I am trying to harvest a thredds catalog using GeoNetwork v3 RC0. While setting up the harvester I've encountered an issue which I cannot fix by myself and I rely on your help.
As you can see in this image: http://postimg.org/image/hav7m4tsn/
the dropdown-menu "Stylesheet to create metadata fragments" is empty. In v2.x there is an option to select either a netcdf attributes or thredds metadata stylesheet. Both stylesheets are located in: "data/config/schema_plugins/iso19139/convert/ThreddsToFragments" which should be the correct location for them. Yet those are not displayed in the dropdown menu.
So if anyone has got an idea how to fix this issue, I appreciate it greatly.
Greetings,
Sebastian
Hi Sebastian,
2015-04-27 13:17 GMT+02:00 Sebastian Hübner <
sebastian.huebner@anonymised.com>:
the dropdown menu.
greatly.
See https://github.com/geonetwork/core-geonetwork/issues/960
It will be fixed in 3.0.0.
Cheers.
Francois
Greetings,
Sebastian
One dashboard for servers and applications across Physical-Virtual-Cloud
Widest out-of-the-box monitoring support with 50+ applications
Performance metrics, stats and reports that give you Actionable Insights
Deep dive visibility with transaction tracing using APM Insight.
http://ad.doubleclick.net/ddm/clk/290420510;117567292;y
GeoNetwork-users mailing list
