[GeoNetwork-users] template drop down-no values
geonetwork-users-request@lists.sourceforge.net wrote:
Hi Edwin,
Thanks for the feedback! Can you be more specific on what you did and also what version you are using, operating system and other relevant details?
Thanks a lot,
Jeroen
On Feb 8, 2007, at 12:33 PM, M.E Aabobe wrote:
Dear All,
I have been test driving Geonetwork and it is great. when a registered EDITOR has logged in the template dop down does not work. how can i go about this? but when logged in as Administrator it works. see attached graphic. Thanks for your help in advance.
Edwin
Hi Jeroen and Edwin,
This sounds like the indexing bug I filed - 1651262 - for some reason
the Lucene indexing isn't picking up the operations allowed on the
templates at template creattion etc. I worked around it by forcing a rebuild of the Lucene indexing on startup of geonetwork (I came across the problem on 2.0.2/2.0.3 - 64 bit Linux) but it probably needs addressing elsewhere.
Simon Pigot
