[GeoNetwork-users] thumbnails not show harvesting WMS geonetwork 10
Dear all
I'm struggling trying to figure out why thumbnails are not showed
after harvesting a local geoserver 2.3. I have checked permissions and
seeing the log but everything looks ok. I think it is a common issue
(which i could not resolve in GeonetWork 2.8, so i upgraded hoping
this error dissapear). I'm running geonetwork with tomcat6 and postgis
database..
Could anybody give me a clue to face the problem?
Thanks in advance
Jesús
Hi Jesús
Check if this solves the issue: select protocol WMS 1.1.1 version. In the
type of import, unselect the check for Create metadata for layer elements
using MetadataURL attributes.
Last week I had similar issue and this solved my problem. I have pending to
check the issue for a fix.
Jose García
On Fri, Sep 27, 2013 at 5:13 AM, Jesús <gesusjl@anonymised.com> wrote:
Dear all
database..
Thanks in advance
Jesús
October Webinars: Code for Performance
Free Intel webinars can help you accelerate application performance.
Explore tips for MPI, OpenMP, advanced profiling, and more. Get the most
from
the latest Intel processors and coprocessors. See abstracts and register >
http://pubads.g.doubleclick.net/gampad/clk?id=60133471&iu=/4140/ostg.clktrk
GeoNetwork-users mailing list
GeoCat Bridge for ArcGIS allows instant publishing of data and metadata on
GeoServer and GeoNetwork. Visit http://geocat.net for details.
_________________________
Jose García
GeoCat bv
Veenderweg 13
6721 WD Bennekom
The Netherlands
http://GeoCat.net/&gt;
Hi Jose
No luck at all. i've been testing differents configuration in the
past, however i tried again as you suggest but thumbails are not
showed.
Actually i have two differents geonetwork / geoserver in a local /
intranet enviroment. Both are deployed using war files. Neither of
them are able to manage thumbnails correctly, but the geonetwork log
in the intranet site is giving me some errors.
2013-09-27 08:36:52,932 ERROR [geonetwork.index] - Failed to properly
index geometry of metadata 1889. Error: null
java.lang.NullPointerException
Failed to set thumbnail for metadata: null
I appreciate your help
Jesus
2013/9/27, Jose Garcia <jose.garcia@anonymised.com>:
Hi Jesús
Jose García
Dear all
database..
Thanks in advance
Jesús
from
Jose García
GeoCat bv
Veenderweg 13
6721 WD Bennekom
The Netherlands
Jesús
Hi, Jesús, i have the same problem!
Thanks
On Fri, Sep 27, 2013 at 11:49 AM, Jesús <gesusjl@anonymised.com> wrote:
Hi Jose
showed.
Jesus
> Hi Jesús
to
> Regards,
> Jose García
>> Dear all
>> database..
>> Thanks in advance
>> Jesús
>> from
>> _______________________________________________
on
> Jose García
> GeoCat bv
> Veenderweg 13
> 6721 WD Bennekom
> The Netherlands
Jesús
from
Davi de O. Custódio
Not alone!.
I have more than 600 layers ready to be served by geoserver in a local
intranet, but having this kind of issue stop me from make them
publicly available. Does anybody know any other strategy to serve my
data properly in geonetwork?.
Thanks in advance
Jesus
2013/9/27, Davi Custodio <davicustodio@anonymised.com>:
Thanks
Hi Jose
showed.
Jesus
> Hi Jesús
> the
> elements
> pending
to
> Regards,
> Jose García
>> Dear all
>> database..
>> Thanks in advance
>> Jesús
>> most
>> from
>> register
on
> Jose García
> GeoCat bv
> Veenderweg 13
> 6721 WD Bennekom
> The Netherlands
Jesús
from
Davi de O. Custódio
Jesús
Hi Jesús
I have found that if the url is configured to
http://localhost:8080/geoserver/wms?request=GetCapabilities&service=WMSmakes
fail the thumbnails retrieval, but removing the request and service
parameters seem working fine. Seem that this has been changed from previous
versions.
I have this configuration (harvesting from GeoServer 2.3.2):
Protocol: WMS 1.1.1
Url: *http://localhost:8080/geoserver/wms* (no request or service params)
Type of import:
Create metadata for layer elements using GetCapabilities information.
Create metadata for layer elements using MetadataURL attributes (if
existing, if not use GetCapabilities).
Create thumbnails for WMS layers.
With previous configuration I get the thumbnails harvested without fails
and displayed in the search results of the new UI (default in 2.10), but in
the classic UI still continue to get the No preview image available (need
to check more about this).
If you use the new UI, previous configuration I guess helps to get the
harvester working fine with thumbnails.
Jose García
On Fri, Sep 27, 2013 at 5:25 PM, Jesús <gesusjl@anonymised.com> wrote:
Not alone!.
Thanks in advance
Jesus
> Thanks
>> Hi Jose
>> showed.
>> Jesus
>> > Hi Jesús
>> > the
>> > elements
>> > pending
>> to
>> > Regards,
>> > Jose García
>> >> Dear all
and
postgis
>> >> database..
>> >> Thanks in advance
>> >> Jesús
>> >> most
>> >> from
>> >> register
metadata
>> on
>> > Jose García
>> > GeoCat bv
>> > Veenderweg 13
>> > 6721 WD Bennekom
>> > The Netherlands
>> Jesús
>> from
> Davi de O. Custódio
Jesús
Jose García
GeoCat bv
Veenderweg 13
6721 WD Bennekom
The Netherlands
Hi Jose.
Great! It's been working switching to a new UI
<client type="redirect" widget="true" url="../../apps/tabsearch/"
createParameter="#create" stateId="s"/>
I guess we can play with different configuration using the new UI
without loosing the thumbnails. Let's see how does it works in the
server environment with a bunch of layers waiting to be harvested.
Please, warn me if you figure out what was happening with the previous
gui, even for curiosity...
Thank you so much!.
Best regards
Jesús
2013/9/28, Jose Garcia <jose.garcia@anonymised.com>:
Hi Jesús
versions.
Protocol: WMS 1.1.1
Type of import:
Jose García
Not alone!.
Thanks in advance
Jesus
> Thanks
>> Hi Jose
>> showed.
>> Jesus
>> > Hi Jesús
>> > In
>> > the
>> > elements
>> > pending
>> to
>> > Regards,
>> > Jose García
>> >> Dear all
and
>> >> issue
postgis
>> >> database..
>> >> Thanks in advance
>> >> Jesús
>> >> performance.
>> >> most
>> >> from
>> >> register
metadata
>> on
>> > Jose García
>> > GeoCat bv
>> > Veenderweg 13
>> > 6721 WD Bennekom
>> > The Netherlands
>> Jesús
>> most
>> from
>> register
> Davi de O. Custódio
Jesús
Jose García
GeoCat bv
Veenderweg 13
6721 WD Bennekom
The Netherlands
Jesús
Hi Jesús
I'm investigating and found the problem, want to discuss with other
developers before committing.
Related to the new UI, it's not the tabsearch, but the html5 ui, you can
enable in config-gui.xml with this line:
<client type="redirect" widget="true" url="../../srv/eng/search"
createParameter="#create" stateId="s" />
Jose García
On Sun, Sep 29, 2013 at 3:20 AM, Jesús <gesusjl@anonymised.com> wrote:
Hi Jose.
Thank you so much!.
Best regards
Jesús
> Hi Jesús
previous
> versions.
> Protocol: WMS 1.1.1
params)
> Type of import:
in
> Regards,
> Jose García
>> Not alone!.
>> Thanks in advance
>> Jesus
>> > Thanks
>> >> Hi Jose
>> >> showed.
>> >> Jesus
>> >> > Hi Jesús
>> >> > In
>> >> > the
>> >> > elements
>> >> > pending
>> >> to
>> >> > Regards,
>> >> > Jose García
>> >> >> Dear all
>> and
>> >> >> issue
>> postgis
>> >> >> database..
>> >> >> Thanks in advance
>> >> >> Jesús
>> >> >> performance.
the
>> >> >> most
>> >> >> from
>> >> >> register
>> metadata
>> >> on
>> >> > Jose García
>> >> > GeoCat bv
>> >> > Veenderweg 13
>> >> > 6721 WD Bennekom
>> >> > The Netherlands
>> >> Jesús
>> >> most
>> >> from
>> >> register
>> > Davi de O. Custódio
>> Jesús
on
> Jose García
> GeoCat bv
> Veenderweg 13
> 6721 WD Bennekom
> The Netherlands
Jesús
Jose García
GeoCat bv
Veenderweg 13
6721 WD Bennekom
The Netherlands
Hi Jesús
The issue about classic UI is fixed in
https://github.com/geonetwork/core-geonetwork/issues/257, should be
available in coming 2.10.2 version.
Jose García
On Sun, Sep 29, 2013 at 10:52 AM, Jose Garcia <jose.garcia@anonymised.com>wrote:
Hi Jesús
Jose García
Hi Jose.
Thank you so much!.
Best regards
Jesús
> Hi Jesús
previous
> versions.
> Protocol: WMS 1.1.1
params)
> Type of import:
information.
but in
(need
> Regards,
> Jose García
>> Not alone!.
>> Thanks in advance
>> Jesus
>> > Thanks
>> >> Hi Jose
>> >> showed.
properly
>> >> Jesus
>> >> > Hi Jesús
>> >> > In
>> >> > the
>> >> > elements
>> >> > pending
>> >> to
>> >> > Regards,
>> >> > Jose García
>> >> >> Dear all
showed
permissions
>> and
>> >> >> issue
hoping
>> postgis
>> >> >> database..
>> >> >> Thanks in advance
>> >> >> Jesús
>> >> >> performance.
the
>> >> >> most
>> >> >> from
>> >> >> register
>> metadata
>> >> on
>> >> > Jose García
>> >> > GeoCat bv
>> >> > Veenderweg 13
>> >> > 6721 WD Bennekom
>> >> > The Netherlands
>> >> Jesús
>> >> most
>> >> from
>> >> register
>> > Davi de O. Custódio
>> Jesús
on
> Jose García
> GeoCat bv
> Veenderweg 13
> 6721 WD Bennekom
> The Netherlands
Jesús
Jose García
GeoCat bv
Veenderweg 13
6721 WD Bennekom
The Netherlands
Jose García
GeoCat bv
Veenderweg 13
6721 WD Bennekom
The Netherlands
Hi Jose
Thanks for your help. I wish i could give a try to git geonetwork trunk but
i'm having some issues compiling with ant. Anyway that's another matter.
HTML5 UI it's a big step to modernize geonetwork appearence and usability.
I'll be waiting for María Arias workshop to customize HTML5 UI .
Now once everything is more or less under control it's time to metadata!.
Regards
Jesús
2013/9/29 Jose Garcia <jose.garcia@anonymised.com>
Hi Jesús
Jose García
Hi Jesús
Jose García
Hi Jose.
Thank you so much!.
Best regards
Jesús
> Hi Jesús
previous
> versions.
> Protocol: WMS 1.1.1
params)
> Type of import:
information.
fails
but in
(need
> Regards,
> Jose García
>> Not alone!.
>> Thanks in advance
>> Jesus
>> > Thanks
>> >> Hi Jose
>> >> showed.
log
properly
>> >> Jesus
>> >> > Hi Jesús
version.
>> >> > In
>> >> > the
>> >> > elements
>> >> > pending
>> >> to
>> >> > Regards,
>> >> > Jose García
wrote:
>> >> >> Dear all
showed
permissions
>> and
>> >> >> issue
hoping
>> postgis
>> >> >> database..
>> >> >> Thanks in advance
>> >> >> Jesús
>> >> >> performance.
the
>> >> >> most
>> >> >> from
>> >> >> register
>> metadata
>> >> on
>> >> > Jose García
>> >> > GeoCat bv
>> >> > Veenderweg 13
>> >> > 6721 WD Bennekom
>> >> > The Netherlands
>> >> Jesús
performance.
>> >> most
>> >> from
>> >> register
>> > Davi de O. Custódio
>> Jesús
metadata on
> Jose García
> GeoCat bv
> Veenderweg 13
> 6721 WD Bennekom
> The Netherlands
Jesús
on GeoServer and GeoNetwork. Visit http://geocat.net for details.
Jose García
GeoCat bv
Veenderweg 13
6721 WD Bennekom
The Netherlands
Jose García
GeoCat bv
Veenderweg 13
6721 WD Bennekom
The Netherlands
Jesús
I've just seen the HTML5 workshop!
http://delawen.github.io/foss4g2013/#/step-1
Best
Jesús
2013/9/29, Jose Garcia <jose.garcia@anonymised.com>:
Hi Jesús
Jose García
Hi Jesús
Jose García
Hi Jose.
Thank you so much!.
Best regards
Jesús
> Hi Jesús
previous
> versions.
> Protocol: WMS 1.1.1
params)
> Type of import:
information.
> (if
> fails
but in
(need
> Regards,
> Jose García
>> Not alone!.
>> local
>> Thanks in advance
>> Jesus
>> > Thanks
>> >> Hi Jose
>> >> showed.
>> >> of
>> >> log
properly
>> >> Jesus
>> >> > Hi Jesús
>> >> > version.
>> >> > In
>> >> > the
>> >> > elements
>> >> > pending
>> >> to
>> >> > Regards,
>> >> > Jose García
>> >> > wrote:
>> >> >> Dear all
showed
permissions
>> and
>> >> >> issue
hoping
>> postgis
>> >> >> database..
>> >> >> Thanks in advance
>> >> >> Jesús
>> >> >> performance.
the
>> >> >> most
>> >> >> from
>> >> >> register
>> metadata
>> >> on
>> >> > Jose García
>> >> > GeoCat bv
>> >> > Veenderweg 13
>> >> > 6721 WD Bennekom
>> >> > The Netherlands
>> >> Jesús
>> >> performance.
>> >> the
>> >> most
>> >> from
>> >> register
>> > Davi de O. Custódio
>> Jesús
> metadata
on
> Jose García
> GeoCat bv
> Veenderweg 13
> 6721 WD Bennekom
> The Netherlands
Jesús
on
Jose García
GeoCat bv
Veenderweg 13
6721 WD Bennekom
The Netherlands
Jose García
GeoCat bv
Veenderweg 13
6721 WD Bennekom
The Netherlands
Jesús
