Hi Giuseppe
A fast way to check if database is working is to login in GeoNetwork. If
using 2.6.x you'll get most probably a NullPointerException if database
connection is not working.
If you can log in the system, try to reindex the catalog, most probably the
problem of no results is related to a problem with lucene index. Login as
Administrator user, go to Administration page and hit the button to
Reindex the catalog. After that check if search works again.
Also for a production site I would recommend to use Postgres/MySql
databases instead of McKoi. McKoi is not a bad database, but lack of tools
to manage it properly.
Jose gGarcía
On Wed, Feb 27, 2013 at 5:57 PM, Giuseppe Molinario
<g.molinario@anonymised.com>wrote:
Also - if this might help you frame the problem, the layers under "recent
changes" appear in the list, if I click on them the data appears in the
metadata view, and I can also access the "edit" page for it. But those are
the only layers I see, if i search for anything the layers don't display in
the metadata area.
also i know the DB is working because I can see that it pulls my custom
country layers and my custom data categories.
this is the link
congo.iluci.org/dataexplorer
thanks
g
On Wed, Feb 27, 2013 at 11:49 AM, Giuseppe Molinario
> Hi Ian,
> What am I looking for in the logs?
> Essentially since jetty and the geonetwork interface work correctly, the
> problem should either be that the connection to the database is broken,
or
> the database server is not on ? does the mckoi DB have an on and off
state
> ? Sorry if that's a stupid question.
> Thanks
> G
> On Mon, Feb 25, 2013 at 5:21 PM, ianwallen <ianwallen@anonymised.com>
wrote:
>> Did you try looking at the log files in the jetty/logs folder.
>> View this message in context:
http://osgeo-org.1560.n6.nabble.com/troubleshooting-geonetwork-tp5036797p5036801.html
>> Sent from the GeoNetwork users mailing list archive at Nabble.com.
>> Everyone hates slow websites. So do we.
>> Make your web apps faster with AppDynamics
>> Download AppDynamics Lite for free today:
>> http://p.sf.net/sfu/appdyn_d2d_feb
>> _______________________________________________
>> GeoNetwork-users mailing list
>> GeoNetwork-users@lists.sourceforge.net
>> https://lists.sourceforge.net/lists/listinfo/geonetwork-users
>> GeoNetwork OpenSource is maintained at
>> http://sourceforge.net/projects/geonetwork
GeoCat Bridge for ArcGIS allows instant publishing of data and metadata on
GeoServer and GeoNetwork. Visit http://geocat.net for details.
Jose García
GeoCat bv
Veenderweg 13
6721 WD Bennekom
The Netherlands
http://GeoCat.net/>
