[GeoNetwork-users] Tomcat crashes
I want to use geonetwork with tomcat on win.
So I installed Tomcat 6.0.20 and geonetwork, copied folder web/geonetwork and
web/intermap into webapps (and insert new geonetwork.xml and intermap.xml into
Tomcat/conf/catalina/localhost). Then I changed geoserver_data_dir (web.xml) to
path of a separate installed geoserver.
Tomcat starts but when I want to start geonetwork tomcat crashes.
tomcat logs give a warning: Native library load
failed.java.lang.UnsatisfiedLinkError: no gdalJni in java.library.path. I
googeled and found that this is no heavy problem.
I have Java 1.6.0_20 installed.
Any clue?
Thanks
best regards
Sarah
