[GeoNetwork-users] Transaction Insert request generates authentication exception
I am testing external CS/W client on CS/W server of geonetwork 2.4 rc2.
When i post the xml embedded in transaction/insert, server generates
- <ows:ExceptionReport xmlns:ows="http://www.opengis.net/ows&quot;
xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance&quot; version="1.0.0"
xsi:schemaLocation="http://www.opengis.net/ows
http://schemas.opengis.net/ows/1.0.0/owsExceptionReport.xsd&quot;&gt;
- <ows:Exception exceptionCode="NoApplicableCode">
  <ows:ExceptionText>Cannot process transaction: User not
authenticated.</ows:ExceptionText>
  </ows:Exception>
  </ows:ExceptionReport>
althought i am using admin login for this operation. I presume that there is
a configuration that i am missing to allow external request.
Any idea for publishing metadata from external client using csw
View this message in context: http://n2.nabble.com/Transaction-Insert-request-generates-authentication-exception-tp3287845p3287845.html
Hello, for example using JS, the following example could be used to
login and run the transaction :
http://geonetwork.svn.sourceforge.net/viewvc/geonetwork/trunk/web/geonetwork/scripts/test-csw.js?r1=2726&r2=4898&pathrev=4898
HTH.
Francois
2009/7/20 Ozan <o.emem@anonymised.com>:
</ows:Exception>
Enter the BlackBerry Developer Challenge
This is your chance to win up to $100,000 in prizes! For a limited time,
vendors submitting new applications to BlackBerry App World(TM) will have
the opportunity to enter the BlackBerry Developer Challenge. See full prize
details at: http://p.sf.net/sfu/Challenge
GeoNetwork-users mailing list
