.apphand - - Data manager...
2009-sep-22 17:33:41 org.geotools.factory.FactoryRegistry scanForPlugins
VARNING: Can't load a service for category "ConverterFactory". Cause is
"NoClassDefFoundError: org/apache/commons/beanutils/Converter".
14734 [main] INFO jeeves.apphand - Adding xml schema : csw-record
15141 [main] INFO jeeves.apphand - Adding xml schema : dublin-core
15250 [main] INFO jeeves.apphand - Adding xml schema : fgdc-std
15500 [main] INFO jeeves.apphand - Adding xml schema : iso19115
15766 [main] INFO jeeves.apphand - Adding xml schema : iso19139
WARNING: gco:Record is a global element without a type - assuming a string
WARNING: schema-substitutions.xml has wiped out XSD substitution list for
gco:CharacterString
gco:CharacterString
17250 [main] INFO jeeves.apphand - - Harvest manager...
17297 [main] INFO jeeves.apphand - - Catalogue services for the web...
17422 [main] INFO jeeves.apphand - - Open Archive Initiative (OAI-PMH)
server...
17578 [main] INFO jeeves.apphand - Site ID is :
f1bc1430-6a54-4427-b634-2b99a6b9f835
17609 [main] INFO jeeves.engine - --- Handler started
17609 [main] INFO jeeves.engine - Starting schedule manager...
17609 [main] INFO jeeves.engine - Memory used is : 17717 Kb
17609 [main] INFO jeeves.engine - Total memory is : 520256 Kb
17609 [main] INFO jeeves.engine - Startup time is : 17 (secs)
17609 [main] INFO jeeves.engine - === System working
2009-09-22 17:33:53.593::WARN: failed
org.mortbay.jetty.webapp.WebAppContext@anonymised.com
b7fe{/geoserver,file:/C:/Program/geonetwork/web/geoserver/}
java.lang.NoSuchFieldError: KEY_REPLACE_INDEX_COLOR_MODEL
        at
org.geotools.resources.image.ImageUtilities.<clinit>(ImageUtilities.java:66)
        at
org.geoserver.GeoserverInitStartupListener.contextInitialized(GeoserverInitStartupListener.java:59)
        at
org.mortbay.jetty.handler.ContextHandler.startContext(ContextHandler.java:548)
        at org.mortbay.jetty.servlet.Context.startContext(Context.java:136)
        at
org.mortbay.jetty.webapp.WebAppContext.startContext(WebAppContext.java:1234)
        at
org.mortbay.jetty.handler.ContextHandler.doStart(ContextHandler.java:517)
        at
org.mortbay.jetty.webapp.WebAppContext.doStart(WebAppContext.java:460)
        at
org.mortbay.component.AbstractLifeCycle.start(AbstractLifeCycle.java:50)
        at
org.mortbay.jetty.handler.HandlerCollection.doStart(HandlerCollection.java:152)
        at
org.mortbay.jetty.handler.ContextHandlerCollection.doStart(ContextHandlerCollection.java:156)
        at
        at
        at
        at
org.mortbay.jetty.handler.HandlerWrapper.doStart(HandlerWrapper.java:130)
        at org.mortbay.jetty.Server.doStart(Server.java:222)
        at
        at org.mortbay.xml.XmlConfiguration.main(XmlConfiguration.java:985)
        at sun.reflect.NativeMethodAccessorImpl.invoke(Unknown Source)
        at sun.reflect.DelegatingMethodAccessorImpl.invoke(Unknown Source)
        at java.lang.reflect.Method.invoke(Unknown Source)
        at org.mortbay.start.Main.invokeMain(Main.java:194)
        at org.mortbay.start.Main.start(Main.java:523)
        at org.mortbay.start.Main.main(Main.java:119)
2009-sep-22 17:33:55 org.wfp.vam.intermap.services.wmc.MailWmcContext init
VARNING: *** The mailserver config property has not been set. WMC mail will
not be available.
2009-09-22 17:33:56.046::INFO: Started
SelectChannelConnector@anonymised.com:8080
View this message in context: http://n2.nabble.com/Still-after-trying-for-weeks-HTTP-ERROR-404-Here-is-the-loggfile-tp3693953p3693953.html
Hi Anders,
It looks like the GeoServer application is not starting up properly. One thing you could try first is to see if that causes the application to not start: move the geoserver folder outside of the web folder and see if now at least geonetwork starts. The interactive map won't work at that point, but at least it could give you a cleu where to look next.
Ciao,
Jeroen
last line
createSchema
threads
gco:CharacterString
gco:CharacterString
server...
       at
       at
       at
       at
       at
       at
       at
       at
       at
       at
       at
       at
       at
       at
not be available.
Come build with us! The BlackBerry&reg; Developer Conference in SF, CA
is the only developer event you need to attend this year. Jumpstart your
developing skills, take BlackBerry mobile applications to market and stay
ahead of the curve. Join us from November 9&#45;12, 2009. Register now&#33;
Best Open Source Mac Front-Ends 2024
GeoNetwork-users mailing list
geonetwork-users List Signup and Options
GeoNetwork OpenSource is maintained at GeoNetwork - Geographic Metadata Catalog download | SourceForge.net
This seems to be an issue with Geoserver, not Geonetwork, and I think it has been discussed on the list over the past few weeks.
Is geonetwork running or it is just an intermap issue?
Best regards,
jason
Jason P. Pickering
Consultant
WHO/Ministry of Health Zambia
email: pickeringj@anonymised.com
tel: +260968395190
-----Original Message-----
From: AnderSweden [mailto:Anders.Soderman@anonymised.com]
Sent: Tue 2009-09-22 18:12
To: geonetwork-users@lists.sourceforge.net
Subject: [GeoNetwork-users] Still...after trying for weeks...HTTP ERROR: 404 Here is the loggfile.
last line
createSchema
threads
gco:CharacterString
gco:CharacterString
server...
        at
        at
        at
        at
        at
        at
        at
        at
        at
        at
        at
        at
        at
        at
not be available.
ahead of the curve. Join us from November 9-12, 2009. Register now!
http://p.sf.net/sfu/devconf
Hello
The screen looks like this:
                                                    … and here it stops!!
//Regards Anders Söderman Sweden.
HTTP ERROR: 404 NOT_FOUND RequestURI=/geonetwork/
<http://jetty.mortbay.org> Powered by jetty://
  _____
[mailto:ml-user+159282-49441017@anonymised.com]
Sent: den 22 september 2009 18:45
To: AnderSweden
Subject: Re: [GeoNetwork-users] Still...after trying for weeks...HTTP ERROR:
Best regards,
jason
Jason P. Pickering
Consultant
email: [hidden email]
<http://n2.nabble.com/user/SendEmail.jtp?type=node&node=3694143&i=0&gt;
tel: +260968395190
<http://n2.nabble.com/user/SendEmail.jtp?type=node&node=3694143&i=1&gt; ]
To: [hidden email]
<http://n2.nabble.com/user/SendEmail.jtp?type=node&node=3694143&i=2&gt;
last line
createSchema
threads
gco:CharacterString
gco:CharacterString
server...
        at
        at
        at
8)
        at
        at
        at
        at
        at
52)
        at
lection.java:156)
        at
        at
52)
        at
        at
        at
not be available.
Come build with us! The BlackBerry® Developer Conference in SF, CA
[hidden email]
<http://n2.nabble.com/user/SendEmail.jtp?type=node&node=3694143&i=3&gt;
[hidden email]
<http://n2.nabble.com/user/SendEmail.jtp?type=node&node=3694143&i=4&gt;
  _____
View message @
-loggfile-tp3693953p3694143.html
To unsubscribe from Still...after trying for weeks...HTTP ERROR: 404 Here is
the loggfile., click
< (link removed)
uQEdJU2Fzc2lzdGFucy5zZXwzNjkzOTUzfC04MzYzMjI3MjA=> here.
View this message in context: http://n2.nabble.com/Still-after-trying-for-weeks-HTTP-ERROR-404-Here-is-the-loggfile-tp3693953p3694179.html
My first thoughts about this:
What comes up if you make localhost?
Is it the right port?
Setting class path to Java SDK right?
View this message in context: http://n2.nabble.com/Still-after-trying-for-weeks-HTTP-ERROR-404-Here-is-the-loggfile-tp3693953p3711671.html
Hi
I think you are using JAVA 5
Try 6 !!!!!!
And reinstall geonetwork
AnderSweden wrote:
Hello
  _____
To: AnderSweden
ERROR:
has
Best regards,
jason
Jason P. Pickering
Consultant
tel: +260968395190
To: [hidden email]
404
Firewall
last line
createSchema
threads
gco:CharacterString
gco:CharacterString
server...
        at
        at
        at
8)
        at
        at
        at
        at
        at
        at
52)
        at
lection.java:156)
        at
        at
52)
        at
        at
        at
        at
will
not be available.
[hidden email]
[hidden email]
  _____
View message @
is
< (link removed)
View this message in context: http://n2.nabble.com/Still-after-trying-for-weeks-HTTP-ERROR-404-Here-is-the-loggfile-tp3693953p3863012.html
although supposedly GeoNetwork suppports Java 1.5 and above. If running on 6
resolves your problem, please enter a bug report !
Kind regards
Heikki Doeleman
On Wed, Oct 21, 2009 at 3:05 PM, ZaTTeLLighT <zattellight@anonymised.com> wrote:
Hi
Try 6 !!!!!!
AnderSweden wrote:
> Hello
> _____
> From: Pickering, Jason (via Nabble)
> [mailto:ml-user+159282-49441017@anonymised.com<ml-user%2B159282-49441017@anonymised.com456...>
> To: AnderSweden
> ERROR:
> has
> Best regards,
> jason
> Jason P. Pickering
> Consultant
> tel: +260968395190
> From: AnderSweden [mailto:[hidden email]
> To: [hidden email]
> 404
> Firewall
> last line
> createSchema
> threads
string
> gco:CharacterString
> gco:CharacterString
> server...
> at
> at
> at
> 8)
> at
> at
> at
> at
> at
> at
> 52)
> at
> lection.java:156)
> at
> at
> 52)
> at
> at
> at
> at
Source)
init
> will
> not be available.
> [hidden email]
> [hidden email]
> _____
> View message @
> is
> < (link removed)
Come build with us! The BlackBerry(R) Developer Conference in SF, CA
ahead of the curve. Join us from November 9 - 12, 2009. Register now!
http://p.sf.net/sfu/devconference
