[GeoNetwork-users] The PDF is not generating properly
I'll explain the problem with an example:
My metadata are multilingual (2 languages: main language is Spanish and the
locale is Catalan).
If I go to 'http://sitmun3.diba.cat/geonetwork/srv/cat/main.home’ and press
the 'search' button I get one metadata. If I display the contents of the
metadata it shows properly, however, if I press the 'PDF' button, the file
that I get has the 'Characterstring' elements in spanish instead of catalan,
that is, the metadata is a mix of spanish and catalan instead of being
completely in catalan.
I copy an image to show the problem.
How can I solve that problem?
Thanks a lot for your help.
Best regards,
Montse <http://osgeo-org.1560.n6.nabble.com/file/n5042697/pdf_gn.jpg&gt;
View this message in context: http://osgeo-org.1560.n6.nabble.com/The-PDF-is-not-generating-properly-tp5042697.html
