[GeoNetwork-users] To Enable Show Advanced Options by Default
I have GN set up, and looking working. My question here is how I can enable the "Show Advanced options" to show by default so that end users can enter inputs.
Thanks.
For GN v2.10.2 HTML5UI I have made the below changes to show the advanced
options by default in the home and catalog tabs (probably not the most
elegant approach but it works).
Commented out hideAdvancedSearch(); in App.js
(https://github.com/geonetwork/core-geonetwork/blob/2.10.2/web-client/src/main/resources/apps/html5ui/js/App.js#L673)
And added showAdvancedSearch(); at end of onReady
(https://github.com/geonetwork/core-geonetwork/blob/2.10.2/web-client/src/main/resources/apps/html5ui/js/App.js#L762)
Changed hideAdvancedSearch(); to showAdvancedSearch(); in GlobalFunctions.js
showBrowse
(https://github.com/geonetwork/core-geonetwork/blob/2.10.2/web-client/src/main/resources/apps/html5ui/js/GlobalFunctions.js#L74)
And added showAdvancedSearch(); at end of showSearch
(https://github.com/geonetwork/core-geonetwork/blob/2.10.2/web-client/src/main/resources/apps/html5ui/js/GlobalFunctions.js#L148)
I hope this helps.
Kind regards
View this message in context: http://osgeo-org.1560.x6.nabble.com/To-Enable-Show-Advanced-Options-by-Default-tp5156276p5156497.html
It works beautiful. Shireeb. Thank you so much.
On Thursday, August 14, 2014 10:26 PM, shireeb <s.brockie@anonymised.com> wrote:
showBrowse
I hope this helps.
Kind regards
GeoNetwork-users mailing list
