[GeoNetwork-users] Tomcat version with GN3
Hi
What about Tomcat version with GN3 ?
Indeed, on a Centos VM, I have many problem to install GN3 on Tomcat 7.
Have you ever managed a such install ?
Thank you
2015-05-19 11:50 GMT+02:00 Georges H <georges.hinot@anonymised.com>:
Hi
GN3 has been deployed with no issue with Java 7 or 8 on Tomcat 7 or 8.
Therefore, on Tomcat 8, there is an issue with mapfish print module used to
print map as PDF.
Francois
Thank you
One dashboard for servers and applications across Physical-Virtual-Cloud
Widest out-of-the-box monitoring support with 50+ applications
Performance metrics, stats and reports that give you Actionable Insights
Deep dive visibility with transaction tracing using APM Insight.
http://ad.doubleclick.net/ddm/clk/290420510;117567292;y
GeoNetwork-users mailing list
OK, thanks.
Can I specify my configuration : Tomcat7 on Centos7.
Do you know installation with no issue with this config ?
2015-05-19 15:32 GMT+02:00 Francois Prunayre <fx.prunayre@anonymised.com>:
Hi
to print map as PDF.
Francois
Thank you
*Georges Hinot*
*CNRS - DRIIHM - UMS BBEES (3468)*
Musée d'Histoire Naturelle de Paris, Maison Buffon
Géomaticien - Administrateur BDD - Intégrateur
*Tél : 01 40 79 80 44*
*Tél : 06 47 61 84 92*
Le nouveau site DRIIHM-ROHM ! <http://driihm.fr>
