[GeoNetwork-users] Trying to connect GN with potgres - srv.xml has an illegal name. Node names must be of the form: [a-zA-Z_\-]+
Hi, can someone point me in the right direction how to correctly connect GN
3.2.x (deployed with war) with postgresql ?
Deployment with the default H2 database works fine. Then I used the
procedure in the manual
http://geonetwork-opensource.org/manuals/3.0.5/eng/users/maintainer-guide/installing/configuring-database.html
+ Comment out the h2 and set the postgresql node in srv.xml :
+ Modify the connection information in the jdbc.properties file :
+ Restart the tomcat service.
This is the result :
/FATAL [jeeves.engine] - Raised exception during init
FATAL [jeeves.engine] - Exception : java.lang.IllegalArgumentException:
FATAL [jeeves.engine] - Message : srv.xml has an illegal name. Node
FATAL [jeeves.engine] - Stack : java.lang.IllegalArgumentException:
        at
jeeves.config.springutil.JeevesContextLoaderListener.contextInitialized(JeevesContextLoaderListener.java:103)
        at
org.apache.catalina.core.StandardContext.listenerStart(StandardContext.java:5027)
        at
org.apache.catalina.core.StandardContext.startInternal(StandardContext.java:5525)
        at
org.apache.catalina.util.LifecycleBase.start(LifecycleBase.java:150)
        at
org.apache.catalina.core.ContainerBase.addChildInternal(ContainerBase.java:901)
        at
org.apache.catalina.core.ContainerBase.addChild(ContainerBase.java:877)
        at
org.apache.catalina.core.StandardHost.addChild(StandardHost.java:649)
        at
org.apache.catalina.startup.HostConfig.deployWAR(HostConfig.java:1083)
        at
org.apache.catalina.startup.HostConfig$DeployWar.run(HostConfig.java:1879)
        at
java.util.concurrent.Executors$RunnableAdapter.call(Executors.java:511)
        at java.util.concurrent.FutureTask.run(FutureTask.java:266)
        at
java.util.concurrent.ThreadPoolExecutor.runWorker(ThreadPoolExecutor.java:1142)
        at
java.util.concurrent.ThreadPoolExecutor$Worker.run(ThreadPoolExecutor.java:617)
        at java.lang.Thread.run(Thread.java:745)
I couldn't find no report about this error on this mailing list, nor on the
web. I appeared as there was an issue with the jdbc.username structure as
the first postgresql user name consisted of numbers, eg: user123. I changed
the user name just in case, but didn't help.
Using the user name and db specified in the jdbc.properties via the command
line to connect to psql works, so the postgresql configuration shouldn't be
the issue neither.
The worst of all is that if changing back to H2 - using the default settings
in srv.xml and jdbc.properties, geonetwork stays blocked with the same
error. No and I didn't forget to restart tomcat. I have to deploy the war
file from scratch if I want to get rid of this error.
I'd realy appreciate some feedback on this and thanks for checking it out !
View this message in context: http://osgeo-org.1560.x6.nabble.com/Trying-to-connect-GN-with-potgres-srv-xml-has-an-illegal-name-Node-names-must-be-of-the-form-a-zA-Z-tp5322253.html
Editing the config-spring-geonetwork is not a part of the procedure in the
manual. Is that a necessary step ?
http://osgeo-org.1560.x6.nabble.com/GeoNetwork-with-PostGIS-configuration-problem-tp5311204p5311210.html
View this message in context: http://osgeo-org.1560.x6.nabble.com/Trying-to-connect-GN-with-postgresql-srv-xml-has-an-illegal-name-Node-names-must-be-of-the-form-a-zA-tp5322253p5322263.html
Check the name of the node config file. It looks like when you edited it you
added another exntension so instead of be named srv.xml it is now name
srv.xml.somethingelse.
If it is the case, please remove the new extension and restore the file name
back to srv.xml.
View this message in context: http://osgeo-org.1560.x6.nabble.com/Trying-to-connect-GN-with-postgresql-srv-xml-has-an-illegal-name-Node-names-must-be-of-the-form-a-zA-tp5322253p5322349.html
        at
        at
        at
        at
        at
        at
        at
        at
        at
        at
        at
        at
the issue neither.
settings
you added another exntension so instead of be named srv.xml it is now name
name back to srv.xml.
*Vriendelijke groeten / Kind regards,Juan Luis Rodríguez.
<http://www.geocat.net/&gt;Veenderweg 136721 WD BennekomThe NetherlandsT: +31
(0)318 416664 <+31318416664> <https://www.facebook.com/geocatbv&gt;
<https://twitter.com/geocat_bv&gt;
<https://plus.google.com/u/1/+GeocatNetbv/posts&gt;Please consider the
environment before printing this email.*
Right ! There were exactly 2 dots in the filename. On purpose. I usually make
a copy of the original file before modifying its contents. In this case I've
overlooked the multinode mode and got punished.
Thank you a lot for the input ! It works now.
View this message in context: http://osgeo-org.1560.x6.nabble.com/Trying-to-connect-GN-with-postgresql-srv-xml-has-an-illegal-name-Node-names-must-be-of-the-form-a-zA-tp5322253p5322413.html
