[GeoNetwork-users] template not shown in administration
  Hello,
I'm new to the GN community and installed the precompiled windows binaries on a Windows Server 2003 machine 2 days ago.
My problem is that the Menu Point Templates (described in the User's Manual) is not shown in my administration menu.
I know that I can creat new templates by creating a "New metadata" and choosing type template instead of metadata.
But how can I delete delete and/or modify individual templates.
As mentoined the User's Manual describes the Menu Template with "Sort Templates" and "Add Templates" but none of this is shown in my administration menu.
Thanks for help
Till
Hi Till,
What version of GeoNetwork are you using? I'm familiar with the 2.6.0 line
so the following is for that.
To delete/modify templates (once you've added/created them) you need to
use the search to find them.
First login as admin.
Click "advanced" for the advanced search options
Click "Restrict To".
In the thing that just popped up, change "Kind" to "template".
Then hit search.
It'll find all of your templates and you can interact with them in the
exact same way as you do regular metadata.
Hope that solves it, if not I'm afraid you'll have to be a little clearer
on what you mean.
Jonathan
This transmission is intended for the named addressee(s) only and may contain sensitive or protectively marked material up to RESTRICTED and should be handled accordingly. Unless you are the named addressee (or authorised to receive it for the addressee) you may not copy or use it, or disclose it to anyone else. If you have received this transmission in error please notify the sender immediately. All email traffic sent to or from us, including without limitation all GCSX traffic, may be subject to recording and/or monitoring in accordance with relevant legislation.
