[GeoNetwork-users] Thredds harvest error
I've looked through past messages on the list and while I see similar questions, did not see any replies with solutions so am hoping that someone out there has run into this and/or can help me find an answer.
I am attempting to set up a harvest to a Thredds catalog. I am making sure I put in the .xml extension. I've tried a variety of options based on the user guide and tried single datasets as well as a folder and the full catalog. However, regardless of what I set in the form I get the following error on harvest (*I took the full path and filename out just so it's not published). I'm wondering if there is some other setting I need to do at the server end or if it is something wrong with our .xml? >
Error: Invalid catalog <filename*>.xml ----Catalog Validation version 1.0.01 **Fatal: InvCatalogFactory.readXML failed Exception= java.io.FileNotFoundException <filename*>.xml fatalMessages= errMessages= warnMessages=
Class: BadXmlResponseEx
Stack:
at: org.fao.geonet.kernel.harvest.harvester.thredds.Harvester file: Harvester.java line: 318 method: harvestCatalog
at: org.fao.geonet.kernel.harvest.harvester.thredds.Harvester file: Harvester.java line: 251 method: harvest
at: org.fao.geonet.kernel.harvest.harvester.thredds.ThreddsHarvester file: ThreddsHarvester.java line: 245 method: doHarvest
at: org.fao.geonet.kernel.harvest.harvester.AbstractHarvester$HarvestWithIndexProcessor file: AbstractHarvester.java line: 399 method: process
at: org.fao.geonet.kernel.harvest.harvester.AbstractHarvester file: AbstractHarvester.java line: 429 method: harvest
at: org.fao.geonet.kernel.harvest.harvester.HarvesterJob file: HarvesterJob.java line: 29 method: execute
at: org.quartz.core.JobRunShell file: JobRunShell.java line: 213 method: run
at: org.quartz.simpl.SimpleThreadPool$WorkerThread file: SimpleThreadPool.java line: 557 method: run
TIA!
Kathy K.
Hi Kathy,
The error message below is returned because the harvester is unable to find the catalog using the provided url (you are getting a FileNotFoundException!).
Check the URL you are entering in the harvester returns an xml catalog on the server (e.g. using wget <filename*>.xml on the server).
For example, this url to a thredds.ucar.edu catalog entry works for me:
http://thredds.ucar.edu/thredds/catalog/grib/FNMOC/WW3/Global_1p0deg/FNMOC_WW3_Global_1p0deg_20140921_1200.grib1/catalog.xml
Craig Jones
Integrated Marine observing System
Stack:
  TIA!
Kathy K.
Meet PCI DSS 3.0 Compliance Requirements with EventLog Analyzer
Achieve PCI DSS 3.0 Compliant Status with Out-of-the-box PCI DSS Reports
Are you Audit-Ready for PCI DSS 3.0 Compliance? Download White paper
Comply to PCI DSS 3.0 Requirement 10 and 11.5 with EventLog Analyzer
http://pubads.g.doubleclick.net/gampad/clk?id=154622311&iu=/4140/ostg.clktrk
GeoNetwork-users mailing list
I was able to do a wget on the server, listed out (cat) the xml just fine, but still doesn't work as a harvest from GN. Same file not found error - settings exactly like you have. Since you had success wondering if there is an issue at the geoserver level? I am using 2.8 right now (have to start testing 2.10 and see if that makes a diff I guess).
Kathy
-----Original Message-----
From: Craig Jones [mailto:Craig.Jones@anonymised.com]
Sent: Tuesday, September 23, 2014 6:23 PM
To: Kathy Koch
Subject: Re: [GeoNetwork-users] Thredds harvest error
Hi Kathy,
I'm able to harvest directly from the first catalog url below using a default GeoNetwork 2.10.3 install (I've included a screen dump of the settings I used). The second didn't return any metadata and I think this is because the harvester can't handle the direct reference to the catalog entry for a specific dataset.
Have a look at the settings I used for the harvester, perhaps you can spot the difference? Or perhaps you are using an older version of GeoNetwork? If so let me know the version and I can check the result there, but as far as I'm aware this should work in 2.8 as well.
Also, it would be good to keep this on the mailing list if possible for future reference by others.
Craig Jones
PS. When I said check to make sure you can access the URL on the server I meant check that you can access the URL from the server where GeoNetwork is installed. Perhaps there is a proxy or network issue preventing this server from accessing your thredds server.
On 24/09/14 04:04, Kathy Koch wrote:
Thanks for the reply. Here are the links I've been testing and get the error every time.
What else am I missing?
http://tds.glos.us/thredds/mtri/aoc.xml
http://tds.glos.us/thredds/mtri/aoc.xml?dataset=LakeErieSST-Agg
(Eventually I will want to harvest the entire catalog at
http://tds.glos.us/thredds/catalog.xml but am trying one of the above
two as a test for right now. I did try the entire catalog as a last
resort but got the same error.)
Kathy
_____________________________________
Kathy Koch
Data Curator
Contractor (LimnoTech / GLOS)
501 Avis Drive, Ann Arbor, MI 48108
Office: 734-332-1200 email:kkoch@anonymised.com
LimnoTech www.limno.com<http://www.limno.com>
________________________________________
Sent: Monday, September 22, 2014 7:30 PM
To: geonetwork-users@lists.sourceforge.net<mailto:geonetwork-users@anonymised.comsourceforge.net>
Hi Kathy,
Craig Jones
Stack:
at:
method: run
   TIA!
Kathy K.
--------- Meet PCI DSS 3.0 Compliance Requirements with EventLog
Analyzer Achieve PCI DSS 3.0 Compliant Status with Out-of-the-box PCI
DSS Reports Are you Audit-Ready for PCI DSS 3.0 Compliance? Download
White paper Comply to PCI DSS 3.0 Requirement 10 and 11.5 with
EventLog Analyzer
.clktrk _______________________________________________
GeoNetwork-users@lists.sourceforge.net<mailto:GeoNetwork-users@anonymised.comrceforge.net>
EventLog Analyzer
GeoNetwork-users@lists.sourceforge.net<mailto:GeoNetwork-users@anonymised.comceforge.net>
Okay. Looks like it's a 2.8 issue. I brought up 2.10 and the harvest worked just fine. Guess I'm off to do a full migration and make 2.10 live. Thanks for your help! (although if you had an easy fix to make it work on 2.8 that would be nice, not necessary to investigate much further)
Kathy
Kathy Koch
Data Curator
Office: 734-332-1200 email:kkoch@anonymised.com<mailto:kkoch@anonymised.com>
LimnoTech www.limno.com<https://mail.limno.com/owa/UrlBlockedError.aspx&gt;
<../../../../tdekker/AppData/Local/Microsoft/Windows/Temporary%20Internet%20Files/Content.Outlook/8B0OUOWO/www.limno.com>
Sent: Wednesday, September 24, 2014 10:47 AM
To: Craig Jones
Cc: geonetwork-users@lists.sourceforge.net
Subject: RE: [GeoNetwork-users] Thredds harvest error
Kathy
To: Kathy Koch
Hi Kathy,
Craig Jones
Kathy
Kathy Koch
Data Curator
Hi Kathy,
Craig Jones
Stack:
at:
method: run
   TIA!
Kathy K.
EventLog Analyzer
EventLog Analyzer
