Could this be an issue of memory?
I have a Intel Core 2 Quad CPU 2,4GHZ 2,00GB RAM.
At stdout.log I could see (with DEBUG logging)
61928 [http-8080-2] INFO jeeves.service - -> transforming with stylesheet
: C:\Programme\geonetwork\web\geonetwork\/xsl/main-page.xsl
Recoverable error
XTRE0540: Ambiguous rule match for /
Matches both "document-node()" on line 13 of
file:/C:/Programme/geonetwork/web/geonetwork/xsl/main-page.xsl
and "document-node()" on line 34 of
file:/C:/Programme/geonetwork/web/geonetwork/xsl/main.xsl
266353 [http-8080-2] ERROR jeeves.service - -> exception during
transformation for : main.home
266353 [http-8080-2] ERROR jeeves.service - -> (C) stylesheet :
266353 [http-8080-2] ERROR jeeves.service - -> (C) message : null
266353 [http-8080-2] ERROR jeeves.service - -> (C) exception :
ClientAbortException
271838 [http-8080-2] DEBUG jeeves.service - Raised exception while executing
service
<error id="error">
<message />
<class>ClientAbortException</class>
<stack>
<at class="org.apache.catalina.connector.OutputBuffer"
file="OutputBuffer.java" line="358" method="realWriteBytes" />
<at class="org.apache.tomcat.util.buf.ByteChunk" file="ByteChunk.java"
line="354" method="append" />
file="OutputBuffer.java" line="381" method="writeBytes" />
file="OutputBuffer.java" line="370" method="write" />
<at class="org.apache.catalina.connector.CoyoteOutputStream"
file="CoyoteOutputStream.java" line="89" method="write" />
file="CoyoteOutputStream.java" line="83" method="write" />
<at class="jeeves.server.dispatchers.ServiceManager" file="???" line="-1"
method="dispatchOutput" />
method="dispatch" />
<at class="jeeves.server.JeevesEngine" file="???" line="-1"
<at class="jeeves.server.sources.http.JeevesServlet" file="???" line="-1"
method="execute" />
</stack>
<request>
<language>en</language>
<service>main.home</service>
</request>
<response />
</error>
271838 [http-8080-2] INFO jeeves.service - -> dispatching to error for :
main.home
271885 [http-8080-2] INFO jeeves.service - -> transforming with stylesheet
: C:\Programme\geonetwork\web\geonetwork\/xsl/error.xsl
Recoverable error
Matches both "document-node()" on line 9 of
file:/C:/Programme/geonetwork/web/geonetwork/xsl/res.xsl
and "document-node()" on line 11 of
272276 [http-8080-2] INFO jeeves.service - -> end error transformation for
: main.home
272276 [http-8080-2] INFO jeeves.service - -> error ended for : main.home
Is it a problem between jetty and tomcat?
Any tip?
Thanks.
best regards
Sarah
I want to use geonetwork with tomcat on win.
So I installed Tomcat 6.0.20 and geonetwork, copied folder web/geonetwork and
web/intermap into webapps (and insert new geonetwork.xml and intermap.xml into
Tomcat/conf/catalina/localhost). Then I changed geoserver_data_dir (web.xml) to
path of a separate installed geoserver.
Tomcat starts but when I want to start geonetwork tomcat crashes.
tomcat logs give a warning: Native library load
failed.java.lang.UnsatisfiedLinkError: no gdalJni in java.library.path. I
googeled and found that this is no heavy problem.
I have Java 1.6.0_20 installed.
Any clue?
Thanks
best regards
Sarah
