[GeoNetwork-users] Stuck with Extent. Also Polygon.
Hello
1) I am a bit stuck with the Extent definition. Not sure how I ended up with
the attached situation. But nothing seems to help. Changing into box and
saving does not bring the box definition GUI. If I delete the whole Extent
block and create a new one, I still cannot define a geographic box. Those
vertical min & max are needed. Should I change Temporal element too?
One solution might be to export as XML, then copy there an extent block from
another XML, and re-import by replacing the data with same UUID.
2) Using a geographic polygon is an interesting option (if a search with it
works - seems there was some bug even with the geographic box). How to enter
a polygon, then?
Arto
(attachments)
It appears so that to add the bounding box definition: Bounding Box
option should be selected first, and then the + button is pressed. But
still, how to get rid of defining the vertical limits is not clear.
And how to practically create a polygon.
Arto
