GeoNetwork 3.10.2 seems to be working fine for months, but we have been ignoring three non-critical system check errors on the status page:
* Dashboard error - related to not using ElasticSearch
* remote index - also related to not using elasticsearch
* available connections in database =0 (we use jndi and PostGIS, and
have set 200 handles and 10 reserved in the postgreSQL config)
Should we be downloading and using ElasticSearch, modifying web.xml and presumably making the first two errors go away (and improving wfs searches)?
How to change the jndi connections?
Hi Terry, those modules are optional - at least dashboard and remote index.
https://geonetwork-opensource.org/manuals/trunk/en/user-guide/analyzing/data.html
https://geonetwork-opensource.org/manuals/trunk/en/maintainer-guide/statistics/index.html
So it is not critical and if you don't need it it does not make sense to
add them just for removing those warnings.
For JNDI, no suggestion.
Cheers.
Francois
searches)?
GeoNetwork-users mailing list
Thank you for that.
Upon perusing the links, I think I need to implement ElasticSearch - it seems to provide excellent capability.
So it is not critical and if you don't need it it does not make sense to add them just for removing those warnings.
Cheers.
Francois
Le lun. 28 déc. 2020 à 05:13, Terry <terry.curran@anonymised.com <mailto:terry.curran@anonymised.com>> a écrit :
been
PostGIS, and
web.xml and
searches)?
<mailto:GeoNetwork-users@lists.sourceforge.net>
<https://lists.sourceforge.net/lists/listinfo/geonetwork-users>
<http://sourceforge.net/projects/geonetwork>
Hi, I would recommend to use GeoNetwork 4 if interested in Elasticsearch
benefits (scoring, more like this, performance, ...)
https://geonetwork-opensource.org/_static/documents/gn-user-meeting-202006-GeoNetwork4-All-about-search.pdf
Francois
Le mer. 6 janv. 2021 à 22:20, Terry <terry.curran@anonymised.com> a écrit :
Thank you for that.
Cheers.
Francois
searches)?
