[GeoNetwork-users] tag manager
Hello all
I'm trying to add google tag manager to geonetwork. There is a piece of
code provided by google to be added just after the <head> so I'm adding it
to base-layout.xsl.
But I'm getting this error:
22-Jan-2020 09:37:19.982 INFO [main]
org.apache.catalina.startup.Catalina.start Server startup in 50128 ms
Error on line 48 column 51 of base-layout.xsl:
  SXXP0003: Error reported by XML parser: The reference to entity "l" must
end with the ';' delimiter.
2020-01-22 09:37:21,258 ERROR [jeeves.service] - -> exception during
transformation for : catalog.search
2020-01-22 09:37:21,268 ERROR [jeeves.service] - -> (C) stylesheet :
/usr/local/tomcat/webapps/geonetwork/xsl/../xslt/ui-search/search.xsl
2020-01-22 09:37:21,268 ERROR [jeeves.service] - -> (C) message :
Failed to compile stylesheet. 1 error detected.
2020-01-22 09:37:21,269 ERROR [jeeves.service] - -> (C) exception :
TransformerConfigurationException
the code provided by google is this (see
https://developers.google.com/tag-manager/quickstart)
<!-- Google Tag Manager -->
<script>(function(w,d,s,l,i){w[l]=w[l]||;w[l].push({'gtm.start':
new Date().getTime(),event:'gtm.js'});var f=d.getElementsByTagName(s)[0],
j=d.createElement(s),dl=l!='dataLayer'?'&l='+l:'';j.async=true;j.src=
'https://www.googletagmanager.com/gtm.js?id='+i+dl;f.parentNode.insertBefore(j,f);
})(window,document,'script','dataLayer','GTM-XXXX');</script>
<!-- End Google Tag Manager -->
any ideas ?
thaks
Sebastian E. Ovide
Hi, "&" should be "&amp;" in the script in XSL
HTH
Francois
Le mer. 22 janv. 2020 à 10:42, Sebastian E. Ovide <sebastian.ovide@anonymised.com54...>
a écrit :
Hello all
to base-layout.xsl.
must
any ideas ?
thaks
Sebastian E. Ovide
GeoNetwork-users mailing list
perfect, that worked ! thank you
On Wed, 22 Jan 2020 at 09:50, Francois Prunayre <fx.prunayre@anonymised.com>
HTH
Francois
sebastian.ovide@anonymised.com> a écrit :
Hello all
to base-layout.xsl.
must
any ideas ?
thaks
Sebastian E. Ovide
Sebastian E. Ovide
[image: https://www.linkedin.com/in/ovide\]
<https://www.linkedin.com/in/ovide&gt;
