[GeoNetwork-users] suitable database for geonetwork for dev/prod migration
Hi Guys,
I am installing geonetwork on a virtual machine and planning to use H2 as database. Do you recommend any other database which is more suitable for dev/prod migration?
Also we have used MEF export/import functionality previously, is there any other recommended functionality instead these days?
Tannu
Hi
For production for sure you should not use H2. For developments can be
fine, but also I would recommend to use the same db as you plan to use in
production.
About MEF import/export should be fine.
Jose García
On Mon, Mar 31, 2014 at 11:26 AM, <Tannu.Gupta@anonymised.com> wrote:
Hi Guys,
dev/prod migration?
Tannu
GeoNetwork-users mailing list
* GeoCat Bridge for ArcGIS allows instant publishing of data and metadata
on GeoServer and GeoNetwork. Visit http://geocat.net
<http://geocat.net/&gt; for details. _________________________Jose
GarcíaGeoCat bvVeenderweg 13 6721 WD BennekomThe
Netherlandshttp://GeoCat.net/> *
Hi
Thanks for the reply, would you mind telling me a bit more detail about why H2 should not be used in production?
Tannu
Sent: Monday, 31 March 2014 5:45 PM
To: Gupta, Tannu (CESRE, Kensington)
Cc: geonetwork-users@lists.sourceforge.net
Subject: Re: [GeoNetwork-users] suitable database for geonetwork for dev/prod migration
Hi
For production for sure you should not use H2. For developments can be fine, but also I would recommend to use the same db as you plan to use in production.
Jose García
On Mon, Mar 31, 2014 at 11:26 AM, <Tannu.Gupta@...448...<mailto:Tannu.Gupta@…448…>> wrote:
Hi Guys,
Tannu
GeoNetwork-users@lists.sourceforge.net<mailto:GeoNetwork-users@lists.sourceforge.net>
GeoCat Bridge for ArcGIS allows instant publishing of data and metadata on GeoServer and GeoNetwork. Visit http://geocat.net/&gt; for details.
Jose García
GeoCat bv
Veenderweg 13
6721 WD Bennekom
The Netherlands
http://GeoCat.net/&gt;
