if I want to choose my own template at creating new metadata page there is
an empty place. My title of that template is not shown (is blank). But I can
open that template choosing that blank field.
Where or which file do I have to change to see my title?
Thanks.
best regards
Sarah
View this message in context: http://n2.nabble.com/Template-don-t-come-up-at-textbox-tp3711764p3711764.html
I have insert at metadata-utils.xsl this:
<xsl:when test="$schema='mytest'">
<xsl:call-template name="dublin-coreBrief"/> <!-- dublin-coreBrief is
still not correct -->
</xsl:when>
so I can read the title of my template at textbox. But I can´t open that
template ("IllegalStateException : Root element not set "). So I copied
metadata-dublin-core, changed name to metadata-mytest and changed some text
from dublin-core to mytest and so on. At this case I can´t open main page of
geonetwork and get this error:
TransformerConfigurationException : Failed to compile stylesheet. 1 error
detected.
Can anybody give me a hint where to look of?
Thanks.
best regards
Sarah
Sarah_S wrote:
can open that template choosing that blank field.
Thanks.
best regards
Sarah
View this message in context: http://n2.nabble.com/Template-don-t-come-up-at-textbox-tp3711764p3735490.html
now I can open my template at input form (default view) but my labels came
up like dc:title and not Title. It seems like GN could not find label
segment at labels.xml. Anybody there who know what the problem is?
Thanks.
best regards
Sarah
Sarah_S wrote:
</xsl:when>
text from dublin-core to mytest and so on. At this case I can´t open main
page of geonetwork and get this error:
detected.
Thanks.
best regards
Sarah
Sarah_S wrote:
is an empty place. My title of that template is not shown (is blank). But
I can open that template choosing that blank field.
Thanks.
best regards
Sarah
View this message in context: http://n2.nabble.com/Template-don-t-come-up-at-textbox-tp3711764p3747983.html
Hello Sarah, not sure if you added a new schema or not, but if that
the case, you need to update in config.xml the gui section to load
translation :
<gui>
<xml name="strings" file="xml/strings.xml" />
<xml name="countries" file="xml/countries.xml" />
<xml name="iso19115" base="xml/schemas/iso19115/loc" file="labels.xml" />
<xml name="iso19115" base="xml/schemas/iso19115/loc" file="codelists.xml" />
<xml name="iso19139" base="xml/schemas/iso19139/loc" file="labels.xml" />
<xml name="iso19139" base="xml/schemas/iso19139/loc" file="codelists.xml" />
<xml name="fgdc-std" base="xml/schemas/fgdc-std/loc" file="labels.xml" />
<xml name="dublin-core" base="xml/schemas/dublin-core/loc"
</gui>
HTH.
Francois
2009/10/1 Sarah_S <Sarah_flip@anonymised.com>:
Thanks.
best regards
Sarah
Sarah_S wrote:
</xsl:when>
detected.
Thanks.
best regards
Sarah
Sarah_S wrote:
Thanks.
best regards
Sarah
Come build with us! The BlackBerry® Developer Conference in SF, CA
is the only developer event you need to attend this year. Jumpstart your
developing skills, take BlackBerry mobile applications to market and stay
ahead of the curve. Join us from November 9-12, 2009. Register now!
http://p.sf.net/sfu/devconf
GeoNetwork-users mailing list
Hi Francois,
yes I add a new schema (copied dublin-core and changed name to 'mytest'). I
added this line at config.xml for my new schema:
<xml name="mytest" base="xml/schemas/mytest/loc" file="labels.xml" />
Do you need a log-file or anything else?
What I´m missing?
Thanks.
best regards
Sarah
translation :
<gui>
</gui>
HTH.
Francois
came
Thanks.
best regards
Sarah
Sarah_S wrote:
<xsl:call-template
</xsl:when>
main
error
detected.
Thanks.
best regards
Sarah
Sarah_S wrote:
But
Thanks.
best regards
Sarah
now!
now!
View this message in context: http://n2.nabble.com/Template-don-t-come-up-at-textbox-tp3711764p3748134.html
I notice that click on a label there are a error (line 7 of labels.xml is:
<description>Test</description>) :
org.jdom.input.JDOMParseException: Error on line 7 of document
file:/C:/temp/geonetwork/web/geonetwork/xml/schemas/mytest/loc/en/labels.xml:
Invalid byte 1 of 1-byte UTF-8 sequence.
at org.jdom.input.SAXBuilder.build(SAXBuilder.java:465)
at org.jdom.input.SAXBuilder.build(SAXBuilder.java:810)
at org.jdom.input.SAXBuilder.build(SAXBuilder.java:789)
at jeeves.utils.Xml.loadFile(Xml.java:143)
at jeeves.utils.XmlFileCacher.load(XmlFileCacher.java:103)
at jeeves.utils.XmlFileCacher.get(XmlFileCacher.java:65)
at jeeves.server.dispatchers.guiservices.XmlFile.exec(XmlFile.java:98)
at
jeeves.server.dispatchers.AbstractPage.invokeGuiService(AbstractPage.java:119)
at
jeeves.server.dispatchers.AbstractPage.invokeGuiServices(AbstractPage.java:103)
at
jeeves.server.dispatchers.ServiceManager.dispatchOutput(ServiceManager.java:640)
at
jeeves.server.dispatchers.ServiceManager.dispatch(ServiceManager.java:383)
at jeeves.server.JeevesEngine.dispatch(JeevesEngine.java:621)
at jeeves.server.sources.http.JeevesServlet.execute(JeevesServlet.java:174)
at jeeves.server.sources.http.JeevesServlet.doGet(JeevesServlet.java:89)
at javax.servlet.http.HttpServlet.service(HttpServlet.java:617)
at javax.servlet.http.HttpServlet.service(HttpServlet.java:717)
at
org.apache.catalina.core.ApplicationFilterChain.internalDoFilter(ApplicationFilterChain.java:290)
at
org.apache.catalina.core.ApplicationFilterChain.doFilter(ApplicationFilterChain.java:206)
at
org.apache.catalina.core.StandardWrapperValve.invoke(StandardWrapperValve.java:233)
at
org.apache.catalina.core.StandardContextValve.invoke(StandardContextValve.java:191)
at
org.apache.catalina.core.StandardHostValve.invoke(StandardHostValve.java:128)
at
org.apache.catalina.valves.ErrorReportValve.invoke(ErrorReportValve.java:102)
at
org.apache.catalina.valves.AccessLogValve.invoke(AccessLogValve.java:567)
at
org.apache.catalina.authenticator.SingleSignOn.invoke(SingleSignOn.java:394)
at
org.apache.catalina.core.StandardEngineValve.invoke(StandardEngineValve.java:109)
at
org.apache.catalina.connector.CoyoteAdapter.service(CoyoteAdapter.java:293)
at
org.apache.coyote.http11.Http11AprProcessor.process(Http11AprProcessor.java:859)
at
org.apache.coyote.http11.Http11AprProtocol$Http11ConnectionHandler.process(Http11AprProtocol.java:574)
at org.apache.tomcat.util.net.AprEndpoint$Worker.run(AprEndpoint.java:1527)
at java.lang.Thread.run(Thread.java:619)
Caused by: org.xml.sax.SAXParseException: Invalid byte 1 of 1-byte UTF-8
sequence.
at
org.apache.xerces.util.ErrorHandlerWrapper.createSAXParseException(Unknown
Source)
at org.apache.xerces.util.ErrorHandlerWrapper.fatalError(Unknown Source)
at org.apache.xerces.impl.XMLErrorReporter.reportError(Unknown Source)
at
org.apache.xerces.impl.XMLDocumentFragmentScannerImpl$FragmentContentDispatcher.dispatch(Unknown
Source)
at
org.apache.xerces.impl.XMLDocumentFragmentScannerImpl.scanDocument(Unknown
Source)
at org.apache.xerces.parsers.XML11Configuration.parse(Unknown Source)
at org.apache.xerces.parsers.XMLParser.parse(Unknown Source)
at org.apache.xerces.parsers.AbstractSAXParser.parse(Unknown Source)
at org.apache.xerces.jaxp.SAXParserImpl$JAXPSAXParser.parse(Unknown Source)
at org.jdom.input.SAXBuilder.build(SAXBuilder.java:453)
... 29 more
sequence.
at
Source)
at
Source)
at
Source)
and further on...
I get no tooltip with the description of the label but an error message
(Cannot get tooltips from server
Error : operation-aborted
Message : Can't load xml file :
C:\temp\geonetwork\web\geonetwork\xml\schemas\mytest\loc\en\labels.xml
Class : OperationAbortedEx
Object : org.jdom.input.JDOMParseException: Error on line 7 of document
Invalid byte 1 of 1-byte UTF-8 sequence) .
Any ideas are appreciated.
Thanks.
best regards
Sarah
Sarah_S wrote:
Hi Francois,
I added this line at config.xml for my new schema:
What I´m missing?
Thanks.
best regards
Sarah
translation :
<gui>
</gui>
HTH.
Francois
came
Thanks.
best regards
Sarah
Sarah_S wrote:
<xsl:call-template
</xsl:when>
that
main
error
detected.
Thanks.
best regards
Sarah
Sarah_S wrote:
there
But
Thanks.
best regards
Sarah
stay
now!
now!
View this message in context: http://n2.nabble.com/Template-don-t-come-up-at-textbox-tp3711764p3748779.html
hi,
just to let you know that I solved this:
I had a mistake at my labels.xml. There was another description text that
caused the problem. Changed it to this line for description tag:
<element name="simplemy">
<label>Metadata</label>
<description/>
</element>
solved incorrect labeling.
Thanks.
best regards
Sarah
translation :
<gui>
</gui>
HTH.
Francois
came
Thanks.
best regards
Sarah
Sarah_S wrote:
<xsl:call-template
</xsl:when>
that
main
error
detected.
Thanks.
best regards
Sarah
Sarah_S wrote:
there
But
Thanks.
best regards
Sarah
stay
now!
now!
View this message in context: http://n2.nabble.com/Template-don-t-come-up-at-textbox-tp3711764p3768386.html
