I recently migrated my geonetwork install to a different server and am
having difficulties uploading thumbnails into my metadata. It mostly works
but at times it gives me a java heap memory error. The file sizes are small
- under 500k. It seems mostly related to one user. Would increasing the
java heap size help with this and if so, how do I go about doing this?
It is possible to know which of the z39.50 fields are supported in Geonetwork? I would like to know the queries that the Geonetwork z39.50 server is able to answer. Ii it able to answer searches by scale (using the 1024 z39.50 attribute)?
In the "Configure Tomcat" tool Java tab - set initial memory pool to 256 and
maximum memory pool to 512.
Images loaded with no error
Byron
ByronC wrote:
Hello,
works but at times it gives me a java heap memory error. The file sizes
are small - under 500k. It seems mostly related to one user. Would
increasing the java heap size help with this and if so, how do I go about
doing this?
