[GeoNetwork-users] The APR based Apache Tomcat Native library was not found
Hi All,
Sorry for cross posting.
I now seem to GN version 2.7 snapshot revision r8695 with ANZMEST
schemaplugins revision r8650.p migrated and running on the new server.
I am now debugging or documenting the errors.
When I start up GN I get the following in the catalina.out file:
INFO: The APR based Apache Tomcat Native library which allows optimal
performance in production environments was not found on the
java.library.path: /usr/lib/jvm/java-6-sun-1.6.0.26/jre/lib/amd64/server:/usr/lib/jvm/java-6-sun-1.6.0.26/jre/lib/amd64:/usr/lib/jvm/java-6-sun-1.6.0.26/jre/../lib/amd64:/usr/java/packages/lib/amd64:/usr/lib64:/lib64:/lib:/usr/lib
This is just a warning but what are the consequences of *not* trying to
debug this issue?
Thanks.
John Hockada
The APR warning is the tomcat configuration, it does not have to do with Geonetwork. I would update the logs so the geonetwork specific debug stuff is in a separate file from the tomcat debug information.
Jesse
On Thu, Jun 7, 2012 at 7:57 AM, john.hockaday <john.hockaday@anonymised.com> wrote:
Hi All,
java.library.path: /usr/lib/jvm/java-6-sun-1.6.0.26/jre/lib/amd64/server:/usr/lib/jvm/java-6-sun-1.6.0.26/jre/lib/amd64:/usr/lib/jvm/java-6-sun-1.6.0.26/jre/…/lib/amd64:/usr/java/packages/lib/amd64:/usr/lib64:/lib64:/lib:/usr/lib
This is just a warning but what are the consequences of not trying to
debug this issue?
Thanks.
John Hockada
Live Security Virtual Conference
Exclusive live event will cover all the ways today’s security and
threat landscape has changed and how IT managers can respond. Discussions
will include endpoint security, mobile security and the latest in malware
threats. http://www.accelacomm.com/jaw/sfrnl04242012/114/50122263/
GeoNetwork-devel mailing list
