Hi Jeroen, in the advanced search interface I added a popup for keyword
selection and remove duplicate service for keyword search (thanks for the
hint ;). This will allow multiple keywords search : "keyword1" or "keyword2"
or .... that feature was asked by Mathieu also.
The button is named "choose" but maybe an image could be better ... Any
proposal for that ? The advanced search is becoming more and more complex !
Demo is http://dev.sandre.eaufrance.fr/gnthesaurus/
Ciao. Francois
-----Message d'origine-----
De : geonetwork-devel-bounces@lists.sourceforge.net
[mailto:geonetwork-devel-bounces@lists.sourceforge.net] De la part de
François Prunayre
Envoyé : mardi 20 février 2007 09:55
À : 'Jeroen Ticheler'
Cc : geonetwork-devel@lists.sourceforge.net
Objet : Re: [GeoNetwork-devel] [GeoNetwork-users] Thesaurus support
/onlinedemo
Hi Jeroen, the administration interface for thesaurus is easier to use now :
- search for keywords
- go to its description (with narrower, broader and related terms)
- click on another term to browse the thesaurus. ... classic thesaurus
search interface. http://dev.sandre.eaufrance.fr/gnthesaurus/ admin / admin
Ciao. Francois
De : Jeroen Ticheler [mailto:Jeroen.Ticheler@anonymised.com] Envoyé : mardi 13
février 2007 11:13 À : François Prunayre Cc :
geonetwork-devel@lists.sourceforge.net; Roberto Giaccio Objet : Re:
[GeoNetwork-devel] [GeoNetwork-users] Thesaurus support /online demo
Hi Francois,
Looks very nice!
We have a range of problems we run into, some related to the editor I assume
(on my Firefox the codelists appear all empty in the editor, Roberto?). On
Patrizia's Internet Explorer the list did not expand with some of the ISO
records.
- It would be better to filter the keyword list to only show items once.
- It's not very clear which Thesaurus you are using. Do I understand
correctly that you define one thesaurus per thesaurus type now?
- When adding a keyword, the associated thesaurus name element should also
be filled to point to the thesaurus. Anyone an idea what should be put here
best? A URI to the rdf of the resource or so?
On Feb 13, 2007, at 8:50 AM, François Prunayre wrote:
Hi all, some news from the thesaurus prototype.
For now, thesaurus support allows to control vocabulary on the > metadata
editing side (using autocompletion). Then Lucene will make > the index based
on metadata keywords (and not on the thesaurus you > have on the node).
Cool!! Is there a minimum number of characters a user has to type in before
the query to the application for a list starts?
The administration interface allows import/export/creation/browse >
thesaurus.
Changes are :
- Keyword / metadata edit work for ISO191XX, DC (On FGDC, edit >
keywords is not working. Any ideas why ?)
- Keyword / metadata edit / ISO191XX : Search only according selected
> thesaurus Type (discipline, stratum, theme, ...)
- Keyword / Added services for narrower, broader and related keyword >
search
It looks interesting but also quite complex to me, especially because you
have to expand each item manually. It maybe useful to automatically expand
the first level and on click on the next item do the same for that item
instead of clicking on three icons? Also, how are recurring loops deal with?
All in all, pretty impressive! Hope others have ideas and suggestions too!
Ciao,
Jeroen
- Administration / Browse thesaurus
The demo is set up with the Agrovoc thesaurus.
http://dev.sandre.eaufrance.fr/gnthesaurus/ login admin/admin
Any comments, ideas ?
Francois
[mailto:geonetwork-devel-bounces@lists.sourceforge.net] De la part de >
François Prunayre Envoyé : mercredi 17 janvier 2007 15:00 À : 'Jeroen >
Ticheler'; 'Lagarde Pierre'
Objet : Re: [GeoNetwork-devel] [GeoNetwork-users] Thesaurus support >
/online demo
Hi, that's fine for me Jeroen, problem of storing Ids instead of > keyword
could cause problem later when people export (or harwest) > without having
the same thesaurus...
I made the following changes to the prototype in order to :
- Search interface : Autocompletion for search criteria "keyword" >
based on Lucene Index (and not thesaurus). That way, user will select only
keywords which are in metadata. Here you could have a mix of >
multilingual keywords according to what the editors put in.
- Lucene index configuration : Lucene will not create tokens based on >
keyword but will index keyword as term (ie. "polar ecosystem" will be >
index as "polar ecosystem" and not as "polar", "ecosystem").
As proposed by Pierre, I will add for ISO standard a filter based on > the
thesaurus type (place, temporal, discipline ...).
You're right Jeroen, the editor is not working because it's alpha 2. > You
will be able to have a keyword list but not able to save it.
Demo is http://dev.sandre.eaufrance.fr/gnthesaurus/ login admin / >
password admin
Francois
De : Jeroen Ticheler [mailto:Jeroen.Ticheler@anonymised.com] Envoyé : lundi 8 >
janvier 2007 11:21 À : Lagarde Pierre; François Prunayre Cc :
Objet : Re: [GeoNetwork-users] Thesaurus support / online demo
Hi François and Pierre,
Both implementations have some nice aspects and I hope we can find a >
kind of middle way of handling keywords. I feel that using the auto- >
completion facility is the way to go, but it would need to give a more >
flexible way of selecting the right keywords. This should include the >
hierarchy in a thesaurus and also be multilingual in the first place. > On
that part I think the only way to go is to store a keyword > identifier and
not the translated keyword in the text element. The > system should than use
these identifiers to display the local versions > of the keyword (or provide
the default language of the thesaurus if no > translation is available).
In the editor, the full thesaurus content should e available, while, > as
François indicated, in the Search interface, only keywords used in > the
catalog should be presented. In fact, that auto-completion as > implemented
by François would than be a very good first step while a > pop-up could
provide a full-fledged selector that includes hierarchy!?
François, I didn't manage to edit keywords in the FGDC and DC records. > I
know the alpha 2 is still not finished what the editor concerns, so > I
assume that is the cause. Roberto is working on it and a functional > editor
should be ready by the second week of February in a first beta > release.
I suggest that we do not add the thesaurus functionality to the code >
base until the prototype is more functional if that's OK with you >
François?
Ciao,
Jeroen
On Jan 6, 2007, at 6:22 PM, Lagarde Pierre wrote:
Hi françois,
Very good to start the integration of french developments of GN >>
(Géosource in french) in GN alpha2 !
The autocompletion is a very interested approach to integrate >> keywords
(we don't use this solution in Geosource. See http:// >>
212.208.217.23/geosource/srv/fr/main.home).
To complicate yours remarks in Edit interface, I think it will be >>
better to limit the thesaurus query in the thematic of the keywords >> in
function of the 19115 list. For example, place thesauri, theme >>
thesauri,... And, when the user has chosen a specific word, GN could >> add
the thesaurus name in the specific field !
In your demo, impossible to add new "descriptive keywords" block or >>
new "keyword" block (id=12)... Side effect ?
Pierre.
De : geonetwork-users-bounces@lists.sourceforge.net
[mailto:geonetwork-users-bounces@lists.sourceforge.net] De la part de >>
François Prunayre Envoyé : vendredi 5 janvier 2007 17:19 À :
geonetwork-devel@lists.sourceforge.net; geonetwork- >>
users@lists.sourceforge.net Objet : [GeoNetwork-users] Thesaurus >>
Hi list, here is a first demo adding support for thesaurus in >>
Geonetwork (based on alpha2 version - thanks Andrea :).
Thesaurus support allows import/export of "external" thesaurus such >> as
Agrovoc, Gemet or other in rdf/skos format and creation of "local"
thesaurus which will be entirely managed by the administrator of the >>
geonetwork node.
Local thesaurus could be basic (id, label, definition and lang for >>
each
term) used for thesaurus of type discipline, theme, temporal or of >>
type place where you could also defined a bounding box for each term.
Thesaurus creation only support flat thesaurus (ie. you can not >>
defined narrower, broader and related term).
When editing metadata, geonetwork will provide an autocompletion >> field
for keyword searching in all thesaurus available in the current >> node.
When searching for metadata, in the search field keyword, an >>
autocompletion process is also available.
Demo is http://dev.sandre.eaufrance.fr/gnthesaurus/ login admin / >>
password admin. Go to the administration > Manage thesauri. The demo >> is
set up with 3 external thesauri (agrovoc, a thesaurus for the >> water
domain, and the Geonetwork list of regions) and 2 local ones.
Main features available for now :
- Administration :
- thesaurus import/export in RDF skos format
- thesaurus creation/edition for "flat" thesaurus
- support for multilingual thesaurus.
- Edit interface :
- Autocompletion for field "keyword" in DC, FGDC and iso19115 (to
>> be done for ISO19139)
- Autocompletion for search criteria "keyword"
For the time being, the user interface query all thesaurus in the >>
current webpage language. But this not really the best option. For >>
the first implementation, maybe I proposed 2 options for the editing
>> part
- if a language parameter is defined in the current metadata, query
>> the thesaurus in that language
- if not use the webpage language or we could also defined a >> parameter
"metatada default language" ? This will allow user not >> having geonetwork
translation (for now en, fr, es, cn) to use their >> own language for
thesaurus.
For the search this is a more complex part. For now, if the user >>
interface is in spanish, it will look for term in spanish in each >>
thesaurus. If the metadata are in english ... it will not be >> relevant.
Here as a first implementation, we could at least use a parameter >>
"metatada default language". Other and more complex options could be,
>> for the keyword criteria
- search for a term in user interface language and then query using >>
the keyword and its translation. Here users need to have multilingual >>
thesaurus.
- proposed the list of keyword found by Lucene in metadata in the >>
indexing process. That way, geonetwork propose only keyword that are
>> used somewhere in one or more metadata
- analyzed Lucene support for thesaurus ...
The thesaurus are stored in a RDF/SKOS format in the /xml/codelist/ >>
thesauri directory of Geonetwork. They are loaded on startup and RDF >>
manipulation is made with Sesame, an opensource java library for RDF >>
(http://www.openrdf.org/).
Thanks to Laurent Magnien, Arnaud Dupuis and Jean-Pascal Boignard for >>
their first ("french") implementation.
Any comments, ideas, bugs ? If that sounds good to the list, I could >>
put it on the alpha 2 version.
Cheers. Francois
Ce message a ete verifie par MailScanner pour des virus ou des >>
polluriels et rien de suspect n'a ete trouve.
Les donnees et renseignements contenus dans ce message sont >>
personnels, confidentiels et prives. Toute publication, utilisation >> ou
diffusion, meme partielle, doit etre autorisee.
Any data and information contained in this electronic mail is >>
personal, confidential and secret. Any total or partial publication, >> use
or distribution must be authorized.
Take Surveys. Earn Cash. Influence the Future of IT Join >>
SourceForge.net's Techsay panel and you'll get the chance to share >> your
opinions on IT & business topics through brief surveys - and >> earn cash
http://www.techsay.com/default.php?
page=join.php&p=sourceforge&CID=DEVDEV
GeoNetwork-users mailing list
GeoNetwork OpenSource is maintained at http://sourceforge.net/ >>
projects/geonetwork
Le contenu de cet e-mail et de ses pièces jointes est destiné à >>
l'usage exclusif du
(des) destinataire(s) expressément désigné(s) comme tel(s). En cas de >>
réception de cet e-mail par erreur, le signaler à son expéditeur et >> ne
pas en divulguer le contenu.
L'absence de virus a été vérifié à l'émission du message. Il convient >>
néanmoins de vérifier l'absence de corruption à sa réception. The >>
contents of this email and any attachments are confidential. They are >>
intended for the named recipient(s) only. If you have received this >> email
in error please notify the system manager or the sender >> immediately and
do not disclose the contents to anyone or make >> copies.
eSafe scanned this email for viruses, vandals and malicious content.
projects/geonetwork
-- Ce message a ete verifie par MailScanner pour des virus ou des >
personnels, confidentiels et prives. Toute publication, utilisation ou
use or distribution must be authorized.
> --- Take Surveys. Earn Cash. Influence the Future of IT Join >
your opinions on IT & business topics through brief surveys - and earn
cash http://www.techsay.com/default.php? >
GeoNetwork-devel mailing list
-- > Ce message a ete verifie par MailScanner pour des virus ou des >
Les donnees et renseignements contenus dans ce message sont > personnels,
confidentiels et prives. Toute publication, utilisation > ou diffusion,
Any data and information contained in this electronic mail is > personal,
confidential and secret. Any total or partial > publication, use or
> --- Using Tomcat but need to do more? Need to support web services, >
security?
Get stuff done quickly with pre-integrated technology to make your > job
easier.
Download IBM WebSphere Application Server v.1.0.1 based on Apache >
Geronimo http://sel.as-us.falkag.net/sel? >
cmd=lnk&kid=120709&bid=263057&dat=121642
projects/geonetwork
-- Ce message a ete verifie par MailScanner pour des virus ou des polluriels
Les donnees et renseignements contenus dans ce message sont personnels,
confidentiels et prives. Toute publication, utilisation ou diffusion, meme
Any data and information contained in this electronic mail is personal,
confidential and secret. Any total or partial publication, use or
This message has been scanned by the Trend Micro IGSA and found to be free
of known security risks.
Take Surveys. Earn Cash. Influence the Future of IT Join SourceForge.net's
Techsay panel and you'll get the chance to share your opinions on IT &
business topics through brief surveys-and earn cash
