[GeoNetwork-users] Template iso19115 added but it doesn't show on Metadada creation page
Hello Group,
I'm trying to create some new metadada using the iso19115 template.
I added the template using the Administration page -> Select Schemas ->
iso19115 and click on Add Templates button. The page informs: Metadada
template added.
But going to New Metadada option and expanding the box, the Template
iso19115 doesn't apper.
I was looking on .../geonetwork/WEB-INF/data/config/schema_plugins and the
templates are there:
csw-record dublin-core iso19110 iso19115 iso19139 labels.xsd
Only iso19115 template is not showing on Metadata creation :frowning:
Any idea?
Natália Oliveira
View this message in context: http://osgeo-org.1560.x6.nabble.com/Template-iso19115-added-but-it-doesn-t-show-on-Metadada-creation-page-tp5203780.html
2015-05-01 18:36 GMT+02:00 nataliaoliveira <queiroz.nati@anonymised.com>:
Hello Group,
template added.
Any idea?
check the iso19115/templates folder (
https://github.com/geonetwork/core-geonetwork/tree/2.10.x/web/src/main/webapp/WEB-INF/data/config/schema_plugins/iso19115).
It does not exist. This plugin is the final draft of the ISO standard which
is not used anymore (FYI, it is deprecated in version 3).
So you should probably use iso19139 instead (
https://github.com/geonetwork/core-geonetwork/tree/2.10.x/web/src/main/webapp/WEB-INF/data/config/schema_plugins/iso19139/templates
HTH.
Francois
Natália Oliveira
One dashboard for servers and applications across Physical-Virtual-Cloud
Widest out-of-the-box monitoring support with 50+ applications
Performance metrics, stats and reports that give you Actionable Insights
Deep dive visibility with transaction tracing using APM Insight.
http://ad.doubleclick.net/ddm/clk/290420510;117567292;y
GeoNetwork-users mailing list
