I'm going to create a new PR for 3.2.x in a very short time.
I created a new pull request here:
https://github.com/geonetwork/core-geonetwork/pull/1968
-I needed to change the connection pattern in oracle.xml
As a side node, if you need to connect to an Oracle DB and do not want to
change the webapp internal files, you may want to create an XML override file
and tell GN about it, by adding a system property like this:
-Dgeonetwork.jeeves.configuration.overrides.file=PATH_TO_YOUR_FILE
In the override file you shall then set the needed properties for the
connection to the DB:
<overrides>
<spring>
<set bean="jpaVendorAdapter" property="database" value="ORACLE"/>
<set bean="jdbcDataSource" property="driverClassName"
value="oracle.jdbc.driver.OracleDriver"/>
<set bean="jdbcDataSource" property="Url"
value="jdbc:oracle:thin:@//YOURHOST:1521/YOURDB"/>
<set bean="jdbcDataSource" property="username" value="YOURUSER"/>
<set bean="jdbcDataSource" property="password" value="YOURPW"/>
<set bean="jdbcDataSource" property="validationQuery"
value="SELECT 1 FROM DUAL"/>
<!-- only when installing, then remove -->
<set bean="jdbcDataSource" property="poolPreparedStatements"
value="false"/>
<set bean="jdbcDataSource" property="maxOpenPreparedStatements"
value="-1"/>
</spring>
</overrides>
Emanuele
Alle 13:16:32 di Tuesday 2 May 2017, Emanuele Tajariol ha scritto:
> Also there're some pull requests in GitHub to fix this, but require
> review and not integrated yet.
The existing PR is against the branch 3.0.x, and won't work on 3.2.x.
WIll also be providing a test build. Stay tuned.
Emanuele
Alle 07:59:58 di Tuesday 2 May 2017, Jose Garcia ha scritto:
> Hi
> If you're trying to setup GeoNetwork 3.x with Oracle, I'm afraid that
> doesn't work for the time being. There're some threads about this in the
> mailing list.
> Regards,
> Jose García
> On Fri, Apr 28, 2017 at 7:48 PM, Olyster <mcnolii@anonymised.com> wrote:
> > Hi,
> > I'm currently trying to install geonetwork via .war file in tomcat. The
> > install is working with H2 DB but trying to make it work with Oracle is
> > such
> > a mess !
> > -I needed to change the connection pattern in oracle.xml, restart
> > Apache service and then access the geonetwork url
> > -The code then tries to insert in Users table but with the value true
> > for a number(1) field which Oracle rejects. I updated
> > data-db-default.sql to workaround this problem.
> > -There's a select from Metadata table ... which doesn't exists.
> > Anybody facing the same problem ?
> > Thank you very much
> > View this message in context: http://osgeo-org.1560.x6.
> > nabble.com/Table-not-found-tp5318792.html
> > Sent from the GeoNetwork users mailing list archive at Nabble.com.
> > Check out the vibrant tech community on one of the world's most
> > engaging tech sites, Slashdot.org! http://sdm.link/slashdot
> > _______________________________________________
> > GeoNetwork-users mailing list
> > GeoNetwork-users@lists.sourceforge.net
> > https://lists.sourceforge.net/lists/listinfo/geonetwork-users
> > GeoNetwork OpenSource is maintained at http://sourceforge.net/
> > projects/geonetwork
Visit http://goo.gl/NWWaa2 for more information.
Ing. Emanuele Tajariol
Technical Lead
Via di Montramito 3/A
